Hi steer question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-10-2009, 02:42 AM   #1 (permalink)
Member # 132078
Hi steer question
I am getting ready to do a high steer setup on my dana 30 in my 86 cj7. Have been looking around at all the kits out there but was just wondering what everyone thinks is the best one to go with? I have also heard about doing the dana 44 knuckle swap and using a high steer for it but would like to keep the dana 30 the way it is since it is already built up. I know that it mite be hard to do but i am trying to do this on a budget also.
Thanks,
Ben
86YJ7 is offline   Reply With Quote Quick reply to this message
Old 06-10-2009, 08:22 AM   #2 (permalink)
Member # 133720
If you have a welder it would be cheaper to get some D.O.M. and weld in some ends and build your own its fairly easy there are several threads on this, and if you donít have a welder it would still be cheaper if you took all the cut pieces to a shop and the welded the ends in
Rubicon Rock Heads
rubicontrailpatrol.org
foxeod is offline   Reply With Quote Quick reply to this message
Old 06-10-2009, 08:57 AM   #3 (permalink)
CJ4U2NV's Avatar
Member # 32034
look into a tie rod flip kit. ok4wd.com sells them.
CJ4U2NV is offline   Reply With Quote Quick reply to this message
Old 06-10-2009, 09:22 AM   #4 (permalink)
Member # 18320
You can use chevy or waggy knuckles on you CJ D30. You will have to run the chevy brakes, & '78 CJ thick rotors . Your spindle will bolt right up to the chevy knukcles so you can run your hubs/ lockouts/ outers as well.
elarsen is offline   Reply With Quote Quick reply to this message
