1946 flatfender build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-05-2006, 07:33 AM   #1 (permalink)
Member # 16901
Send a message via AIM to jeepfreak81 Send a message via Yahoo to jeepfreak81
This build thread is a bit lacking as I did not do a good job of updating it. There is another more detailed build thread out on the web (GL4x4) though if something isn't here.
I think I finally have my build plan so it's a good time to post....
day I picked it up
that mixed with a
triangulated 4 link rear on Stock TJ springs to follow once the rig is running and moving. [scrapped this idea for simplicity]
SOA front [scrapped due to no need]
2" lift
Buick 225 V6
T-86 or t-14 (for now as I have them) [changed to a T98 and Warn OD]
D18
saggy swap
pizza cutters (34x9.5 TSL)
winch
possible PTO (if I can find one)
3.73 gears, Offset 44 rear [welded], D30 front
Eventually a set of Autometers
The jeep will have a military arctic hardtop off a M38 as well. [destroyed wheeling, now has a top from a MB]
Plans for a locker in the front.
CJ5 frame... Not a crawler as we dont have that in MI, more of a very cabable all around rig
getting closer :rock:
This should help get it moving along faster :naughty:
Wow this thing is already taller then expected... the front and rear are both SUA and those are a true 32" tire... chassis had an SUA lift on it hmmm.
So much for a solid Tub... The hat channels were rotted out... so I removed it all....
Sadly I thought it was worth saving when I bought it as it was very solid, but I found many brazed panals with 1/4" of bondo over them. Then the hat channels were rotten, so I took them off and it was punky where the wood is in contact with steel...
The vertical step I think is also going to eventually need to be changed/reinforced. It is mostly there but there are bad spots.
The tub is getting fixed/reinforced with 1" C-channel and The floors will be diamond plate. The tub is going on a 66 CJ5 with 34x9.5 TSLs and will be smoothed and painted slate grey with Navy markings, going for the used look
It will be a around town toy/ mild trail wheeler just to have some fun in, smiles per mile. when I saw the tub was rotten I figured fun is better then accuracy
I just HATE cutting on this 60 year old steel, every time I remove a piece I feel like I am removing history
Test fiting the tub with the new hat channels/measuring for body mounts for the 2A tub to go on the 66 CJ5 frame
headers clear the passenger side, but NOT the drivers side for some reason, going to have to do some 'adjusting' with heat and a sledge I think...
We also installed the floors in the CJ2A with 99grandTJ (my buddy Adam), he also started dismantling my D18 t-cases to install the twin sticks on the proper case. (the one that has them is smoked it is safe to say)
also started cutting out the bad stuff, found out someone must have whacked the spare tire on something as the passenger side was pretty bad under the bondo I found.
1994 Wrangler -- 6.0 Chevy, 700R4, D44, D60, 37's
1946 CJ2A -- 225V6, T98, D18 & 34's
jeepfreak81 is offline   Reply With Quote Quick reply to this message
Old 12-05-2006, 07:33 AM   #2 (permalink)
Member # 16901
yes it is diamond plate, and still needs some final trimming/welding underneath, but the rear floor fit perfect Also need to weld the new hat channels in, changing the locations of them to allow mating to the 66 CJ5 frame easily
Going faster then anticipated, hoping to mount the tub and fire the motor before Christmas
Good chance the bottom will be painted and the tub mounted soon
Old 12-05-2006, 07:34 AM   #3 (permalink)
Member # 16901
Here are the latest after 12 more hours labor today, body is FINALLY mounted and tightened for the last time, everything is undercoated and the body work/prepping to fire the motor can begin
If you look close it even has a 1" boatside (chuckles)
SO far off to a good start, anxious to see how the end combo will perform suspension wise when I get to that point. Welding to 61 year old sheetmetal has been fun... good think I have the aid of a friend on it when it gets past my skill level
Old 05-17-2011, 11:37 AM   #4 (permalink)
pushrod249's Avatar
Member # 182166
nice
nice start. keep the pics coming
nothing wrong with extra strong
pushrod249 is offline   Reply With Quote Quick reply to this message
Old 05-17-2011, 01:07 PM   #5 (permalink)
lethaljeep's Avatar
Member # 190687
Originally Posted by pushrod249 View Post
nice start. Keep the pics coming
x 2
lethaljeep is offline   Reply With Quote Quick reply to this message
Old 05-17-2011, 01:16 PM   #6 (permalink)
sammyg's Avatar
Member # 98177
It's done and it's been done... He wheels the piss snot out of it and loves it. Runs 34's on it now and makes me jealous. Lol.
sammyg is offline   Reply With Quote Quick reply to this message
Old 05-17-2011, 04:45 PM   #7 (permalink)
Rooney77's Avatar
Member # 82435
Talk about resurrecting an old thread.
diesel willys build
51 Ford
81 Cherokee
Rooney77 is offline   Reply With Quote Quick reply to this message
Old 02-11-2013, 11:02 PM   #8 (permalink)
Member # 16901
I probably should update this some day... considering it is now undergoing build V3 since this post. I forgot all about it...
Some of the reasons for build V3:
Just scored $1000 worth of drivetrain on CL for $325 after a tip from a friend
T98/D18/Warn OD I can keep my 3.73 axles for wheeling now! 6.72:1 first and an OD!
I also went snow wheeling again at Snofari 2013
I have done this run for over 5 years without issue... this year all hell broke loose on me.
It started with backing into a ledge/stump
The day was going well and then....
