Dana 18 outputshaft - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-09-2011, 08:40 PM   #1 (permalink)
Member # 67890
Dana 18 outputshaft
I really like this little transfercase, however some say outputshaft is a nail in the coffin for strength issues. I've witnessed a 3a with a very healthy fuel injected 327 turning 6500 rpm, of course traction was broken and the load was lessened. Is the deep freezing (cryogenic) of the shaft a worth while effort or a waste of money and time? My jeep, 55 tub,72 frame, 350 with a T18 tranny, 77waggy axles......and yes a 18 transfercase, that has always been there, the jeep is going from 33's to a 36-37" tire. I realize the load will be hell, but the rear driveline angle will be much better, even stretched. I like old stuff, but it always has to be done right.
GreenJeep55 is offline   Reply With Quote Quick reply to this message
Old 12-10-2011, 06:30 AM   #2 (permalink)
Member # 80328
From my experience the main thing that breaks the rear output is axle wrap/ u-joints binding up. Controlling the wrap will go a long way in making the rear output survive.
I would recommend switching to a M20 case and the bigger intermediate shaft. Cryogenic treating the out could not hurt either.
Script GPW project in progress.
b4wscrambler is offline   Reply With Quote Quick reply to this message
Old 12-10-2011, 07:19 AM   #3 (permalink)
Member # 9991
Run it till you break it, and then switch to a D20, so only the front axle is applying torque on the main case.
MrWillys is offline   Reply With Quote Quick reply to this message
Old 12-12-2011, 10:30 AM   #4 (permalink)
Member # 5326
I would have to agree that a binding u-joint is probably the best way to trash a rear D18 output.
I like the D18 t-case, but it does have its limitations. Cryo treating the rear shaft is probably a good idea.
Its nice you can still buy a new one! Keeping a spare around in the long distance trail bag could be a smart move.
I would love to see someone make a stronger replacement out of some 300M or something. The rear spline count would probably be altered to use something more modern. I don't know if a 32 spline output would work without making a new tail housing and ditching the speedo....but I think something could be figured out. Even the stock coarse 10-spline shaft in 300M that was properly heat treated would be an AMAZING upgrade in strength. If I ever get access to a rotary table that will probably make my list.
Old 12-13-2011, 08:47 AM   #5 (permalink)
Member # 67890
If the Advance Adapters would have followed through with the Atlas 18 unit, I would have purchased one the moment it was released. Talked to them about a year ago, they made a proto type then the project was shelved...oh well. It would have been nice to have a 4 to 1 ratio in a stout and compact new version of the 18.
Old 12-13-2011, 09:50 AM   #6 (permalink)
Member # 5326
Anyone have a picture of that prototype?
You can buy 'new' D18 transfer cases complete now....they are not even THAT expensive. I think under $800.
The D18 isn't a bad case at all, but it is a rather old design. I think with a few upgrades like better output shafts, it would be just fine for most people uses.
I always wondered if it would be possible to make a D300 into some kind of D18 like t-case. Looking at the front output bearing retainer on the front output side of the transfer case...its looks REALLY similar to a D18 rear output bolt pattern.
I would also love to see someone do something like a samurai gearset in a new billet t-case that bolted in place of a D18. I think that would be GREAT for everything except a V8 flat fender. The sami t-case can go down to like 6.5 or even 8:1 low range. The non-1:1 high range could make bigger tires on low power jeeps possible since you can only get down to 5.38 gears on most stock jeep axles.
Just a few thoughts. I'm will probably find a few limitations in my t-case once I get it back on the trail....
Old 12-13-2011, 02:32 PM   #7 (permalink)
Member # 9991
I'd rather use NOS stuff that's still available than use this:
http://www.reiderracing.com/product_...oducts_id=5985
Doesn't look made in America to me, but maybe i'm wrong.
Old 12-14-2011, 08:23 AM   #8 (permalink)
Member # 67890
Only one picture of the Atlas 18 that I know of, it was in some publication. I"ll try to dig it up if I still have the magazine. I believe it was in a "what is new this year" type of column.
