Low ridin TJ's - Page 35 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-16-2015, 10:36 PM   #851 (permalink)
CORNFED's Avatar
Member # 2557
Finally got to roll this outside today. 14" Kings front tri lowers, 16" Kings rear tri uppers. 111" WB full hydro steering, ls1.
Team Tetanus Racing
68 Chev 4400 Blazer buggy
CORNFED is offline   Reply With Quote Quick reply to this message
Old 10-17-2015, 04:48 PM   #852 (permalink)
Member # 7624
Send a message via AIM to offroadman83
Originally Posted by ZUBE2000:30901202
I'll play. 2.5" coils, 1.25" BL, 37s, 100" wb.
Whos fenders/flares are those...love this!
2000 tj with stuff
offroadman83 is offline   Reply With Quote Quick reply to this message
Old 10-17-2015, 04:58 PM   #853 (permalink)
over's tj's Avatar
Member # 107256
That thing is looking good but how the hell did you get 16"KINGS in the back and not have the top of them sticking way up high?
FFR-FAB-'NEVERENDING BUILD' TJ, 4.0L, AW-4, Atlas,113"wb, hp60/14b, ARBs, 40s
over's tj is offline   Reply With Quote Quick reply to this message
Old 10-17-2015, 05:37 PM   #854 (permalink)
Member # 83301
Pretty gay, his other ride is some ricer import. Though he gets a win for towrig....
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 10-19-2015, 07:19 PM   #855 (permalink)
Member # 200867
Ok who could this be?? Haha! Hmmm...who do I know from Everett that goes wheelin'?
Trail 29, Rock Run, Patton, PA
Insanity, The Cove, Gore, VA
ZUBE2000 is offline   Reply With Quote Quick reply to this message
Old 10-19-2015, 07:24 PM   #856 (permalink)
Member # 200867
Genright fenders, flares, corner blanks
Flares and fenders already a bit beat since these photos. If you wheel in the rocks, get steel. I know this has been a topic of debate for years. But now having these fenders for 2+ years, I wish I wouldve went steel.
Old 10-27-2015, 10:11 PM   #857 (permalink)
CORNFED's Avatar
Member # 2557
I mounted them low on the axle so the top was flush with the top of the tub.
Team Tetanus Racing
Old 10-28-2015, 12:58 AM   #858 (permalink)
over's tj's Avatar
Member # 107256
Nice work fitting those. Like to see more of that build & maybe compare notes on suspension tuning.
Edit, think I see now why you were able to fit those lower, are they 2.0s...?
If so they're 2.4" shorter collapsed compared to my 2.5s.
Used some remains of upper mount/hoops from previous 16x2.5 air shocks but the 16" Kings needed completely new upper & lower mounts, it does use ever bit of available travel
And a Dune Buggy pic.
Old 10-28-2015, 08:04 AM   #859 (permalink)
Member # 579729
35" mtrs
23" front bumper, 23" legwetters, 18" to the t-case skid, 17" to the np465...
3" springs, 1.5" body lift, 5" up, 6ish" down.
Needs more lugs nuts and less rear bumper, when the money tree blooms.
gitcha sum is offline   Reply With Quote Quick reply to this message
Old 10-28-2015, 01:03 PM   #860 (permalink)
Member # 200867
WJ knuckle?
Old 10-28-2015, 01:05 PM   #861 (permalink)
Member # 200867
This thing looks nuts! I assume it is near completion? 40" Treps?
Old 10-28-2015, 01:27 PM   #862 (permalink)
Member # 579729
WJ knuckle?
Yes, not the best for low lift amounts.
Old 10-31-2015, 02:26 PM   #863 (permalink)
Member # 322985
Not the lowest of low-riding, but it's what I've got. 18" to belly pan and fuel tank, 21" to frame, 25" to the body, 74" to top of door surround. PSC Highlines/ AEV Hood, 37x12.5x15 Creepy Crawlers, 14" ORIs on all 4 corners. 103" wheel base.
beaureed445 is offline   Reply With Quote Quick reply to this message
Old 10-31-2015, 06:21 PM   #864 (permalink)
Member # 67470
Originally Posted by SMCRUZ13 View Post
19" to the belly
How much stretch front and rear?
