Yj stretch brackets - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-05-2011, 05:34 PM   #1 (permalink)
Brandon Rhoads's Avatar
Member # 89064
Yj stretch brackets
So Im looking at stretching my yj using cherokee springs and I know BT makes a kit. But.... I wanna fab my own rear bumper and mounts for the springs. What tabs/parts did you use and where did you get them from? Yes I searched and found some info but limited. Thanks for the help or any advice
Work in progress- 88 YJ 60/14 sbc,TH400, D300, spring over and stretched some
Brandon Rhoads is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 05:50 PM   #2 (permalink)
Member # 96466
really nothing nothing at all. Page 2 stretching my YJ
Making racesuits for racer that make you go faster.
JaysinDesignz is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 06:03 PM   #3 (permalink)
Member # 89064
Yup I actually read that and got some tips. Im def on a learning curve with the leaf springs. I seen ruffstuff has tabs so i'll have to call them up and see what they have to say to use.
Old 07-06-2011, 08:36 AM   #4 (permalink)
Cumminshunter's Avatar
Member # 192169
I'm looking at this too... Cheapest way I've seen to stretch wheelbase.
I also got a link to copperheadfab.com where the parts are $20 (minus bumper, but with summit bushings). Also enter "Pirate" in coupon code area for 8% off...
I'm probably going to end up making my own spring pack using the ones I've got and used xj's... I'm also considering moving the front (of the rear) shackle hangers back as well...
93 YJ Build: Search "Black & Tan 2 Black & Blue" in Non-Hardcore...
Cumminshunter is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 12:01 AM   #5 (permalink)
Member # 112838
Ok ill play. xj springs on a YJ are ease to do. Take 4"x3/16 flat stock shape it like the stock cross member, weld or bolt it on ( I would weld) get some shackel hangers from Dan at ruffstuff, move your tank, trim your finders, mount the shocks, new brake lines and a driveline and your done. its really just that easy. oh and you're going to want a traction bar of some kind with the XJ springs. good luck
dirtbikeboy54 is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 09:42 AM   #6 (permalink)
Member # 186901
I'm assuming it is going to be spring over?? What if you just relocated your stock springs back (bracket). I've been looking into doing this. You gain 6" with the XJ springs. That will give you 99 inch WB. I found some 1.5" YJ springs for spring over, I'm going to move my brackets back and go for 10" total.
94YJ, 40z, linked rear, tons, and stretched to 109"
CreepinYJ is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 10:02 AM   #7 (permalink)
Member # 89064
yeah I am doing a spring over.. Its gonna be a nice gain for sure. I am finding out more and more info on it and ways people do it. I am trying to do a build with buying as little as possible. I see some guys use a bar to prevent axel wrap and some don't. Whats the pro's and con's in using one? As of now I plan to build one but just curious.
Old 07-07-2011, 10:16 AM   #8 (permalink)
Member # 192169
How are you going to deal with the fact that the frame arches up just rear of the front hanger?
I was thinking this would work too (and allow me to use the same springs I have now...) Blue Torch Fab offers the spring hangers (front of the rear set) so maybe it's possible to weld them part way up that arch.
Old 07-07-2011, 12:19 PM   #9 (permalink)
Member # 96466
no reason to relocate the YJ rear front mounts in an xj leaf stretch
if you do then you are moving the rear more the 5-6"
Old 07-07-2011, 01:07 PM   #10 (permalink)
Moderator
apeters89's Avatar
Member # 7647
Pro's - your pinion will no longer point at the back seat wen you press the gas pedal down. Wheel hop diminishes significantly.
Con's - you need to make sure your axle housing is securely mounted to the tubes. With the anti-wrap bar being on only one side you run the risk of spinning the tubes in the housing. I fixed that on mine by welding the housing to the tubes as well as adding a truss over the housing to connect both sides together.
Check out our new Team
Like us on
KF5EQF
apeters89 is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 01:29 PM   #11 (permalink)
Member # 186901
I was gona move the mount without using the XJ springs. The rear spring mount can easily be moved back 8", right before the arch. Looking at it, it looks like it is doable, but I haven't done it yet. Plus I know the Rubicon Express sells 1.5" YJ springs meant for springs overs, I don't want to mix and match springs, ya know!
Old 07-28-2011, 11:11 AM   #12 (permalink)
Member # 8867
Send a message via AIM to YJ4LIFE
i used modified rear cj7 spring hanger brackets. I was going to weld them to my rear crossmember but the stock one just looks too flimsy. I cut a window in the rear crossmember so I can get a wrench inside the frame to hold a washer and nut. There is already a welded nut inside the frame. I drilled an offset hole in the spring hanger to use that mounting point. I used 52" chevy springs that are not offset like XJ springs
'89 YJ, 4.2L, B&M shifter, '91 efi, '99 intake, 52" rear springs, 44044 front...
YJ4LIFE is offline   Reply With Quote Quick reply to this message
