78' Ford F250 HP44 Questions???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-22-2006, 09:20 AM   #1 (permalink)
Member # 45755
I bought a 78' Ford HP44 empty with no outer knuckles. I am going to narrow it to 61.5" and run 5 on 5.5 bolt pattern. This axle will go under my TJ.
I am new to this so be gettle as I am in Kuwait missing my Jeep.
My questions (I have searched and did not get the questions answered):
1. I am looking at Crane knuckles and with these knuckles what will I need to complete them, i.e. spindles, rotors, hubs, etc.?
2. Do I narrow the long side only or both the long and short side to get 61.5"? I do not have the axle here to messure the length now so I have no idea how long it is.
3. I have a looked a couple websites on changing waggy axles to 5 on 5.5 but can I run older Ford 1/2 ton parts to complete the conversion? I would like to go to the parts store and get the parts I need for brakes, spindles, seals, bearings, etc.
4. If someone has done this swap recently let me know what parts you have used.
I am newbi to front axle and I am doing reseach but some of gets confusing on parts list.
Thanks. Let flaming begin.
Clean 80 CJ5 that I don't want to cut up!!!
jebdrup is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 09:39 AM   #2 (permalink)
sand dune coon's Avatar
Member # 57123
1. yes spindles (small bearing chevy off of a half ton) and 1979 or a similar year half ton ford rotor
2. There are a couple of ways to narrow this axle a lot of folks narrow each side so they can run waggy shafts.
3. I did everything chevy except the rotors.. calipers, backing plates (or caliper brakets) all from a chevy
4. read above ^^^^^^
sand dune coon is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 11:17 AM   #3 (permalink)
W_B
Member # 64758
I just bougth a 73' HP 44, and will doing the same shortly. my plan is to
go with the Chevy flatop knuckles, spindle and caliper brackets and then Ford hubs, rotors and bearings
W_B is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 07:27 PM   #4 (permalink)
Member # 11973
Here is a great site, has about all you need to know on 44s.
http://77cj.littlekeylime.com/web_rs44.html
Don't spend money on the Cranes, just get the Chevy outers, small bearing spindles and Chevy stub shafts. That is what I did on my 76 HP 44.
Murfman is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 07:40 PM   #5 (permalink)
Member # 53265
that's a great site Murf.
getting ready to put a HP44 (79 I think) into my YJ. its 3/4 ton (3inch diameter tubes) but has half ton outers. I'm planning on cutting the axle down to accept waggy inners. for knuckles, I'm going with deadenbear stuff. that way I can reuse everything else I already have.
TELLICO RALLY POST #264
admar2 is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 07:54 PM   #6 (permalink)
Member # 21488
FYI:he said its a f250 hp 44 they have leafs not coils.
fgallo is offline   Reply With Quote Quick reply to this message
Old 11-23-2006, 04:11 AM   #7 (permalink)
Member # 45755
Thanks for the replies. I have looked through the "Mr. N" site and there is good info but not specific info. I like the Crane knuckles because the have the key system for high steer arms. I am going high steer right now but in the future I would like the option.
If I understand the info correct I need either Chevy or Ford spindles depending on the knuckles (weather 5 or 6 bolts) and I can go Ford 1/2 ton everything else.
The inner axles will be based on the length I cut the tubes too and the inners are either Chevy or Ford based on the spindles?
The Big question is what years do ask the parts guy for when buying the everthing minus inner, outer shafts, and the warn hubs?
Old 11-23-2006, 04:55 AM   #8 (permalink)
W_B
Member # 64758
go here
http://77cj.littlekeylime.com/flatop_knucles.html
.. about half way down the page he has a "Knuckle out Section" there it list the different bolt patterns and what you need for each one including the year..
Old 11-23-2006, 05:21 AM   #9 (permalink)
Member # 45755
I did some more research and it looks like I can run waggy shafts (inner and outer) with Chevy small bearing spindles. It looks like Crane uses 6 bolt knuckles (Chevy) so it looks like I am going to mix parts for a 5 on 5.5 bolt pattern.
Old 11-23-2006, 07:03 PM   #10 (permalink)
W_B
Member # 64758
what about the large bearing Spindles can they be used?
Old 11-24-2006, 03:33 AM   #11 (permalink)
Member # 45755
According to a couple website on this conversion you have to use the small bearing spindles. I might be wrong.
