Stretched Flatty Specs - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-21-2013, 11:36 AM   #51 (permalink)
1972Blazer's Avatar
Member # 20609
I have been searching for an NOS M38 Arctic Top for a while now. I want one in like new condition.
Build Thread - 1946 CJ2A "Post War Willys" -
1972Blazer is offline   Reply With Quote Quick reply to this message
Old 12-21-2013, 11:52 AM   #52 (permalink)
nofender's Avatar
Member # 25958
not the best shot, as the latest mods are still in progress.
110 in wheelbase
21 inch belly
52 inches at the hood
77 inches at the tallest point of the cage
39 in tires
64 inch WMS in rear
65.5 inch WMS in front
double triangulated suspension in rear with 16 in King coilovers, 4 in air bumps
3-link front with 14 in Kings, 2 in air bumps
Stretch was done behind the door - 16 inches
Frame is a heavily modified 69 CJ5 frame. The middle was removed and replaced with a longer frame section.
Drivetrain:
Mild TBI 350 hooked to a TH350/D300, stock gearing, stock hood and fender length
rear - Ruff Stuff 9 inch housing with 5:14 gears with a spool
front - Dodge 60 housing, narrowed 2 inches, 5:13 with a Detroit
fighting weight - 3717 last I scaled it. I expect it to come in about 100lbs lighter next year once all is said and done.
Only a couple of things I would do differently:
put 4 inches of the stretch into the door opening, instead of all of it behind the door.
Maybe start with a custom frame. I'd like the rig to be lower overall. the only way to accomplish that though would be to have the front and rear frame rails kick up higher that they do. tough call though. I'm very fond of being able to still see stock-ish frame sections.
Completely remove front crossmember under that radiator instead of trying to work around the stock piece.
Do a 3 link rear. It would be so much easier to package exhaust and maybe even allow for the fuel tank to drop further into the rails making room for a 3rd seat.
Speaking of tank - make my own to fit the space at hand. Off the shelf cells, no matter what i have tried just don't fit like I would prefer. I still may do this at some point as a side project.
Change the cage design a bit to allow a stock windshield frame to work. The current down tubes block everything. It's not really a design I can easily change at this point. I have a couple of Willys windshield frames in mint shape. I hesitate to chop them up.
nofender is offline   Reply With Quote Quick reply to this message
Old 12-22-2013, 10:41 PM   #53 (permalink)
csutton7's Avatar
Member # 4962
adding some frame info from my build:
wheel base 108.5"
Front links: lowers are 36 ½" and upper is like 36 Ό" center of bolt hole to center of bolt hole(at the moment)
Rear links: lowers 30 Ύ" and uppers are 23 Ό" center of bolt hole to center of bolt hole
frame measurements: bumpers not included but are 2x4---frame is built from 2x4x3/16" tube steel----
rear frame piece is 35 Ύ" long to the short point of the angle
center frame pieces is 62" long to the short point of the angles
front frame piece is 42" long to the short point of the angle
the length of the angle is 7 Ό" long when measured (I'll get the angle later)
also I"ll make a drawing and take a pic & post it later since my keyboard rendition doesn't want to post correctly...
| 35 Ύ" | | 42" |
_______________/x _________________
|_____________ \/____________________/ _______________|
| 30 ½" |\________________________/| 36 Ύ" |
| 62" |
--my '48 build:
'56 truck:
csutton7 is offline   Reply With Quote Quick reply to this message
Old 06-12-2014, 07:19 AM   #54 (permalink)
46WILYZ's Avatar
Member # 141981
Send a message via ICQ to 46WILYZ
Updates
KK6MWD "46WILYZ previously known as 1946cj2"
pirate4x4.com/forum/showthread.php?t=968398
46WILYZ is offline   Reply With Quote Quick reply to this message
Old 06-12-2014, 11:08 AM   #55 (permalink)
csutton7's Avatar
Member # 4962
my update: I'm still in Kenya….
