Comp Cut Questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-16-2007, 05:25 PM   #1 (permalink)
Member # 84074
Comp Cut Questions
I plan on compcutting and flat fendering my YJ this weekend, is there any write ups on this? Can anyone post up some pics so I can see how I want mine to look. Also for you guys, what did you do with the filler for the fuel tank? I really want to stay away from a fuel cell because I need the back seat for the little jeepers.
This is my Jeep with the 9inch rear and 38X12.50-15 installed the front axle is on the ground and I jacked up the front levle so i could set the rear pinion angle. stats on my jeep are SOA stock yj springs with 2inch BL..
Angler1979 is offline   Reply With Quote Quick reply to this message
Old 01-16-2007, 05:55 PM   #2 (permalink)
Member # 67642
without a fuel cell, you can't move the axle back enough to really get enough out of a comp cut. you might want to look into BTF or another fuel cell thatmounts in the stock location, but gives you more space for a stretch. look for TombRaider, i think his is a YJ, might be wrong...
Don't correct me when I misspell Cabernet Sauvignon. I'm drinking it from a box. You missed your chance to help a long time ago.
Phantom1016 is offline   Reply With Quote Quick reply to this message
Old 01-16-2007, 05:57 PM   #3 (permalink)
Member # 77602
My yj with compcut, no front tube fender yet. U can get a fuel cell that will fit behind the rear seat. Blue torch has a fuel cell that mounts under the jeep where the stock tank is located that will allow u to move the axle back
6"
Blue1TonYJ is offline   Reply With Quote Quick reply to this message
Old 01-16-2007, 10:41 PM   #4 (permalink)
chadburgin's Avatar
Member # 18196
im sure someone still makes a fuel cell that will go behind the backseat. i agree with the above that if you are ready to do a comp cut you need to move the tank. the filler neck will odviously be cut out... buy a star and search. there is a sea of info and all that you will ever need right here on this board...
chadburgin is offline   Reply With Quote Quick reply to this message
