4.0L engine noise - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-10-2011, 12:43 PM   #1 (permalink)
Member # 138334
4.0L engine noise
Have a 4.0L which I got in a cherokee out of a scrapyard, today I started it and is was working perfectly, after about 10 min on idle I revved it up to ~5000rpm and it started making this noise, even on idle you can hear it but as you rev up it it increases.
YouTube - ‪Weird jeep 4.0 "knock"‬‏
Dont know where to start looking for the problem so any help is very well welcome.
Thanks
James
jam3z is offline   Reply With Quote Quick reply to this message
Old 07-10-2011, 06:05 PM   #2 (permalink)
Member # 72257
Id start with the valvetrain. have you pulled the valve cover off yet? It sounds like a valve to me, could be a broken rocker, bent pushrod, fucked up lifter, or you screwed up a valve.
I drive the fastest barbecue on 4 wheels...
CJim7 is offline   Reply With Quote Quick reply to this message
Old 07-11-2011, 08:51 AM   #3 (permalink)
Member # 178200
It could also be a collapsed lifter.
SLOWPOKE693 is offline   Reply With Quote Quick reply to this message
Old 07-11-2011, 11:30 AM   #4 (permalink)
Member # 142024
it sounds like a wrist pin or a lower bearing knock to me...... drain the oil and see if there is any silver or gold flakes in the oil
SCRAPPY#1 is offline   Reply With Quote Quick reply to this message
Old 07-11-2011, 01:31 PM   #5 (permalink)
Bigburlynakedguy's Avatar
Member # 11961
5k rpm under no load? Not really good for a very long crank and flat tappet motor.
I'd also go valvetrain, lifter or rocker.
[QUOTE=MT4Runner;36844945]If you died tomorrow, are you ok with the life you've lived up until today?[/QUOTE]
Bigburlynakedguy is offline   Reply With Quote Quick reply to this message
Old 07-11-2011, 03:19 PM   #6 (permalink)
GFY Racing's Avatar
Member # 136091
Location: Back in the good 'ol U S of A after three long deployements!
Like others have said. Pull the valve cover and drain the oil.
Fighting for the right for SORRY PIECES OF SHIT to protest at soldier's funerals.
1989 XJ on 35s Work in Progress
GFY Racing is offline   Reply With Quote Quick reply to this message
Old 07-11-2011, 05:36 PM   #7 (permalink)
Member # 72257
Could be. But when my 401 decided to freeze up a wristpin, the sound was much deeper...sounded like a main or rod bearing. This sounds more at the top end to me
Do a compression test, wet and dry. Check for burning oil in your exhaust, pull plugs and look for fresh oil.......just pull the damn valve cover and start there
Old 07-11-2011, 09:49 PM   #8 (permalink)
Member # 138334
will do so after work, thanks for your help guys. Ill post up if I find something.
