Low ridin TJ's - Page 39 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-25-2017, 11:59 AM   #951 (permalink)
Member # 73670
No need to notch the frame to be low. I have a 21.5" belly. 106" WB and 39" reds and 79" to top of cage.
Here is my 4 link.
image2 by Jeff Bell, on Flickr
image1 (4) by Jeff Bell, on Flickr
wrangler4x4_97 is offline   Reply With Quote Quick reply to this message
Old 10-26-2017, 04:22 PM   #952 (permalink)
Member # 343466
Here is my 4 link.
How much up travel do you have in the rear?
wvjeepguy81 is offline   Reply With Quote Quick reply to this message
Old 10-26-2017, 04:38 PM   #953 (permalink)
Member # 212988
you don't have a lot of separation at the frame end though
HankScorpi0 is offline   Reply With Quote Quick reply to this message
Old 10-26-2017, 08:48 PM   #954 (permalink)
Member # 73670
I have about 4.5" of up travel in the shocks. Will have 5-6" when I go to ORIs in the rear. The vertical separation at the frame works perfectly. When I originally designed the 4 link the uppers and lowers were equal lengths. When I put the doubler in I had to shorten the lowers and they are now 3 or 4" shorter than the uppers. Rig is super stable. Have ran this configuration for around 6 or 7 years now.
Old 10-27-2017, 01:36 AM   #955 (permalink)
Member # 343466
Are you running stock height coil springs in the rear?
Old 10-27-2017, 05:41 AM   #956 (permalink)
Member # 212988
I am sure it works fine. Mine isnt done yet but I am @ 20" to a flat belly sitting on 33" tires right now so i expect to be around 22-23" with 37's. Stock gas tank location 100" wheelbase. I did modify the front and rear frame portion though. 4" up in the rear 6" up travel in the front. just about 5.5" separation at the frame end
Old 10-29-2017, 07:07 PM   #957 (permalink)
over's tj's Avatar
Member # 107256
Way to many variables to say you don't need to cut into floor. Mine for example, I wanted lower links at frame to be above flat belly. Proper vertical separation meant cutting into floor, I even needed to notch the frame for lower Links.
FFR-FAB-'NEVERENDING BUILD' TJ, 4.0L, AW-4, Atlas,113"wb, hp60/14b, ARBs, 40s
over's tj is offline   Reply With Quote Quick reply to this message
Old 10-30-2017, 08:24 AM   #958 (permalink)
caryt's Avatar
Member # 27775
Just a question what is the top of axle to bottom of frame measurement of a stock TJ?
What are you guys thinking for a Low COG
caryt is offline   Reply With Quote Quick reply to this message
Old 10-30-2017, 07:40 PM   #959 (permalink)
Member # 117278
[QUOTE=caryt;42289146]Just a question what is the top of axle to bottom of frame measurement of a stock TJ?
What are you guys thinking for a Low COG[/
There is no magic number for low cog. It's all relative to region and type of wheeling. I liked boulder crawling. I kept my belly at 19" with 40's and 7" and 7" down travel. That's too low for mud, but I hate mud. It was too low a few other times and I turtles on big ledges, but it sure side hilled like a goat.
stan o is offline   Reply With Quote Quick reply to this message
Old 10-31-2017, 08:30 AM   #960 (permalink)
caryt's Avatar
Member # 27775
So what your axle to frame #?
Old 10-31-2017, 05:15 PM   #961 (permalink)
Member # 117278
Can't tell ya, #1, sold the rig. #2, I chopped the rear frame off and raised it probably 4 inches and used 2" tube, so those numbers wouldn't help u any.
Old 10-31-2017, 05:26 PM   #962 (permalink)
over's tj's Avatar
Member # 107256
Find stock one on a used car lot or something & take some measurements.
Not going to find a lot of stock TJ's around here
.. in the end when you're done with your build you'll probably realize getting these exact numbers really isn't necessary
Old 11-02-2017, 11:02 AM   #963 (permalink)
caryt's Avatar
Member # 27775
Just asking for a reference thats all...
Old 11-03-2017, 04:14 AM   #964 (permalink)
Member # 737849
We had to cut the floor out to get proper separation on the frame side. Running 4 up 12 down in the rear.
Rexy doesn't look low without front fenders.
Makers_Mark is offline   Reply With Quote Quick reply to this message
Old 01-30-2018, 04:34 PM   #965 (permalink)
SledgeHammer's Avatar
Member # 3104
What part of MD are you located?
if it ain`t broke, fix it till it is...
