looking for pics of cj7 soa rear strectched on 35s - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-11-2009, 05:53 AM   #1 (permalink)
Member # 61946
ive got a cj7 im thinking of stretching the rear 4-6 inches going soa and running 35s. just looking for some pics of others that may have done it. im worried that it may look a little silly. Some people may saw why 35s. Well bc i think its as tall as I can go and it still fit in the garage.
oakridgecj is offline   Reply With Quote Quick reply to this message
Old 06-11-2009, 07:12 AM   #2 (permalink)
Member # 85098
then why do soa? keep it sua, trim the fenders more and run 35's with a lower cog
ruecifur is offline   Reply With Quote Quick reply to this message
Old 06-11-2009, 07:15 AM   #3 (permalink)
Member # 61946
yeah thinking about that too, but was liking the idea of strecthing the whell base a little and getting the articulation of the soa.
Old 06-11-2009, 07:30 AM   #4 (permalink)
Member # 85098
i just did a sua xj spring swap on my yj. don't have pics but it flexes nicely
Old 06-11-2009, 07:41 AM   #5 (permalink)
Member # 11892
Mine is not exacly what you are look for but it was stretched 2" in the rear and 1" in the front. Sorry, not a great side pic but the best i have.
natehall is offline   Reply With Quote Quick reply to this message
Old 06-11-2009, 07:44 AM   #6 (permalink)
Member # 127762
does the xj springs use the stock mounts on a yj? am looking to get a lil more wheelbase.
crownsey54 is offline   Reply With Quote Quick reply to this message
Old 06-11-2009, 11:51 AM   #7 (permalink)
Member # 85098
i used the stock spring hanger in the front. Cut out the stock rear x-member and welded in box steel. Then welded rough stuff way back hangers to that. it was pretty simple
Old 06-11-2009, 01:57 PM   #8 (permalink)
Member # 127762
Do you have any pictures i can look at?
Old 06-11-2009, 04:00 PM   #9 (permalink)
Member # 85098
i'll try to take some tomorrow
Old 06-11-2009, 04:41 PM   #10 (permalink)
Member # 122427
how much lift do the xj springs give you?
iv been thinking about doing this
91YJRockCrawler is offline   Reply With Quote Quick reply to this message
Old 06-11-2009, 04:45 PM   #11 (permalink)
Member # 85098
not sure as my stock springs were pretty shot. I've only done the rear but plan on doing waggy springs sua in the front, and i'm thinking that should put it level. I'd say about 2-3" of lift from the swap, but i'm using a xj bastard pack.
Old 06-11-2009, 05:11 PM   #12 (permalink)
Member # 122427
thanks... im running RE 2.5" lift right now so i should be good
Old 06-11-2009, 06:32 PM   #13 (permalink)
Member # 85098
I chopped up the fenders pretty good so even sua i could fit 37s pretty easy. I also have a 1" body lift. I'll get pics tomorrow if its not raining
Old 06-11-2009, 09:27 PM   #14 (permalink)
Member # 65332
I did Ruff Stuff's way back hangers and welded them onto 1/4" plate.
I did this for 2 reasons: I don't have a welder at my house and less work when 4-link goes in.
I have 325's on, which measure a true 35".
Up front is RE's 1.5 SOA.
I have not wheeled this set-up up yet, but from all the research I did it will work fine with a "slip and twist" or similar wrap bar on.
http://www.4x4trailhunters.com/my4x4...id=392&vid=141
fishotro is offline   Reply With Quote Quick reply to this message
Old 06-12-2009, 06:09 PM   #15 (permalink)
Member # 85098
heres some pics of my yj. Stock front susp, xj strech rear kept sua. It has 33x10.5s right now, Need to trim a bit more in the rear but 35's will be no problem. Front still needs to be done, it's a work in progress:
