Dana 30 advice - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-22-2011, 06:45 AM   #1 (permalink)
Member # 80807
Dana 30 advice
Hey guys I've got a high pinion 30 in a 94 yj.
4.88 gears and lockright in it. I pulled some guys out the mud and shelled the cross pin which took everything else out. So rebuild time. Question is since it got carrier locker and r/p do I rebuild with Detroit or is it gonna happen again. I just recently went to 4.88s and currently running 35s. May jump to 37s someday.
I'm not hard on pedal and have had the lockright in it since 1998.
If you say new front axle give me opinions on which one and why. And I'm recently divorced with three girls child support so money is tight!!!!
kfjeep is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 06:58 AM   #2 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
If you stick with the D30 it's going to again with 35's and certainly with 37's.
Please, don't spend money polishing a turd. Find a 1980 or later Waggy D44 and use that.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 07:30 AM   #3 (permalink)
Member # 46937
You should be able to make a 30 live on 35s especially in the mud. If money is that tight, throw in a new carrier with a lunchbox locker. Make darn sure the install is done correctly (bearing preloads, etc.).
That being said, if you go Dana 44, I wouldn't waste my time with anything other than a High Pinion 44.
Detroits...meh. ARB would be my choice.
atblis is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 08:51 AM   #4 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
X2 these can be had cheap if your still running the 35 rear maybe it's time for an upgrade on both ends.
Old 07-22-2011, 09:17 AM   #5 (permalink)
Member # 66452
Send a message via AIM to jeep795
If it already broke once, i think it's swap time. by the time labor and parts are done, you're well on your way to a decent hp44. I second the early 80's waggy 44.
jeep795 is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 09:40 AM   #6 (permalink)
Member # 148006
build a waggy 44, spool, lockouts, and gears.
RoyalXJ is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 10:57 AM   #7 (permalink)
Member # 121233
As atblis mentioned I have several rigs running 30's on 35's and they are not babied in the slightest. Were you pulling out the other rig in reverse. If so that is why you broke it. If money is tight I would rebuild what you have for under $500 you are back on the trail.
Then as funds allow begin building a 44 and swap when everything is complete, sell the 30 for $200 buckets and keep going.
Love building them, love wheeling them.
[COLOR="Red"]ECV Tuliburg 69[/COLOR]
Hanford Trail Busters
Cal-4
United Four Wheel Drive Association
Blue Ribbon Collation
MyJeep Rocks.com
Owner of Sidewayz Motorsports
cweed is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 03:19 PM   #8 (permalink)
NERD
gtxracer's Avatar
Member # 25303
x2, run a Jana K4 kit if you are worried about the gears and run a full case locker.
97 TJ Build:
2013 Raptor SuperCrew Tow Rig
Porsche
Fab Parts:
PNW Shock Tuning:
gtxracer is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 03:38 PM   #9 (permalink)
JAYS-TJ's Avatar
Member # 76518
If you drive wisely the hp should be good. A guy I wheel with has a hp 30 in his TJ with 37" tires. With the super 30 kit and an ARB. He's been running it for 8 maybe 10 years and runs lots of trails each year including 3 or 4 trips each year on the Rubicon
5.5" extreme duty RELA
NORCAL CRAWLERS W6JLO
JAYS-TJ is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 07:46 PM   #10 (permalink)
Member # 185278
There are so many pros to going 44, lockout hubs, wider range of gears, bigger stronger gears .Go with a waggy 44 and don’t look back. Just remember to avoid the vacuum disconnect axle they made for a couple years in the early 80's I want to say they were made from 82-84. The 80-81 were non disco as were the 85 up axles.
rda616 is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 08:00 PM   #11 (permalink)
Member # 86873
44
you guys keep saying hp44 but then say waggy 44 which is a low pinion axle... i for one am in the process of putting a waggy 44 in the front of mine so im not saying its a bad idea im just welll .... saying.... btw get ctm ujoints or some other well made u joints, if you dont you will have the same u joint issue with the 44.....
94 yj, front hp44 with detroit and 4:88 gears, klune 2:7.1 mated to a NV241OR rock trac 4.1 t-case, Rear ford 8.8 arb locked with 4:88's, soa stretched with xj leafs in the rear and wagoneers up front. 103 wheelbase. Sitting on 38 geolandar m/t's
ewalls is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 08:24 PM   #12 (permalink)
Member # 74251
On the cheap, 35" tires, a hp30 will survive with a locker and common sense.
Would probably go with a selectable locker for a YJ. I know several people besides myself that seem to keep 30s alive, with a front locker and 35s.
Have to remember that it's a 30 and treat it as such.
Wally
WallyP226 is offline   Reply With Quote Quick reply to this message
Old 07-22-2011, 08:30 PM   #13 (permalink)
NERD
gtxracer's Avatar
Member # 25303
I run a 30 but a waggy 44 is much more desirable since he's starting from scratch.
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 07-22-2011, 09:09 PM   #14 (permalink)
CSP
Member # 1533
Since when is a Waggy 44 a hp44?
CSP is offline   Reply With Quote Quick reply to this message
Old 07-23-2011, 04:51 AM   #15 (permalink)
Member # 74251
I suppose if I stumbled accross a 44 set up exactly the way I wanted it, I would go for it. Maybe a set of JKs or TJ 44s at the right price. Otherwise from a cost, time and benefit ratio, I can't see spending the time building a 44, where I would be replacing U joints, axle shafts, getting the drive shaft cut to length etc etc etc. If, i was going down that road, I would look forward to a Dana 60s, where the time and money invested would allow for 37s, and down the road 40s, where the bearings, knuckles, R&P housing are all more durable. I haven't found anything cheap about building an axle the right way.
Wally
Old 07-23-2011, 05:02 AM   #16 (permalink)
Member # 103689
Rebuild the 30 n next time use ur winch to pull ppl outta mud. I beat on my 30 like its my job (same set up as urs) n never a prob in 3yrs. if u have to pull someone at all DONT do it in rev. Takes the strength of ur hi pinion away. FWIW I mite someday swap a 44 in but never a waggy. It's Ford hi pinion or nothing. Lotta work n $ to not constantly have to worry bout my dshaft getting hammered.
'94 yj punished regularly.
'91 f250 pulls it home after i break it.
1tuffyj is offline   Reply With Quote Quick reply to this message
Old 07-23-2011, 07:56 AM   #17 (permalink)
JAYS-TJ's Avatar
Member # 76518
Wally
x2 on this. IMO
Old 07-23-2011, 10:57 AM   #18 (permalink)
Member # 122014
That gets my vote. I did the same thing, pulled someone out in reverse and cleaned the ring gear off. Otherwise, offroading I beat mine hard on 36's and an aussie and it stood up well. I did upgrade to the 95 shafts with the larger wheel joint. Good Luck
RandyYJ is offline   Reply With Quote Quick reply to this message