SledgeHammer is offline   Reply With Quote Quick reply to this message
Old 02-16-2018, 12:40 PM   #966 (permalink)
Member # 737849
Harford county.
Here is a picture of my TJ next to a friend's, whose running a 3" lift with 32's.
Old 02-16-2018, 01:35 PM   #967 (permalink)
Member # 225905
I'll throw some pictures of mine up.
Snow picture is final ride height.
Sent from my SM-G930T using Tapatalk
Mihlfeldl2005 is offline   Reply With Quote Quick reply to this message
Old 08-22-2018, 10:43 AM   #968 (permalink)
Member # 72851
Let's bring this one back from the dead. I'm about to put my Jeep under the knife again. In '08 I built a long arm for it and it was NOT a LCG build at all. In '16 I stretched/backhalved the rear and started focusing on a lower cg. Since I'm currently only running 37s I can't go too low because I'll drag my belly and/or link mounts on sharp breakovers/ledges....which I come across a lot.
Since I was tired of catching my long arms on these ledges I built the rear into more of a mid-length arm setup when I stretched it (99" now). That helped, but with my lower ride height I catch my lower link mounts too frequently. In the coming months I'll be converting the Jeep to a TJ-6 and want to address the rear suspension....again. Ideally I'd like to inboard or outboard the lower mounts for a smooth transition from belly to links.
I see some folks have achieved this and I'd love to see more pics of how you did it (preferably without heims as I daily this thing a lot). Most look to have bridged the gap between the chassis link mounts with steel plate and while this would provide a smooth transition, it also kills belly clearance so I'm hoping to avoid that option.
FYI, my chassis is currently at 19.5" (framerail to ground). Not what I'd call "LCG", especially since I need to raise it up a bit for more clearance. I'm also planning on going with a shorter rear arm (again) and will do the same up front when I re-do that end of the Jeep.
Here you can see my lower link mounts which catch everything:
Current ride height:
'01 Jeep Wrangler - not quite "hard core" junk
'19 Ram Rebel 1500 - tows the junk
'30 Model A
"HATER" - /ˈhādər/ A word used by someone with a limited vocabulary to describe a person with a different opinion.
Tommy R is offline   Reply With Quote Quick reply to this message
Old 08-22-2018, 11:31 AM   #969 (permalink)
Member # 212988
You are catching the lower rear link mounts on the frame side? Your jeep looks exactly like my current ride height on 37's. Did you mount the rear of the gas tank skid to the bumper? im digging the current look. why shorten the rear arm stretch?
Old 08-22-2018, 12:25 PM   #970 (permalink)
Member # 72851
Yeah, catching the lower link mounts on the frame pretty frequently. Right now I'm on the long end of the "mid-arm" spectrum and am thinking a shorter arm would be okay if my geometry doesn't get much worse. But I'd prefer to keep the arm length and mount the brackets up higher. The wheelbase won't get shorter, though.
Yeah, the gas tank (Gen Right) bolts directly to the Undercover Fab backhalf kit after a lot of work. Here's a pic in process:
Here's a better pic:
'30 Model A
Old 08-22-2018, 12:59 PM   #971 (permalink)
Member # 212988
Running a 14bolt? Any idea how far you have the pinion up and how your driveshaft length? I think mine is going to be 19" on a 100" wheelbase
Old 08-22-2018, 01:07 PM   #972 (permalink)
Member # 121042
Your mount points don't look THAT bad..... Maybe you just need larger tires !!!
For comparo, here's mine on 40's. I'm 23" to the frame rails, which puts you actually lower taking into account the tire size difference.
https://drive.google.com/file/d/1o6T...ew?usp=sharing
'05 TJ, HEMI, Tons, ATLAS, ORI's, 40's, stretched, etc....
Fukk U cancer and CHD
jimmih is offline   Reply With Quote Quick reply to this message
Old 08-22-2018, 02:13 PM   #973 (permalink)
Member # 72851
Nope, just a Dana 44. I have a Sterling 10.5" waiting to go in sometime next year.
Yes, I definitely need bigger tires, but not until I get bigger axles installed. But regardless, I think the benefit of running a lower link mount that's higher up will be a big win in for belly clearance!
'30 Model A
Old 08-28-2018, 09:58 AM   #974 (permalink)
Member # 212988
Not a TJ but 21" to the frame rail
Old 02-05-2019, 07:01 AM   #975 (permalink)
Member # 853772
My TJ before the LJ Stretch. 73 6 of uptravel
littlecrawler 51 is offline   Reply With Quote Quick reply to this message
