Other than an Atlas... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-08-2011, 02:01 PM   #1 (permalink)
Cumminshunter's Avatar
Member # 192169
How are you guys getting better crawl ratios?
I've got 4.56's and am locked so I'd rather do it w/o changing axle gears.
Thanks.
93 YJ Build: Search "Black & Tan 2 Black & Blue" in Non-Hardcore...
Cumminshunter is offline   Reply With Quote Quick reply to this message
Old 07-08-2011, 02:02 PM   #2 (permalink)
MR. HOGG's Avatar
Member # 146572
Diff trans...
Under Drive....
Diffrent Non-Atlas Case w/ lower gears...
"Professional Driver on a Closed Course"
Rockwelled LS Buggy
JKU on 37's
RZR XP1K
RZR XP900
follow me on Instagram @ MR.HOGG
MR. HOGG is offline   Reply With Quote Quick reply to this message
Old 07-08-2011, 03:05 PM   #3 (permalink)
Member # 99513
crawl box maybe.
gear change set in t-case.
Swapping Front ends:
Motorcycle stuff.
[SIZE="5"][COLOR="Red"][B]NEW BEGINNINGS:[/B][/COLOR][/SIZE]
jpfrk2001 is offline   Reply With Quote Quick reply to this message
Old 07-08-2011, 04:07 PM   #4 (permalink)
howyadoin's Avatar
Member # 84132
4:1 kit if you're still running your stock YJ t-case.
Debating economics with Screwloose is like asking a homeless dude for stock advice.
howyadoin is offline   Reply With Quote Quick reply to this message
Old 07-09-2011, 07:14 AM   #5 (permalink)
Member # 5577
Older Chevy NV4500.
It's all here before your eyes / Safety is a big disguise / That hides among the other lies
Jakesteramalamajama is offline   Reply With Quote Quick reply to this message
Old 07-09-2011, 07:29 AM   #6 (permalink)
pcoplin's Avatar
Member # 17986
I swapped in an auto with my V8 swap and don't need crawl gears, and the tranny stays under 210 when crawling in the heat. WOrks for me.
98 TJ LQ4/TH400
FullStack MotorSports
pcoplin is offline   Reply With Quote Quick reply to this message
Old 07-09-2011, 10:56 AM   #7 (permalink)
Member # 87682
SM465 granny trany.
wranglerwilson is offline   Reply With Quote Quick reply to this message
Old 07-12-2011, 09:30 AM   #8 (permalink)
Member # 17632
T-18
Travis..
18 Ram 2500 4x4 Big C and a 6 speed
87 Blazer on 35"s
crashnzuk is offline   Reply With Quote Quick reply to this message
Old 07-12-2011, 07:06 PM   #9 (permalink)
smokinsilverrt's Avatar
Member # 56912
Send a message via AIM to smokinsilverrt
i installed a D&D machine 231/300 crawlbox in my buddies tj and it works great.only thing is hes still drivers drop and we had to drill out the trans holes to flup the 231 case and flip the 300 i wasnt a fan of that method.id only do that again if it was for a pass drop.theres bunches you can do to get lower gearing just gotta research what you want a doubler lets u get 7:1 or your regular low range.an atlas is bulletproof.tou can 4:1 your 231,you can adapt a d300 and 4:1 that
DeepWoods Extreme
Summit Crawlers
smokinsilverrt is offline   Reply With Quote Quick reply to this message
