Offset question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-21-2009, 04:44 PM   #1 (permalink)
Member # 131425
Offset question
What is the best way to make 35s clear my leafs spacers or offset rims I have 33s with a 1/4 spacer and they just rub at lock but I want bigger tires any help would be appreciated.
cz858 is offline   Reply With Quote Quick reply to this message
Old 06-21-2009, 05:22 PM   #2 (permalink)
Member # 21592
Send a message via AIM to Mark Campbell
Inexspensive way: Adjust the steering stops.
Expensive way: different offset rims and wider flares, etc.
It will probably not require much change to the steering stops and you will not loose much turning radius. All you have to do it adjust enough so the tires do not rub. May be different amounts on each side. Just enough to keep contact away. Good thing to check/adjust anyway. Doesnt cost a thing!
99Tj, 4.5 RE, 1"body, 4:88's, lockrights, homebrew cage,WOR bumper, rocker/rear armor, 35's
Mark Campbell is offline   Reply With Quote Quick reply to this message
Old 06-21-2009, 07:48 PM   #3 (permalink)
Member # 131425
oh and sorry its a 91 yj. i will look at adjusting the stops any sorces would help im not always able to get alot of time with internet out of town alot
thanks sean
Old 06-22-2009, 05:05 AM   #4 (permalink)
Member # 21592
They are on the knuckles. You will see them from the front near the bottom. They look like bolts sticking out and facing the middle of the jeep. What I would do first is spray them with some PB Blast or similar (rust breaking spray) and let them soak for a day or two. Just to make sure they don't snap off like all old bolts that havent moved for a long time. Then just adjust them outwards untill it stops the contact of the tires on the springs.
Good luck