Love this thing.
Mope is offline   Reply With Quote Quick reply to this message
Old 11-01-2015, 08:27 AM   #865 (permalink)
Member # 200867
Love this thing.
+1!
I want to move my front out some and get to 102-104" when the tons go under it.
Old 11-01-2015, 10:10 AM   #866 (permalink)
Member # 121042
Now that the build is finished, it's been a blast running trails this summer.
'05 TJ on tons, 14" ORI stx, long armed, hylined, 40" crawlers, HEMI/545RFE/ATLAS2 sitting at about 101", 22" to the frame rails, about 6" up, 8"down
'05 TJ, HEMI, Tons, ATLAS, ORI's, 40's, stretched, etc....
Fukk U cancer and CHD
jimmih is offline   Reply With Quote Quick reply to this message
Old 11-02-2015, 09:56 AM   #867 (permalink)
Member # 200867
^ Very clean! Looks like a good bit of that 101" WB is out front? Rear looks like ~4". Although it looks like the steering box is in the stock location and orientation. Can you give front/rear numbers?
Oh and what is the WMS of your axles??
Old 11-02-2015, 10:26 AM   #868 (permalink)
Member # 121042
Thanks !!
The rear is almost 5" back. I wanted to keep a rear fender flare for roadworthinessn as opposed to going comp cut.... Front is about 2.5". I pushed it out as far as i could with the stock steering box location/steering. The box itself was moved out a bit and rotated some but not allot. Frame had to be notched on the PS. On full stuff, the linkage just clears the rad/hoses and the upper CA just barely clears the oil filter on the HEMI.
Front is at 65" WMS. It's a snofighter that's been cut down with dutchman shafts.
Rear is a CC 14Bolt (63") with 1 1/4" spacers. Trails up here can be very narrow so as much as i wanted the wide stance look, it would have severely limited my trail abilities...
Old 11-02-2015, 11:16 AM   #869 (permalink)
Member # 127403
'98 TJ on D44's, highline with 2" of lift and 37's
Just rubbing my belly a little
[B]Rob[/B]
'98 TJ
'78 CJ5
'55 Willys P/U
DieselDent is offline   Reply With Quote Quick reply to this message
Old 11-05-2015, 08:26 PM   #870 (permalink)
Zi
Member # 203081
I think I know that rock at Rausch creek...
Zube2000s rig from post 855.
Zi is offline   Reply With Quote Quick reply to this message
Old 11-06-2015, 07:55 AM   #871 (permalink)
Member # 200867
No Rausch pix from me. My pix were from Rock Run and Gore.
Here is a pic at the entrance to Afflication at Rausch...
Old 11-06-2015, 12:43 PM   #872 (permalink)
Zi
Member # 203081
I think you misunderstood me. I know that pic is from Rausch because I took it. And just so everyone knows, you did not make it over that rock! Puny tires with no grip...
(Look at the two-trunked tree by the drivers side of the jeeps in both pics, you'll see its the same)
Old 11-08-2015, 06:06 AM   #873 (permalink)
Member # 200867
Lol. I made it over on 35s and stock wb. Got bellied up after the stretch.
That pic you posted wasn't displaying the other day. Hence the misunderstanding
Old 11-09-2015, 10:40 AM   #874 (permalink)
Member # 127403
lol yup, Kodak rock I think.
Nice rig by the way, how do you like the aluminum hardware.
[B]Rob[/B]
'98 TJ
'78 CJ5
'55 Willys P/U
Old 11-12-2015, 07:09 AM   #875 (permalink)
Member # 200867
Love the fact it does not rust and is light. Hate the fact my fender flares and rear flares are beat to crap already. If I knew then what I know now I wouldve done aluminum corners, aluminum inner fenders, and steel fenders and rear flares and painted it all orange. Aluminum and rock crawling don't mix. From a guy with aluminum for 2+ years.