A low tree combined with my heavy foot ripped the (hard to find) hardtop almost clean off, springing the door open. I got stopped and started sliding backwards on the ice and the door swung wide open on me causing me to "Tommy Boy" the door, crack the windshield, and dent/bend the passenger fender.
The funny part was someone said my exact words were "I got this!" as I broke out a cordless sawz-all. I was then asked who in the world carries a sawz-all.
Video of it happening, and the repair When I hit the tree the front wheels came off the ground.
Snofari 2013, Crunching to cutting on the Willys. No frills video - YouTube
Old 02-11-2013, 11:02 PM   #9 (permalink)
Member # 16901
Wheeled some more
and then my electric fan failed
So we did a redneck cooling fix
the fender, the picture doesn't show it well, but it is bent downward and the tub is bent
Culminating in the So-Broke award
Old 02-11-2013, 11:07 PM   #10 (permalink)
Member # 16901
So the night I got it back home:
My buddy took over from here while I was out of town
Old 02-11-2013, 11:07 PM   #11 (permalink)
Member # 16901
Test fitting
Old 02-11-2013, 11:10 PM   #12 (permalink)
Member # 16901
Well, My rear driveshaft was >< that close to breaking. Adam noticed it is twisted like a pretzel, just not broken when he was measuring it to see if I would need to shorten it.
Clutch Dynamics wants to look at my pressure plate and stuff, they think they can make me the clutch disk I need for about $100. They seem VERY knowledgeable and are genuinely nice people on the phone. They asked that I bring my old parts over, and what I have and they can get me something that will work.
Trans mocked into place with all the levers...
More showed up today:
I picked this up Saturday, he was a great guy, really took care of me when I had a trailer break down.
I'm going to try not to bang this one up. I am still confused how on every one of these tops I have looked at the door latches are broken and mangled beyond operating.
Old 02-13-2013, 12:06 PM   #13 (permalink)
Member # 96278
Damn. Cool. Jeep.
You, sir, get it.
Drink to the dead all you still alive
We shall join them in good time
cj5.5 is offline   Reply With Quote Quick reply to this message
Old 02-14-2013, 08:09 PM   #14 (permalink)
Member # 16901
Originally Posted by cj5.5 View Post
Damn. Cool. Jeep.
You, sir, get it.
Thanks!
Small update from my buddy that was tinkering while I was out of town...
"I Think we will have to mod the upper bracket slightly but the column fits nice then fix the floor with the patch template I made using steel of coarse "
The brake pedal return spring is not hooked up so the pedal is down a little
Steering pictures (These are from Build V1 that i never posted)
Old 02-14-2013, 08:48 PM   #15 (permalink)
Member # 229506
Awsome jeep. I had a 48 and screwed it up trying to build it up too much, ran out of money and had to pretty much give it away. If I had it to do over again I would build it just like yours. Live and learn I guess, as someone else said, you definately get it.
svhinspection is offline   Reply With Quote Quick reply to this message
Old 02-17-2013, 06:58 PM   #16 (permalink)
Member # 16901
I love Craigslist... With a receiver mount, cheap. Front and rear winches anyone?
Old 02-24-2013, 04:49 PM   #17 (permalink)
Member # 16901
Old 03-02-2013, 10:29 AM   #18 (permalink)
Member # 80328
I really like the look and patina on the Jeep. The vintage plate just makes it even better.
What length did you go with on the new column? I assume it is from Speedway.
Script GPW project in progress.
b4wscrambler is offline   Reply With Quote Quick reply to this message
Old 03-02-2013, 02:19 PM   #19 (permalink)
Member # 16901
Yeah the column was a 30" black column from Speedway for $100.
The law states I can use that plate for club events
It's not my fault most club events happen to be wheeling trips
Old 03-02-2013, 09:33 PM   #20 (permalink)
Member # 156517
Cool Jeep nice build
Billy_Bottle_Caps is offline   Reply With Quote Quick reply to this message
Old 04-28-2013, 09:12 PM   #21 (permalink)
Member # 16901
we got the radiator mounts in, we just have do do some tweaking as the lower part of the radiator tank is damn close to the fan.
Clutch is done... thought I posted it, I guess not.
Old 04-29-2013, 04:50 AM   #22 (permalink)
Member # 66452
Send a message via AIM to jeep795
Hey I got a 46' too. Early column shifter with tool indents. What the number on yours? You keep finding these real colorful parts for that thing. The body on yours was pretty much mangled. did you have a frame and it was just shot? or did you want to upgrade to something stouter?
jeep795 is offline   Reply With Quote Quick reply to this message
Old 04-29-2013, 09:29 AM   #23 (permalink)
Member # 16901
Wow that's a rare early one.
I don't recall the number on mine, but to be honest with the mismatch of the parts I did have, I don't know that the tag went with the tub.
The frame I had was good, but I got a good deal on the CJ5 frame with the V6 in it, and I knew I would want the added power. Since the tub was absolutely shot I did not mind cutting modifying it to make it fit the CJ5 frame, which was not that hard. The CJ5 frame is quite a bit stouter than the 2A frame.
Old 07-08-2013, 02:52 PM   #24 (permalink)
Member # 82354
Love this old rig.... Cant wait to see more of it! Thanks for sharing.
MCMAIN0121 is offline   Reply With Quote Quick reply to this message
Old 07-09-2013, 04:32 AM   #25 (permalink)
Member # 206486
Thanks for sharing. Great Jeep. Glad you brought it back.
GoldenSahara00 is offline   Reply With Quote Quick reply to this message
