8.8 dif skid plate - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-23-2008, 11:56 AM   #1 (permalink)
Member # 108168
8.8 dif skid plate
ive done a search and found nothing.. i just whant to see what some you have done about the anchor on the 8.8.
poodog is offline   Reply With Quote Quick reply to this message
Old 04-23-2008, 02:29 PM   #2 (permalink)
Member # 44027
I built one out of 1/4 scrap plate I had around ... nothing fancy but does the job. There are a few things I'd change on it (ie: ubolts facing some other way other than down .... extend front to help protect flange).
4.0L, 42RE, 242, HP30 (Lockright)/8.8 (mini-spool), 4.11
Skids (Engine, Oil, T-Case, Gas, FLCA), LP-1 sliders
Rusty's hooks, Class III Hitch
RE 4.5" SuperFlex, JKS disco's, RE Monotube, Adj Trackbars
TrXus 33x12.5-15, RC's 15X8 3.75"BS
CB, Hi-Lift, Tube Doors
mawardjr is offline   Reply With Quote Quick reply to this message
Old 04-23-2008, 09:48 PM   #3 (permalink)
Member # 108168
hmmmm have any problems with those u bolts hitting rocks.. how about that cover it looks like it hanging lower?
Old 04-26-2008, 06:17 AM   #4 (permalink)
Member # 44027
I cut all of the bolts off just below the nuts and so far I haven't had any issues with them getting caught on stuff. If I was to redo it though I change the mounting so that the ubolts where horizontal instead of vertical - or box in the lower section to protect the bolts.
Cover is 1/4" thick so I've lost that much clearance under the pumpkin. It is sitting flat against the bottom of the pumkin. I'll take that clearance loss over having the lip exposed and no protection for the diff cover.
Old 04-26-2008, 06:51 AM   #5 (permalink)
Member # 3511
Aftermarket thick diff cover and weld some steel to the bottom of the diff to ramp the lip in the back.
Chuck P
A man can do all things if he will
oldjeep is offline   Reply With Quote Quick reply to this message
Old 04-26-2008, 09:03 PM   #6 (permalink)
Member # 108168
nice.. good thinking
