1942 GPW Build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-31-2011, 10:34 AM   #1 (permalink)
Member # 104115
1942 GPW Build
Well I've started this post before, but have changed direction so many times I just decided to start over and finally start my thread and build with pictures.
Currently I have a frame and tub sitting on the garage floor.
Chevy front dana 44 housing narrowed with Ford outers. No gears or lockers yet.
Ford rear dana 60 narrowed and converted to 35 spline. No gears or lockers yet.
Buick 225 V6
Ford T18
Dana 300 with twin sticks
35 " BFG's
Saginaw steering box
Frame Stretched 12"
YJ springs
Any advise is always appreciated.
I will start posting pics once I get it out of the garage and get working.
Don't sweat the petty, pet the sweaty.
1dunner is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 11:29 AM   #2 (permalink)
jalbrecht42's Avatar
Member # 52989
In (to watch). Any reason you can't remove the VIN tag from the frame and put it on a new frame? With a Saginaw swap, would you even be able to see the stock tag? (I thought it was located right where the box goes on the MB's -- not sure about gpw though).
'47 Willys CJ-2A -- www.pirate4x4.com/forum/showthread.php?t=690670
jalbrecht42 is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 11:52 AM   #3 (permalink)
Member # 104115
I thought about that but wasn't sure if the CHP officer signing it off would notice? I just finished a bike and took it to them, and he was very thorough. I figured I'd just not risk it, and hope the frame holds up. Thanks for the interest I hope to get started soon.
Old 12-31-2011, 12:08 PM   #4 (permalink)
Member # 27874
Send a message via AIM to Mrfreeze5
Ive got a 42 GPW with saginaw steering and the frame stamp is easily visible. There isnt a tag like the MBs, its stamped into the top of the frame in the engine bay. And the serial number is on the dash data plate too. I have yet to have mine registered though, but do have the matching data plate for the frame, but its not the original engine.
Mrfreeze5 is offline   Reply With Quote Quick reply to this message
Old 01-03-2012, 06:08 PM   #5 (permalink)
Member # 104115
Here are a couple pics of the project getting started:
Gonna start torching off the excess, and prep it for boxing it in.
Front HP 44 Rear 60
Took the rear in today to get narrowed to 59" and converted to 35 spline. Waiting to see if the HP 44 is gonna clear everything.
Old 01-13-2012, 12:12 PM   #6 (permalink)
Member # 104115
I've been kicking around the idea of re-tubing my Ford HP44 to be passenger drop, but I was told there might be a problem with the driveline hitting my starter and bellhousing when articulated.
Has anyone ever ran into this problem?
Old 01-27-2012, 10:55 AM   #7 (permalink)
Member # 104115
Just got the 60 finished. 65" wide now wms-wms, 35 spline, and disk brakes.
Old 01-28-2012, 08:50 PM   #8 (permalink)
Member # 104115
Anyone know of a place where I could find some affordable 8 lug 15" steel wheels?
Old 01-29-2012, 12:01 AM   #9 (permalink)
CRO
Member # 7588
Summit has cheap whitespokes
http://www.summitracing.com/parts/CRR-3105880/
1948 Willys
1952 M37CDN Powag
CRO is offline   Reply With Quote Quick reply to this message
Old 01-31-2012, 08:18 AM   #10 (permalink)
Member # 104115
Those might work. It looks like there is a couple different options too. I Like the backspacing. Thanks for the info.
Old 02-03-2012, 09:34 PM   #11 (permalink)
Member # 104115
Still need to get the front narrowed, but at least I can see the width with the 60 done. Gonna be perfect with some 35's just needs to be stretched to give me some leg room.
Looks a lot better with all that BS cut off the frame.
Old 02-03-2012, 10:35 PM   #12 (permalink)
csutton7's Avatar
Member # 4962
you might find some info in this thread---
https://www.pirate4x4.com/forum/showthread.php?t=1004065
also there's no reason for the jeep to be inspected by the CHP, but enlighten me to why you think it does??? ...chris
--my '48 build:
'56 truck:
csutton7 is offline   Reply With Quote Quick reply to this message
Old 02-03-2012, 11:45 PM   #13 (permalink)
Member # 104115
Even if I have no registration or plates? I imagine DMV won't issue me tags or plates for a 70 year old jeep that was sitting in a field with no record of it's history. I could be wrong, but they have never made it easy for me in the past. If they do decide to make me get an inspection at least I have the original stamping in the frame to prove it's legit. I've never delt with a rig this old, so I could be totally wrong. Worse case, I have fun with it for 5 or 6 years then build a new frame. What fun would it be if I didn't have to tear it all the way back down? I've read a lot of threads and seen a lot of rigs and some boxed in original frames crack and some don't. Being that I want my rig to be streetable, good little hunting rig, and make it through fordyce and home, so it might not get the stress that it would if it was a wheeler only. I'm always open to suggestions though. There's more than one way to skin a cat.
