vibration/shaking under power only - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-16-2009, 05:57 PM   #1 (permalink)
Member # 116329
my jeep has developed a terrible shake when under power, it continues through all gears. if i press the clutch in it smoothes out immediatley. so, clutch, tranny, mounts etc... where should i start first, what is my most likely problem?
mondols1 is offline   Reply With Quote Quick reply to this message
Old 06-16-2009, 07:46 PM   #2 (permalink)
onewhitezj's Avatar
Member # 45304
bad u-joint? Could possibly be a bad mount, letting the driveline angles get out of whack I guess...but I would think that would just get you a noticible clunk when you first start moving in gear and not a continous vibration...
Professional thread killer since 2005
onewhitezj is offline   Reply With Quote Quick reply to this message
Old 06-16-2009, 07:51 PM   #3 (permalink)
Member # 83773
Originally Posted by onewhitezj View Post
bad u-joint?
^This is where I'd start too...replace the front and rear u-joints in the driveshafts...actually just take the front driveshaft out and see if it still does it, that way you'll know which one is causing the trouble.
"Sometimes you eat the bar, sometimes the bar eats you"
mapes is offline   Reply With Quote Quick reply to this message
Old 06-16-2009, 10:05 PM   #4 (permalink)
Member # 133720
Would have to agree with above I just went threw this not to long ago
Rubicon Rock Heads
rubicontrailpatrol.org
foxeod is offline   Reply With Quote Quick reply to this message
Old 06-21-2009, 06:31 PM   #5 (permalink)
Member # 116329
yall were right. i have a tom woods double cardan drive shaft in the rear and one of my gold seal u-joint caps was completley gone, the metal under the cap was whittled down to a point almost. the problem is that there is also some damage from metal to metal contact on the knuckel were the two u-joints fit in the double cardan. i think this might be covered by the tom woods warranty when one of their u-joints goes out. i'll call them tomarrow to find out.
Old 06-21-2009, 06:46 PM   #6 (permalink)
Member # 99513
If you destroyed a u-joint in the CV assembly, something is seriously wrong! I've been running the same 1310 Tom Woods CV system in my rear D-shaft with zero issues in the past 9 years! Its still tight the day I got it. Im only tearing out the u-joint at the rear axle which is normal. But tearing out a joint in the CV system And Im packing some serious torque in my drivetrain. something is wrong. Better check your drivetrain angles and all your mounts. Even the motor mounts. A bad motor mount can cause drivetrain to go 3 sheets to the wind.
Swapping Front ends:
Motorcycle stuff.
[SIZE="5"][COLOR="Red"][B]NEW BEGINNINGS:[/B][/COLOR][/SIZE]
jpfrk2001 is offline   Reply With Quote Quick reply to this message
Old 06-22-2009, 09:14 AM   #7 (permalink)
Member # 116329
ive had that cv in for a little over 5 yrs, its a dd and never had a problem till now. i will check my drive angles today but i dont think theres anyting wrong, but i'll check anyway, thanks.
Old 06-22-2009, 11:34 AM   #8 (permalink)
Member # 43534
Tear it apart and inspect the centering ball also...fair chance it's gotten boogered up with that much damage.
Fyathyrio is offline   Reply With Quote Quick reply to this message
Old 06-22-2009, 08:56 PM   #9 (permalink)
Member # 116329
thanks
