700r4 to Jeep 4.0 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-15-2011, 12:56 PM   #1 (permalink)
Member # 27285
700r4 to Jeep 4.0
Has anybody done this swap, I see AA and Novak have an adapter for this. I would sure like to have a 700r4 rather than the 32rh 3 spd.
gary pierce is offline   Reply With Quote Quick reply to this message
Old 07-15-2011, 06:57 PM   #2 (permalink)
Member # 37769
Hey, Gary....Did you give "come get ya some" a call?
Willing to learn, try, fail, learn more, and try again.
cisco is offline   Reply With Quote Quick reply to this message
Old 07-16-2011, 07:00 AM   #3 (permalink)
Member # 191442
Depending on your driveline length, a stock Jeep AW-4 or 42RE would be a viable alternative to add an overdrive. In my experience, Adapted chevy transmissions sometimes have issues with the spacers for the torque converter loosening up, flexplates cracking and starter alignment/noise issues. It's also hard to get the converter's dust cover to seal properly.
Marty, SoCal is offline   Reply With Quote Quick reply to this message
Old 07-16-2011, 10:24 AM   #4 (permalink)
Member # 27285
Yes, they said they have not done this swap. I really would like the od, but might have to settle for the 32rh, and I think there are no drive shaft mods.
Old 07-16-2011, 10:26 AM   #5 (permalink)
Member # 27285
Thanks, Marty
Old 07-16-2011, 01:45 PM   #6 (permalink)
Member # 87845
Ive got a buddy who's been workin on this for a long ass time... mostly due to getting a new girlfriend in the meantime... he finally found the flex plate he needed on rock-auto after searching forever and a day.... but hes not made it far enough to tell you if is or aint gonna work! I'll shoot him a FB link to this thread for his feedback.
y2knole is offline   Reply With Quote Quick reply to this message
Old 07-16-2011, 08:42 PM   #7 (permalink)
Member # 37769
Thats incredible! I was in there just over a year ago and they told me they had mated a 700r4 to a 4.0. W/O adapters. Said it was tricking but could be done.
Or maybe at 40 yrs old I am showing the first signs of senility!
Old 07-16-2011, 09:51 PM   #8 (permalink)
Member # 4375
I don't know what year you're working on, but forget the 42RLE suggestion, that stupid thing has a TCU with more wires going into it than the ECM on a TJ does.
I just finished up a flat belly AW-4 swap into a TJ that originally had the 32RH. During the test drive, I was so happy with the way it performed and worked that before I had gone two blocks I was trying to find out how to acquire one for my wife's 01 TJ with a 32RH.
I will have a complete 32RH for sale before long if you can't convince yourself to do the AW-4.
Stupidity abhors a vacuum
mrblaine is offline   Reply With Quote Quick reply to this message
Old 07-17-2011, 05:43 AM   #9 (permalink)
Member # 27285
mrblaine
I've got a 98 TJ, RE 5.5 long arm, 1" BL, 4.0, so I guess if I want the OD I need to check out the AW4 swap. Did you have to modify both drive shafts, and was the wiring that bad?
Old 07-17-2011, 06:56 AM   #10 (permalink)
Member # 191442
Here's a good write up on swapping in a AW-4 to a TJ:
http://www.stu-offroad.com/engine/aw-4/aw-4-1.htm
The AW-4 swap will require driveline length mods, it's quite a bit longer than the 32RH. It's close in length to the AX-15 and NV3550.
Old 07-19-2011, 08:54 PM   #11 (permalink)
Member # 143020
I am in the middle of figuring out if I am replacing my busted AX-15 or going to a AW4.. Thoughts? Blaine- What did you love so much about it beside that 4th magic gear?
xplodn is offline   Reply With Quote Quick reply to this message
