tranny options for the 2.5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-27-2007, 06:47 PM   #1 (permalink)
CAVE's Avatar
Member # 30681
I am planning on puting together a buggy with my old yj's 2.5L. I was wondering what tranny options are out there. I don't mean the stock options, I want to know what adapters are made. I was thinking about a turbo 350, but couldn't find anyone that made an adapter. I tried to look up some info on AAs site, but couldn't really find anything. What are my options and where do I go for more info?
CAVE is offline   Reply With Quote Quick reply to this message
Old 01-27-2007, 11:40 PM   #2 (permalink)
Member # 291
2.5 had an auto opt. it was a 904 you should be able to get one from a tj or a yj i will have a 21 spline out put witch limits your t case opt.
In The Rear With The Gear...
84scrambler is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 04:17 AM   #3 (permalink)
Member # 85983
If you're interested, you can go with a SM465 or SM 420. I've contacted http://novak-adapt.com/ when I was researching this for myself. It's not a cheap option, and the t-case input shaft has to be changed, but that's the easy part.
willness is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 07:01 PM   #4 (permalink)
CAVE's Avatar
Member # 30681
If novak makes an adapter for a sm420/65, then wouldn't it be a close swap for a th350/400? I didn't see either on their site though. Just for the bigger amc engines and 4.0. Isn't the 2.5 a different bell housing than the 4.0? Has anyone put other than stock trannys behind their 2.5? I do like the sm420 option though. Thanks for the heads up willness. One other question, those of you that may have autos behind your 4banger... is it hell or will a deep set of case gears or axles make up for it enough to be responsive offroad? I would like to stay auto for the build to keep my wife interested, but if it isn't going to get the job done then I'll have to go with a 4spd. I realize I'm not going to have "power", I just want to know if I can make it "quick" with the right gears and not go so low that I never get above 40mph. Thanks for the input.
Old 01-28-2007, 09:00 PM   #5 (permalink)
Member # 65935
I'm not sure about automatic upgrades. But you can use a nv3550 or ax15 behind the 2.5L using a 96-98 dodge dakota 2.5L bellhousing and a specific camaro clutch and a few other random parts. There was a good thread on this site somewhere awhile ago, but i can't search (i guess b/c i'm a newb ). I have a 5spd so i havn't looked much into auto set-ups Depending on how big you are looking at going, the poor little 2.5L isn't going to have enough power to get you to highway speeds.
pickupman387 is offline   Reply With Quote Quick reply to this message
Old 01-29-2007, 03:35 AM   #6 (permalink)
Member # 85983
That thread is here:https://www.pirate4x4.com/forum/showthread.php?t=181361
Old 01-29-2007, 03:37 AM   #7 (permalink)
Member # 85983
Just shoot Novak an E-mail with your concerns. They'll be more than willing to help you out.
Old 01-29-2007, 05:06 AM   #8 (permalink)
WyoJeeper's Avatar
Member # 1040
Use a 700R4 from a 2.8L V6 Blazer. Has the same bolt pattern.
WyoJeeper is offline   Reply With Quote Quick reply to this message
Old 01-29-2007, 08:21 PM   #9 (permalink)
CAVE's Avatar
Member # 30681
yes
700R4, now we are talking. I don't know why I didn't think of that. Is that a computer controlled tranny? A np231 should bolt to that too right? Thanks for the info.
Old 01-29-2007, 08:32 PM   #10 (permalink)
Member # 30537
The 2.5 will be a turd on power behind any auto, especially the 700R4. The factory 904 auto is really the best option if you have to have an auto.
John Cappa is offline   Reply With Quote Quick reply to this message
Old 01-30-2007, 12:43 PM   #11 (permalink)
kingmick217's Avatar
Member # 44327
Send a message via MSN to kingmick217
The 2.5l 4cyl and the 2.8l v6 had the same 60* gm bolt pattern, I know that my buddy here at work has a 2.8l v6 in his Izusu trooper with an auto behind it. I haven't been able to identify the tranny yet, but the Izusu Boards might have some input aswell.
Oh you sir. You are definitely fired.
kingmick217 is offline   Reply With Quote Quick reply to this message
