76 cj backfires and smoking - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-01-2009, 01:54 PM   #1 (permalink)
blue cordcj7's Avatar
Member # 124954
i have a 76 cj7 with a 304 in it. when i shift gears it backfires and when it revs up pretty hi it starts poping and backfiring. it also has a greyish whitish smoke coming out of the drivers side tail pipe. i have advanced the timing and adjusted the carb and neither seem to change a thing. i also pulled the plugs the looked all right had a slight bit of oil on the tip but not really burnt up or antthing. i think it might be the valves but i really hope not. any ideas or help would be great. i also dont think that the smoke is coolant but not really sure. thanks alot.
blue cordcj7 is offline   Reply With Quote Quick reply to this message
Old 06-01-2009, 03:31 PM   #2 (permalink)
Member # 128317
do a compression test. come back with the numbers
baldfatdad is offline   Reply With Quote Quick reply to this message
Old 06-01-2009, 03:33 PM   #3 (permalink)
angrychairmen's Avatar
Member # 96586
vacuum test?
wreck wheel wrench repeat.
angrychairmen is offline   Reply With Quote Quick reply to this message
Old 06-01-2009, 04:52 PM   #4 (permalink)
Member # 133720
Gray white smoke… coolant in the cylinder normally compression like stated above, check coolant level maybe pull the spark plugs and presser test the radiator for leakage
Rubicon Rock Heads
rubicontrailpatrol.org
foxeod is offline   Reply With Quote Quick reply to this message
