upper link mount, will this work? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-15-2011, 05:56 PM   #1 (permalink)
Member # 168896
im building a 4 link on a YJ and i came up with this upper link mount it's 1 3/4 .120 wall, it will be guesseted (sp?) to the frame also. This is my 3rd attempt at trying to find a way to mount my uppers. the red lines are where i plan on placing tubes. just wondering if this will work before i weld everything in.
so what do you think will it work?
DualPurposeXJ is offline   Reply With Quote Quick reply to this message
Old 07-15-2011, 06:38 PM   #2 (permalink)
howyadoin's Avatar
Member # 84132
First of all, I'd consider .188 to be a bare minimum for a link bearing cross member personally. Second, what kind of vertical seperation have you designed into the front links to need your uppers mounted that high? Third, if anything failed there, you would truly redefine an enema.
Debating economics with Screwloose is like asking a homeless dude for stock advice.
howyadoin is offline   Reply With Quote Quick reply to this message
Old 07-15-2011, 06:58 PM   #3 (permalink)
Member # 168896
i can easily sleeve this with 1.5 .120 wall, my lowers are tucked up pretty high. Nothing hangs below the frame and i will have about 6-7" of vertical seperation on the frame end and 9" on the axle end
Old 07-15-2011, 07:49 PM   #4 (permalink)
Member # 149566
Ouch! A perforated fartbox would be no bueno.. But I can see it happening, good point...
Pacific North West Jeeper = My HEMI Build:
https://www.pirate4x4.com/forum/showthread.php?t=850159
PacificNWestJeeper is offline   Reply With Quote Quick reply to this message
Old 07-16-2011, 07:38 AM   #5 (permalink)
howyadoin's Avatar
Member # 84132
Have you run those numbers through the caluculator?
Old 07-18-2011, 12:16 PM   #6 (permalink)
Member # 168896
yes i have
Old 07-18-2011, 04:19 PM   #7 (permalink)
GreatWhiteXJ's Avatar
Member # 103442
Send a message via AIM to GreatWhiteXJ
Can you triangulate the lowers more? Your RAA isnt scary bad, but its pretty bad.
XJ Buggy. RoXJoX
GreatWhiteXJ is offline   Reply With Quote Quick reply to this message
Old 07-19-2011, 02:26 PM   #8 (permalink)
Member # 168896
this better?
so do you guys think that link mount will be strong enough if i sleeve it with 1.5" .120 wall and tie it into the frame and try to tie it into the B-pillar as much as possible?