--my '48 build:
'56 truck:
Old 11-12-2014, 07:11 PM   #56 (permalink)
Member # 231011
Originally Posted by h8sprint View Post
Ok I'll chime in too.
WB 103"
Drivetrain
350tbi , sm465, 205, D44/GM12
Tires
35" for now
Stretch
8" in hood, 3" in middle of the rear wheel well, the rest was in the door, I don't know how much in the door as I had to remake some of the stock body too and I didn't grab a measurement before the cut
Suspension
2.5 BDS Soa
Frame 2x4 .188
Height to hood 51"
Height to frame 26"
Height to crossmember 21"
Height to window frame 79"
Overall length 149"
Over all width 82" but I have spacers in the front. I have to fix an issue with the rims
Attachment 1027153Attachment 1027161
Sent from AutoGuide.com App
Couple updates and BTT
After some settling:
To the top of the grill 48"
To top of the door entry 37.5"
Top of the cage 79.75"
bottom of the frame 23.75"
Lowest crossmber 17.35"
Length of top bar on trackbar 39"
Front shackle angle is 25*
Rear shackle ended up at 40* after settling
Weight 4000 with 20 gallons gas and not me in it.
Size:  60.0 KBName:  ImageUploadedByAutoGuide1415848190.122179.jpg
Size:  45.3 KBName:  ImageUploadedByAutoGuide1415848260.815449.jpg
h8sprint is offline   Reply With Quote Quick reply to this message
Old 03-12-2019, 10:13 PM   #57 (permalink)
46WILYZ's Avatar
Member # 141981
Figured I would bring back a 5 year old thread for any updates or new rigs.
Old 03-13-2019, 02:33 AM   #58 (permalink)
nofender's Avatar
Member # 25958
Not a ton to update. But the old girl is still out there wheeling hard. Since posting in this thread I did a few updates. I tore apart the front suspension and redid the upper link. The geometry was all wrong. It works amazingly now. Did a 4:1 in the D300 and I swapped converters a time or two. It's pretty dialed in now. These days it's mostly maintenance and mild little updates here and there.
Old 04-16-2019, 07:01 AM   #59 (permalink)
Member # 187666
Finally pulled a tape, got my list together.
Specs are:
Wheelbase - 105"
Tire size - 37x12.50x15
Belly height - 19.25"
Top of hood height - 48.5"
Overall height - 72.5"
Overall length - 154"
Width - 75"
Axle WMS - F(58.5")/ R(58.5")
Weight - 4340
Suspension - 4" Alcan for Toyota, but ran SUA so equivalent to 0-1" lift
Stretch mods - 4.5" in the door opening, 18" behind the door
Frame origin - 2"x6" rec tube center rails, 2"x4" front and rear rails, 2"x4" front and rear bumpers
Drivetrain - 22re, W56, dual toy cases (2.28/4.7), front toy 8" w/ E-locker, rear toy 8" w/ Detroit.
lurch9 is offline   Reply With Quote Quick reply to this message
Old 04-22-2019, 09:00 PM   #60 (permalink)
CAVE's Avatar
Member # 30681
Very nice. Been watching your build and excited to see you on the road!
CAVE is offline   Reply With Quote Quick reply to this message
Old 04-23-2019, 07:50 AM   #61 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Specs
Wheelbase: 96”
Tire size: 37x13.50x15
Belly height: 19”
Top of hood height: 50”
Overall height: 80”
Overall length: 160”
Width: 80”
Axle wms: F:64” R:63.5”
Weight: ?
Suspension: Rubicon Express 4” wrangler leaf springs, ruffstuff 2+ perch kit, traction bar, Rancho RS9000 shocks
Stretch mods: 4.5” in door opening, 4.5” behind door at angle to preserve rear wheel opening.
Frame origin: 2”x4”x.240”
Drivetrain:Chevy Dana 44 cut down 4” and long side wagoner axle shaft used, cab and chassis 14bolt, 4.56 axle gears, ARB lockers, Chevy 4.3 v6, SM465 trans, Dana 20 with tera low.
4x4Yak is offline   Reply With Quote Quick reply to this message
