8.8 rebuilt but now have issues. Need advice - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-23-2011, 07:48 PM   #1 (permalink)
Mopar96's Avatar
Member # 139758
So this past spring i rebuilt the 8.8 that i swapped into my fiances 95 YJ everything went good and has been fine since. I used royal purple oil to break in the gear set and i used lucas after. We have put maybe 2k on the axle since he rebuild and everything was fine till we went to Haspin the other weekend.
While toying around i noticed a "twisting metal/stressed metal" sound form the rear tire. Thought maybe it was loose lug nuts or caliper bolts. check all that it was fine. ran into town and we could only hear the noise when turning. Nothing going straight.
Got back to camp put it up on the trailer and spun the rear end and nothing, had my buddy hold one tire while i spun the other and hear not so good noises.
Granted we drove it all t he way from lima to haspin (150 miles plus) and didnt have a problem.
Popped the diff cover off tonight and i see......... nothing.. everything looks great i DID NOT replace the spider gears during the rebuild i was told they were fine and could be reused.
Pics:
Should i replace the spider gears and see if it goes away or is the LSD just now starting to really grab?
95 YJ: 5.3/700R4/241C HP60/60 5.38's and 40's in progress "The Bitch"
Mopar96 is offline   Reply With Quote Quick reply to this message
Old 07-23-2011, 08:20 PM   #2 (permalink)
Member # 174280
Its hard to tell for sure because the picture close up is slightly out of focus, but it looks like the spider gears are starting to round off and might be jumping teeth. Specifically, the gear in the top of the first photo and on the left of the second photo. The teeth start by rounding off and start to jump, but before long you'll be missing teeth all together.
When they break, they start out looking like this:
And before long look like this:
If it were me, I would pull the differental and inspect EVERYTHING with extra care and clean it all with brake cleaner while you have it apart. Look specifically for cracks in the carrier and metal pieces in the oil sump. Then, run a magnet through the axle tubes to collect and off metal shavings, chunks, ect that might have made their way up there.
After you've done that and your confident the carrier, ring gear, and pinion are all in good shape ditch the spider gears and LSD in favor of an Aussie. I know some look down on lunch box lockers, but based on your signature your 33's will be fine on them. I've seen guys running Aussie lockers with success on 36's. While your doing the install, make sure you replace the cross pin with a good hardened replacement. Do all that and you'll be set.
Bill3753 is offline   Reply With Quote Quick reply to this message
Old 07-23-2011, 08:34 PM   #3 (permalink)
Member # 174280
Oh, and by the way, I see your from Lima Ohio and was wondering if you ever go run Yankee Lake Truck Night? I'm originally from Ohio and haven't been to that red neck event in years (Military). I recently heard they put in a rock crawl section and have been thinking of bringing my TJ over from CT to give it a try.
Old 07-23-2011, 11:58 PM   #4 (permalink)
Mopar96's Avatar
Member # 139758
I have yet to make it over there yet my self. I plan on making it over there at some point just got to get my YJ moving again
looks like im calling East Coast on Monday for some spiders.
