Newb Locking Hub question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-20-2007, 06:27 PM   #1 (permalink)
Member # 85478
Send a message via AIM to Nemesiszx2 Send a message via MSN to Nemesiszx2 Send a message via Yahoo to Nemesiszx2
Could anyone expalin to me why you run locking hubs. Do you have to run them to be locked in the front? Do you have to install them on older axles? Or is it un necessary on a new axle? I guess I just don't get why you need them. Be gentle I am trying to learn. Thanks guys
Nemesiszx2 is offline   Reply With Quote Quick reply to this message
Old 01-20-2007, 07:39 PM   #2 (permalink)
Member # 67642
when you lock your hub, it "connects" your axles to your tires, which turns your axles and driveshaft with the tire, which wears on parts. With you hubs not locked, when you're tires spin, that's all they do, so your U Joints don't see any wear on them. Other axles have vaccum disconnects which picks and chooses when to engage, or flanges, which is fully engaged 24-7.
They're not necessary, but if you have bad pinion angles in the front, or just like to save U Joints, they're nice. they can be a bit pricey and are a weak link on bigger axles. HTH
Don't correct me when I misspell Cabernet Sauvignon. I'm drinking it from a box. You missed your chance to help a long time ago.
Phantom1016 is offline   Reply With Quote Quick reply to this message
Old 01-20-2007, 09:05 PM   #3 (permalink)
Member # 85478
A locker locks the innershafts of an axle together then and the Locking hub locks the wheel to the outer shafts. But if you don't have the hubs are you truly locked if you are running a locker?
Old 01-20-2007, 09:26 PM   #4 (permalink)
Member # 82394
Yes,& you can't UNlock & if for any reason you have to drive on the street in frontwheeldrive w/o hub lockouts or vac disco, you'll wish you weren't locked in your diff. I hope that makes sense.
BerzerCO is offline   Reply With Quote Quick reply to this message
