help me identify my cj5 broken tranny, got more info now... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-12-2009, 09:19 AM   #1 (permalink)
Member # 67732
i have an 81 cj5, 6 cyl 4 spd. trying to figure out what tranny i need to get to replace my cracked in half one....
heres the info i got..
it has the shifter handle thats bent, not a straight handle. ford stamped on the tranny case, borg warner stamped on teh shifter plate.
dana c300-15-2 transfer case, steel case. thats the dana 300 right?
the tranny, you have to press down for reverse, its a 4 speed
Ford rf-d9zr-7222-aa
13-32-097-902
13-32-065-905
10 spline front shaft and the rear shaft is like 23 or so splines.
[COLOR="Red"][CENTER]THIS SPACE FOR RENT, INQUIRE WITHIN[/CENTER][/COLOR]
[QUOTE=jettscott;14783350]That guy can go fuck himself with whatever power tools he has left.[/QUOTE]
[color=red][SIZE="3"][b]For the best deal on 8 lug disc brakes click here-->
[/SIZE][/b][/color]
Honky Lips is offline   Reply With Quote Quick reply to this message
Old 06-12-2009, 10:24 AM   #2 (permalink)
Member # 67732
due to this page, i have come to the compclusion that it is the jeep sr4 transmission...
am i correct?
http://www.novak-adapt.com/knowledge/sr4.htm
[/SIZE][/b][/color]
Old 06-12-2009, 12:40 PM   #3 (permalink)
Member # 32187
13-32-097-902
13-32-065-905
Well if that's the numbers you have on the case, yep I would say it's an SR4.
Like the article says, it's not that desireable, it's a car tranny in a Jeep. Get out your wallet for some upgrades unless your just using it as a commuter.
If your just going to put another SR4 back in (easiest) it should be a cheap fix, (no demand for the SR4)
Good luck
GoldToyBox is offline   Reply With Quote Quick reply to this message
Old 06-12-2009, 12:47 PM   #4 (permalink)
Member # 67732
it is just gonna be a d.d. for now. something to putt around town with no top on. i have my blazer that i wheel and my girl has a tj on 35's to wheel. so an sr4 tranny is all i want then.
[/SIZE][/b][/color]
Old 06-25-2009, 10:50 AM   #5 (permalink)
ddestruel's Avatar
Member # 20999
at least seek out a t-176. the SR4 should never have come behind anything except a 4cyl
I AM ONE OF MANY WHOM WASHINGTON HAS CHOSEN TO IGNORE OR FORGET
But i Vote
GO UM Montana Griz
"Jeep Lurker"
KEEP REMEMBERING 9/11
Jeep with Rambler motor, SUA,
and some
I miss my
Support Frank the Tank
ddestruel is offline   Reply With Quote Quick reply to this message
Old 06-25-2009, 02:17 PM   #6 (permalink)
Member # 102207
Yes it is an SR4. Look here. . . http://jeeptech.com/trans/t4.html
85cj7 is offline   Reply With Quote Quick reply to this message
Old 06-25-2009, 07:59 PM   #7 (permalink)
Member # 114256
A T4 or T5 will bolt right in as a replacement, they are the same length as that turd. Neither is a great trans but both are much, much better than the SR4.
no_bs is offline   Reply With Quote Quick reply to this message
Old 06-26-2009, 08:04 AM   #8 (permalink)
Member # 46937
Don't waste your time with the T4/T5. Look for at the minimum a T176.
________
Live sex
atblis is offline   Reply With Quote Quick reply to this message
