Tj gauge cluster problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-31-2008, 10:22 PM   #1 (permalink)
Member # 56232
I have 1998 tj 4.0 auto and out if the blue my whole gauge cluster quit working everything all the fuses and relays are good as far as I can tell I just thought maybe I was missing something simple.
xjfan1974 is offline   Reply With Quote Quick reply to this message
Old 05-31-2008, 10:25 PM   #2 (permalink)
Member # 36286
hit it
camoTJ is offline   Reply With Quote Quick reply to this message
Old 05-31-2008, 10:32 PM   #3 (permalink)
Member # 56232
Tried that several times
Old 05-31-2008, 10:51 PM   #4 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
Check connections on back, check for bad ground.
Travis Waldher is offline   Reply With Quote Quick reply to this message
Old 05-31-2008, 11:06 PM   #5 (permalink)
Jorge Meza's Avatar
Member # 70340
This is a common failiure on all 97-99 TJ's. The two connectors on the back need to be checked since they commonly get "loosey".
4 Sale:
* 79 Ford Dana 60 Front Axle
* AX-15 REBUILT
WTB:
* LSX/6L80 complete takeout
* Complete DE Hydro steering system
* Millermatic Multiprocess or 255 MIG
* Tuffy Overhead Console
Jorge Meza is offline   Reply With Quote Quick reply to this message
Old 06-01-2008, 01:34 AM   #6 (permalink)
Member # 73413
does the radio and heater work? I know alot of chrysler products have problems with ignition switches. You turn the key on, and the vehicle will run, but no signal gets sent to the interior stuff to turn on, so the gauges, radio, and heater all are still off. Just a thought
Bansheestu is offline   Reply With Quote Quick reply to this message
Old 06-01-2008, 01:42 AM   #7 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
If it turns out to be a bad cluster, I have one from my '98 TJ 4.0 that you can have.
Azzy2000 is offline   Reply With Quote Quick reply to this message
Old 06-01-2008, 05:00 AM   #8 (permalink)
Member # 83256
Send a message via MSN to Stonecoast Send a message via Yahoo to Stonecoast Send a message via Skype™ to Stonecoast
A girlfriend had the same problem in her 98 TJ, it was a problem in the wiring harness. she drove it for a couple months wacking the dash every time it acted up but eventually had to have it done by the stealership. They said it was a common problem too and I didn't get any info on what it cost or if it was just the connector or the actual wiring. She didn't ask me to look at it.
Pogo Stick with the bell and tassels
Stonecoast is offline   Reply With Quote Quick reply to this message
Old 06-01-2008, 06:51 AM   #9 (permalink)
xjay1999's Avatar
Member # 108247
Just had this problem on my 99' XJ,the seatbelt,airbag,turnsignal and highbeam lights and dashlights worked but no gauges or odometer or tripmeter.Checked the kickpanel fuse panel and the fuse was o.k.Pulled cluster and cleaned contacts indash and on cluster and still didn't help.Put the idiotlight cluster back in and the idiotlights all worked but still no odometer or tripmeter..I giveup and figured It was going to have the connectors in the dash replaced by the stealership per service bulletin for the late model XJ and TJ's.Took it in and all it was was a 15 amp fuse in the box under the hood,that is unmarked as to what it is for.Small blue fuse middle of the box on the engine side.Check that out, it cost me $28 to find that one out.
xjay1999 is offline   Reply With Quote Quick reply to this message
Old 06-01-2008, 07:23 AM   #10 (permalink)
ItsaCJ6's Avatar
Member # 6340
And to think I thought this thread might have some sick new custom gauge cluster worthy of the forum......
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 06-01-2008, 09:53 AM   #11 (permalink)
GaryTJ's Avatar
Member # 36995
I have fixed lots of them. What you are looking for is the pins on the board loose the solder connection and pop up about .015", losing contact.
pull the cluster and the board. Look closely at the pins where the wiring attaches. You will probably find one, or two that are loose. Push them back down and resolder them and you are good to go.
Life is not about a pretty body, it is about sliding in at the end, all used up and worn out, going "Man, what a ride!"
GaryTJ
GaryTJ is offline   Reply With Quote Quick reply to this message
Old 06-29-2008, 06:12 PM   #12 (permalink)
Member # 63126
Send a message via MSN to jeepsport
Just had the same problem and that was the cause, that god damn little 15 amp fuse. Only cost me a coffee to fix it though lol.
jeepsport is offline   Reply With Quote Quick reply to this message
Old 06-16-2016, 11:42 PM   #13 (permalink)
Member # 683201
2000 jeep tj problem
sorry for replying as a post but i'm new and don't know how to make a new post. i have a 2000 jeep tj 4.0 MT. today out of nowhere the gauge cluster stopped working all the lights work but the gauges do not move and as soon as this happens the radio wont turn on and the dome light stopped working but the heater still works and the a/c still works the jeep also still runs fine i checked all fuses under the hood and behind the glove box with a multi meter all are fine i checked the ground wires under the hood and in the dash all are fine i checked the volts in the wires going to the dome light they have no power as well as no power to the radio i also checked the pins in the cluster connectors all are tight i'm thinking maybe ignition switch but before i do anything else i want to ask for some help. any reply is helpful thanks
nick-tj is offline   Reply With Quote Quick reply to this message
Old 06-17-2016, 08:59 PM   #14 (permalink)
dzntzhellfire's Avatar
Member # 49185
Send a message via AIM to dzntzhellfire Send a message via Yahoo to dzntzhellfire
Same here. Then I scrolled through looking for the standard Pirate answers. Apparently even hardcore section is now gone soft.
Lifted & cut up TJ,
06 Cummins QCLB 6spd 4x4
dzntzhellfire is offline   Reply With Quote Quick reply to this message
Old 07-31-2016, 10:19 AM   #15 (permalink)
Newbie
Mauiview's Avatar
Member # 357018
Send a message via Skype™ to Mauiview
Nick-TJ, I have the same exact problem. Did you find a solution yet?
Christine - 99 TJ 42in IROKS, TR Beadlocks, PSC Full Hydro, RCI Fuel Cell, 108 WB, Artech trusses
Crush 2013 JKU 35in Nitto, Rugged Ridge 17x9, Poison Spyder Customs Bumpers, Rockers
and
Mauiview is offline   Reply With Quote Quick reply to this message
Old 07-31-2016, 10:36 AM   #16 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
Pretty funny considering all the posts you were reading happen to be 8 years old.
TRAIL WORTHY FAB
| 316.337.5311
Old 07-31-2016, 08:03 PM   #17 (permalink)
Newbie
Mauiview's Avatar
Member # 357018
So since dnztzhellfire and you feel this isn't high tech, and given I have tried search strings of TJ gauges, TJ gauge problems, TJ gauges not working, TJ gauges radio, and a dozen other combinations with little luck. Is there a more efficient way to search forum history than hoping the site search box (or google) returns a relevant result?
How bout copping a guy a break and helping out. I have checked gauge connections, grouds, and I have no fuse problems.
Thanks!
and
Old 07-31-2016, 08:10 PM   #18 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
Thanks!
I'm making fun of him because he says "pirate went soft" when this thread is 8 years old.
TRAIL WORTHY FAB
| 316.337.5311
Old 08-01-2016, 02:50 PM   #19 (permalink)
Moderator
geberhard's Avatar
Member # 5861
mooved
geberhard is offline   Reply With Quote Quick reply to this message
Old 09-12-2016, 08:34 PM   #20 (permalink)
Member # 191442
I worked as a dealer tech for 18 years, from 1990-2008. Dieing clusters is a common problem as stated earlier in this old thread.
The Dealership fix was in the form of a TSB (technical service bulletin). The repair was to remove the cluster, scrape off the black corrosion you will find on the contacts of the pins,c lean them with contact cleaner, then replace a connector with an updated one with more bite on the pins. Not sure of the TSB number or the part number of the repair connector. Maybe the dealership will help look up the TSB and get you a new connector, if they are still available. A loose pin on the cluster circuit with a bad solder joint would certainly have the same effect.
What happens is the cluster loses it's communication with the engine controller, which supplies all the data for the cluster gauges. Same basic cluster in XJ's and TJ's, they both will have the problem. If you have a good scan tool that can read the cluster, you will find communications error code stored in it.
If other things like the dome lights, turn signal indicators and other accessories also stop running, then look to the fuse issue talked about earlier.
Hope this helps!
Marty, SoCal is offline   Reply With Quote Quick reply to this message
