'79 Ford 44 front SOA swap into YJ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-28-2007, 10:21 AM   #1 (permalink)
Member # 85487
Got the axle. Got the springs over it and the Jeep set back down...and now I have a question.
I need to bolt the 2.5" wide YJ spring to the new axle tubes. I need the bottom plate that the u-bolts bolt to (under the axles). Is there a kit for this? I also need the plate on the top of the spring.
Where is the search function?
stroked250 is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 10:26 AM   #2 (permalink)
88YJSOA's Avatar
Member # 66409
you need to buy something here to search, when i did my SOA i used the idea from the early jeeps and welded a large bolt to the plate for the shock mount....
88YJSOA is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 10:36 AM   #3 (permalink)
Member # 85487
Not really looking for the shock mount now. On the axle I am swapping in, I cannot use the standard U-bolt since the driver side spring perch sits partially on the pumpkin. The bottom of the axle uses has a piece that you need to clamp to the axle to hold the square u-bolts in. This piece goes around the pumpkin.
Old 01-29-2007, 12:30 AM   #4 (permalink)
Member # 11973
take an angle grinder and cut notches into the pumpkin. You want to add about some spring plate to the side of the pumpkin and weld that on, then move the centering hole about a 1/2".
http://www.4x4wire.com/jeep/tech/axle/yjrcdana44/
http://77cj.littlekeylime.com/Dana44_2.htm
Murfman is offline   Reply With Quote Quick reply to this message
Old 01-29-2007, 08:07 AM   #5 (permalink)
Member # 85487
Check out picture 17 in your second link. That is the plate on the bottom of the axle that I need custom I believe. I thought about notching the pumpkin like you said only to use a round ubolt inverted. I was hoping that someone made that piece I can just get for the bottom of the axle and will work with the 2.5" wide YJ spring.
I'd eventually do a lont term fix. I just need to get this thing rolling asap.
Old 01-30-2007, 12:22 AM   #6 (permalink)
Member # 11973
It only takes between 30 and 45 minutes of grinding to get it to work. YOu can have the Ubolt made, just take the top spring plate in for the exact width.
Old 01-30-2007, 08:08 AM   #7 (permalink)
Member # 85487
That's what I am thinking about doing. I wasn't too sure about grinding there since that provides strength to the housing.
Old 01-30-2007, 09:05 AM   #8 (permalink)
Member # 39371
Send a message via AIM to currupt4130
Mine's ground out, it's fine. The axle tubes are so damn thick it ain't gonna bother it.
The mountains are calling and I must go.
-John Muir
currupt4130 is offline   Reply With Quote Quick reply to this message
Old 01-30-2007, 09:21 AM   #9 (permalink)
Member # 85487
I'll give it a try, thanks for the help.
Old 01-30-2007, 11:14 AM   #10 (permalink)
jtr
jtr's Avatar
Member # 41068
Not a 44 but it came with the same plates your axle did...my waggy ubolts worked with a add a leaf too.
1990 Ford Ranger on boxed full size frame, FI393W, C6, 203/205, KP60, 14 bolt, 4 link rear, 39.5 PB, H1s, full hydro
jtr is offline   Reply With Quote Quick reply to this message
Old 01-30-2007, 12:25 PM   #11 (permalink)
Member # 85487
Great picture, thanks! What did you use for a top plate? The factory plate wont be wide enough for my new axle tube.
Old 01-30-2007, 12:56 PM   #12 (permalink)
jtr
jtr's Avatar
Member # 41068
Factory wagoneer plate, I ground the axle until it did work. Wasn't much, a little off the front, a little off the back. You can see the shiney part where I ground it on the back side. .......grinder is your
Old 01-30-2007, 02:01 PM   #13 (permalink)
Member # 85487
I am thinking about grinding the bottom only where the U of the bolt goes. I'll get a wider u-bolt then to go around the larger diameter part of the pumpkin. I think I'll need a custom plate made for the top though that has one side of the u bolt holes farther apart than the other side.
Old 02-01-2007, 12:17 AM   #14 (permalink)
Member # 11973
I used plates off a Blazer.