Old 11-25-2006, 10:18 AM   #12 (permalink)
W_B
Member # 64758
found out today that you can machine the rotors out to accept the larger bearing on the Chevy spindle, I think I'll go that route
Old 11-25-2006, 10:43 AM   #13 (permalink)
Member # 37184
That last post confused me. I thought the purpose of using the small bearing spindles is so that you can use the Ford 5 on 5.5 HUBs. These hubs wont fit the large bearing spindles, because the the larger bearing wont fit into them. Machining the rotors would have nothing to do with that. I have heard of people machining large bearing spindles to fit the smaller bearings. Personally, I'd just get the correct, small bearing spindles.
Bubba_Jeep is offline   Reply With Quote Quick reply to this message
Old 11-25-2006, 01:48 PM   #14 (permalink)
W_B
Member # 64758
you can machine the Ford hub to accept the large Chevy bearing. that way you get your 5 on 5.5 but you also get the benifits of the larger bearing aswell
Old 11-26-2006, 05:36 AM   #15 (permalink)
Member # 45755
What are some other websites that talk about this conversion?
Old 11-28-2006, 10:15 PM   #16 (permalink)
Member # 45755
Can I use the parts of a 80+ Front Dana TTB?
Old 11-29-2006, 06:56 PM   #17 (permalink)
Member # 57123
if anything maybe the rotors and im not even sure of that..
Old 11-29-2006, 07:08 PM   #18 (permalink)
Member # 69441
Spindles/hubs/etc will swap.
Lj stretched Dana 80s 47s coilovers 5.8 aodw 203 205
99grandtj is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 12:57 AM   #19 (permalink)
AGRESIVE's Avatar
Member # 19322
Send a message via MSN to AGRESIVE
One of the better threads I have seen on narrowing a HP44 and should answer most of your questions.
http://72.41.91.149/forum/showthread.php?t=2805
"No good deed goes unpunished..."
AGRESIVE is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 10:49 PM   #20 (permalink)
Member # 45755
I now have all the answers to narrowing an axle what hubs and knuckles to use but what about steering issues with the track bar? Can anybody shed light on this subject?
Old 12-01-2006, 08:00 AM   #21 (permalink)
Member # 72977
you know what , you should just give the axle to me.
I think a little more specificity is needed on the second question about steering, but in general, you'll want to set up your track bar to have the same or as close to the same angle as your drag link. The results of not doing so will be severe bump steer and a jeep that drives like a 2 yr old child... it doesn't want to follow direction ...
you should be able to find more info on those websites also .... good luck
Rockhugger is offline   Reply With Quote Quick reply to this message
Old 12-01-2006, 10:24 PM   #22 (permalink)
Member # 45755
Own the steering question. Does the tierod rub on the trackbar? Does the trackbar mount get in the way? Thanks for the replies. I spend a lot of time searching for the answer and a lot the time I find info on YJs but I have TJ.
Old 12-02-2006, 09:21 AM   #23 (permalink)
Member # 37184
I'd say track bar/tie-rod interference depends on the type of frame bracket, axle mount, track bar, differential bridge, and steering set-up (high or normal), etc. My experience comes from a build I just completed. '79 HP D44 into an XJ. On full compression, driver's side track bar mount(home built RE heavy duty style) hits the UCA bridge (an RE bride). The drop is stock. The tie rod barely clears the bolt going through the frame-side track bar (I have Parts Mike high steer arms) at full left steering. On the passenger side, the track bar hits the oil pan. The track bar is a straight piece mounted above the axle tube and parallel to the tie rod. Additionally, the engine is a Chevy V8. The answere? More bump stops and possibly put a bend in the track bar. Oh, and my Jeep's lifted 6.5 inches.
Old 12-02-2006, 09:14 PM   #24 (permalink)
W_B
Member # 64758
I can't wait to tackle mine when the it's time (sense the sarcasism)..
I was planning on pushing the axle ahead 1-2" if possible in my TJ.. I've heard that using High Steer can cause some issuse.. If there's to many clearence issuse I'll just run the cross over setup up
Old 12-06-2006, 04:00 PM   #25 (permalink)
W_B
Member # 64758
I was tlaking to a buddy of mine.. turns out he used D-side axle shafts from an EB and Waggy shafts for the passenger side.. he only had to cut the long side and cut about 3/4" of spline off the outter EB shaft..
only thing that I can see being a problem with this is that you wouldn't beable to adjust your caster unless you cut off your D-side C. and the pumpkin woul dbe abit more towards the P-side, resulting in an offset front D-shaft..
