whats my crawl ratio - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-25-2007, 08:29 PM   #1 (permalink)
Member # 83642
I seen some threads about this in the hardcore tech forum and i was wanting to know what mine were. The TJ has 3.73 stock gears in the axles and 1st is a 3.93:1 not sure what tcase gears are. Any help is appreaciated
TJsahara is offline   Reply With Quote Quick reply to this message
Old 01-25-2007, 08:34 PM   #2 (permalink)
Banned
4Mogger's Avatar
Member # 33748
Go here and find out:http://www.4lo.com/calc/gearratio.htm
4Mogger is offline   Reply With Quote Quick reply to this message
Old 01-25-2007, 08:44 PM   #3 (permalink)
Banned
4Mogger's Avatar
Member # 33748
Looks like 38.41:1 but I am not sure what transfer case you have.
Old 01-25-2007, 08:44 PM   #4 (permalink)
MudOnTheTireS10's Avatar
Member # 41474
Send a message via AIM to MudOnTheTireS10
www.GrimmJeeper.com/gears is a good resource also. Post up what you get when you calculate your crawl ratio.
'97 S10: D44+Aussie/9"+Detroit | AMSOIL Dealer | <><
MudOnTheTireS10 is offline   Reply With Quote Quick reply to this message
Old 01-26-2007, 01:46 PM   #5 (permalink)
Member # 63791
231 t-case has a 2.72:1
so its 3.93x2.72x3.73 = 39.87
hi
yellowredlight is offline   Reply With Quote Quick reply to this message
Old 01-26-2007, 03:18 PM   #6 (permalink)
Member # 49539
Send a message via MSN to BCYJ
An ax5 has a first gear ratio of 3.93....
An ax15 like in his sahara, has 3.83 first gear.
as stated above, the 231 has 2.72 low range ratio...
Transmission first gear(3.83) X T Case low range(2.72) X Axle ratio (3.73)
= 38.85 to 1. Which is decent if your running a 205/65R14, its crap if your running anything bigger than 31's.
Crawl ratio is NOT a bragging number though. your rig on 30" Stock GSA's would have a forward momentum of 2.52 feet a second at 750 Rpm(Crawl ratio of 38:1). Yet if you built your rig with the same tranny and t case, had D60's packed with 4.56's and running on 38" tires, would have a crawl ratio of 48:1 and still move at 2.61 Feet/sec.
So you built a wicked rig on D60's, with a 48:1 crawl ratio it must be better than a stock TJ, the crawl ratio is better!!
But your stock TJ was actually slower than this built rig. Crawl ratio is only a usefull number when matching gearing choices with tire size.
3.93X2.72X4.88 = 52:1 on 33's = 2.07 feet/sec
4cyl YJ 33/12.5 BGF AT K/O's, RE4.5ED, AR 767's, Boomerangs, DT Shocks, What Swaybar? AA HD SYE,8.8/LS and 4.88's, HPD30 4.88's, 1750 KG's with all my junk.
BCYJ is offline   Reply With Quote Quick reply to this message
Old 01-26-2007, 04:07 PM   #7 (permalink)
Member # 83642
yea im runnin 33's right now and its a lil hard workin the clutch when ur tryin to go up somethin pretty steep. Thanks guys
