Dana 18 binding on t90 trans - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-22-2012, 06:36 AM   #1 (permalink)
Member # 209412
I am trying to reinstall my Dana 18 on to the original t90 on my m38. The main shaft on the trans spins free and smooth until I bolt the tcase on. It feels like the rear bearing in whats binding up. Am I missing a step or is it supposed to be tight? Thanks for any help.
YellowdogsM38 is offline   Reply With Quote Quick reply to this message
Old 01-23-2012, 08:43 AM   #2 (permalink)
Member # 196310
Is the transfer actually pushing the barring ahead more when you put it on???
VermontCJ3a is offline   Reply With Quote Quick reply to this message
Old 01-23-2012, 09:38 AM   #3 (permalink)
Member # 209412
Everything spins fine until I snug down the tcase mounting bolts. When everything is tightened down, I can spin the shaft by putting a ratchet on the output shaft nut, but not by hand.
Old 01-23-2012, 12:09 PM   #4 (permalink)
CRO
Member # 7588
I would check to see if you dropped a needle bearing out of the input shaft when you assembled the transmission..
test this by taking off the input bearing retainer, tighten the transfercase and see if the front bearing pops out a little..
1948 Willys
1952 M37CDN Powag
CRO is offline   Reply With Quote Quick reply to this message
Old 01-23-2012, 12:32 PM   #5 (permalink)
Member # 196310
I agree will CRO or there might not be enough play between your shim and the barring causing it to bind
Old 01-23-2012, 06:02 PM   #6 (permalink)
Member # 209412
Thanks for the advice. I pulled the shaft only to find a synchro pawl had found its way into the input shaft causing it to bind up. She spins free now. Can't wait to get this thing running. Its been 6 long years since its been driven.
