JJ upper bushings and radius arms - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-19-2007, 06:05 AM   #1 (permalink)
Member # 69818
Send a message via AIM to tommaho
Anyone have any problems running radius style arms with JJs instead of rubber bushings in the upper mounts?
I'm considering running Claytons with the bushing kit from Currie, but I dunno if the JJs will take away so much deflection it'll cause / hasten breakage. They use rubber on the axle end of the lowers, but is that enough?
Seems like I could lose some articulation and risk tearing off axle brackets.
Any experience or comments?
tommaho is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 11:44 AM   #2 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
If you have a clayton's style front setup, with an upper control arm coming off of the lower to control pinion angle... and you have this setup on both sides... you will want rubber bushings.
Clayton's setup binds under flex. Those rubber/poly joints that come with claytons original setup allow for the bind without breaking parts. When you get rid of those soft joints, something else has to take the brunt of the bind
You could run a JJ in the upper if you only ran 1 upper control arm and that would completelly eliminate the binding problem.
Nordic1 is offline   Reply With Quote Quick reply to this message