Old 02-03-2012, 11:47 PM   #14 (permalink)
Member # 104115
By the way, your rig's coming along good. I can't wait till I get a little further along because you have some good ideas.
Old 02-04-2012, 09:02 AM   #15 (permalink)
old school idiot
wilez5150's Avatar
Member # 86194
if the frame and body have vin numbers you do a lien sale for new paper work in your name. i have done this several times thur a private dmv service here in the hi desert. its to easy to hand the job off to karen than go to the dmv. the vin numbers have to be varified by somebody thats certified for vin varification, chp, dmv, or a private service. junk yards and mechanics do this all the time and can tell you who to use or you can do it yourself. if you go to the chp you can have a new vin issued for it but i would get the paper fixed before you go any farther. all they need to see is the frame and body, nothing else(hint hint).
USN 2x Viet Nam Vet.
life member Victor Valley 4 Wheelers
82 Yota with some stuff
F Toy #20
86 CUCV with some stuff
F 800 toter ho
retired wheeler
if you don't roll it over once in a while you aren't trying hard enough
wilez5150 is offline   Reply With Quote Quick reply to this message
Old 02-04-2012, 10:02 AM   #16 (permalink)
csutton7's Avatar
Member # 4962
ok I see what you're up against with the DMV....
wilez5150 great info there.....chris
--my '48 build:
'56 truck:
Old 02-04-2012, 10:07 AM   #17 (permalink)
Member # 104115
Thank you so much. This is great information. I will start on that now.
Old 02-10-2012, 08:46 PM   #18 (permalink)
Member # 104115
Well the 44 went into the shop this week. Gonna swap the HP 44 housing for a chevy housing so I can get the passenger drop. But after it's narrowed I am going to have the Ford knuckles put on it so I get the best of both. I was looking forward to a High Pinion but if I swaped it to pass drop than it would have interfered with my starter and bellhousing.
With some helpful info from everyone I will now be getting started on a box tube frame also.
Old 05-12-2012, 10:10 PM   #19 (permalink)
Member # 104115
Well it's taken a while, but finally a little more progress.
Out with the old, in with the new. I tried to keep the original frame, but I figured I'd listen to everyone's advice since you all went through it. The front axle is now done too. Not geared or locked, just narrowed the Chevy housing and added Ford knuckles.
Frame stretched 12"
It's probably gonna be a while till I can make a whole lot more major progress.
Old 05-13-2012, 08:02 AM   #20 (permalink)
csutton7's Avatar
Member # 4962
aw that brings back memories--good to see you built a new frame--very smart....
--my '48 build:
'56 truck:
Old 05-24-2012, 01:24 PM   #21 (permalink)
Member # 104115
I'm glad I got that advise before I went through all the effort to box in the frame. It's good to learn from others mistakes. I'm sure I'll make enough during this project so every one that I can avoid is a bonus.
Old 01-09-2013, 03:32 PM   #22 (permalink)
Member # 104115
Here is the small amount of progress so far. Axles under it. Lining up the tub for rear body mounts before I cut it in half. Slowly just getting the body set so I can start adjusting for the drivetrain.
Old 01-10-2013, 11:28 PM   #23 (permalink)
Member # 127313
Lookin good!!! Another stretched flatty!!! I like it. Good job on the frame.
[COLOR="Red"]Nobama[/COLOR], I don't mind working for my money, you shouldn't either.
Willys Build
[I]
“If you don't have time to do it right, when will you have time to do it over?”[/I] - John Wooden [B]RIP[/B]
[I]"Let every man have a pistol, instead of one man have a tank."[/I]
2003_ram is offline   Reply With Quote Quick reply to this message
Old 05-25-2013, 01:17 PM   #24 (permalink)
Member # 104115
Thanks 2003 Ram. It's a slow moving project right now. I hope to get the motor mounts, tranny mounts, and body mounts all tacked on soon so I can start cutting and aligning the body. I'll post pics as soon as progress picks up again.
Old 05-25-2013, 09:46 PM   #25 (permalink)
mikecj5cj8's Avatar
Member # 153
Since you live not too far from me.. who did your axle work? I'm gonna be shopping for axles for my flatty project soon and will need a source to cut them down. Thanks
When in doubt, knock 'em out.
mikecj5cj8 is offline   Reply With Quote Quick reply to this message
