valves clicking - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-21-2009, 03:56 PM   #1 (permalink)
Member # 77789
valves clicking
I have a 04 Tj 4.0 with about 65K the valves are ticking slightly, I was going to pull the valve cover off in the next few days is their anything i should look for?
xxxjeep jake is offline   Reply With Quote Quick reply to this message
Old 06-21-2009, 07:17 PM   #2 (permalink)
Member # 96130
Solution - get used to what a Jeep engine sounds like.
Corey Kruchkowski, [COLOR="DarkOrange"]TEAM TNT motorsports - car 780/car 781[/COLOR]
[COLOR="Lime"]Pitbull Tires [/COLOR]
[COLOR="Red"]ROARK SUPPLY
[/COLOR]
[COLOR="DeepSkyBlue"]Bilstein Shock Absorbers [/COLOR]
[COLOR="Gray"]Rugged Race Radios[/COLOR]
[COLOR="Orange"]Gear Center Group
[/COLOR]
YJ_and_Corey is offline   Reply With Quote Quick reply to this message
Old 06-21-2009, 09:02 PM   #3 (permalink)
Member # 77789
yeah I know what it sounds like and now it sounds different, thanks for the help.
Old 08-01-2009, 12:23 PM   #4 (permalink)
Member # 80641
ya go pick up a chiltons manual or something comparable, you might be able to find the information you need on the internet.
What you need to look for is loose rocker bolts. The ticking noise you hear is probably caused by the rocker slapping on the valve or the rocker arm.
I helped my friend fix a tick in his 1994 chevy 2500 with a 350 and what we did is just pull the cover, start the motor, listen to it to figure out which one is ticking (putting your hand over one rocker at a time and listening for a change in sound helps), then we just slowly tightened it until there was no more ticking. Once there as no more ticking i think we did about another 1/8 turn or so.
not that hard of a fix just takes some time. good luck.
1986 M1009, 6.2 diesel w/turbo, tons, ARBs, 37s
offroadjunkie is offline   Reply With Quote Quick reply to this message
Old 08-01-2009, 09:24 PM   #5 (permalink)
Member # 129677
Since jeep lifters (4.2's and 4.0's specifically) are not adjustable like your friends chevy... it is a hell of alot easier. Take the valve cover off, and go down the row of lifters. I normally torque em to 30lbs with a drop of blue loctite on the em.
Clay
jeepman1320 is offline   Reply With Quote Quick reply to this message
