SuperTramp Willys - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-28-2013, 03:47 PM   #1 (permalink)
Member # 231011
SuperTramp Willys
Ok so this will be my build page EDIT: and Adventure page
I wanted to wait till I had more done so it didn't look like it was taking forever but I have tons of questions and hoping people will dig it and help answer them and keep it in one place. (Named it supertramp as in Alexander supertramp in the movie "into the wild" )
The plan. Is to have a reliable trail rig that is streetable. I will use the parts that I currently have to get it built and driving then when stuff breaks go to better equipment from there. I just don't want it to die out cause I spent to much $ on over kill before it was running and never get done. Time frame I want to do the rubicon in2014 jeepers jamboree.
Parts list.
Wills tub title says 48
Chevy 44 front spool, chromo, 4.56 warn premium hubs. ( later will have arb's both ends)
Chevy corp 12 rear, spool,
Chromo, 4.56
5.7 tbi
Sm465/205
SOA ( link rear later) bds004200 springs
New frame. Stretching to 100" wb 10" in the door. Some in front and some behind door.
I know I'm forgetting stuff. But thanks for any input.
Size:  77.7 KBthis was the night I got her Name:  ImageUploadedByTapatalk1359412979.887364.jpg
Size:  102.1 KB1st thing out with the frame and axles Name:  ImageUploadedByTapatalk1359413040.143866.jpg
Size:  98.8 KBtaking it apart so it will fit in the truck
Size:  57.9 KBcleaning up the tranny and 205
[ATTACH]729337[/ATTACH
h8sprint is offline   Reply With Quote Quick reply to this message
Old 01-28-2013, 03:54 PM   #2 (permalink)
Member # 231011
Good and bad. Clean but found a crackName:  ImageUploadedByTapatalk1359413339.589637.jpg
Size:  82.3 KBName:  ImageUploadedByTapatalk1359413487.697431.jpg
Size:  95.6 KBcleaning up and taking off all the old brackets and hack shit. Name:  ImageUploadedByTapatalk1359413540.758842.jpg
Size:  99.1 KBall better
Size:  80.8 KBstarting to make the frame
Old 01-28-2013, 03:56 PM   #3 (permalink)
Member # 5326
cool! Always good to see another flat fender build...
Old 01-28-2013, 03:57 PM   #4 (permalink)
Member # 231011
Size:  82.4 KBmaking sure it's all straight
Size:  68.0 KB template for plates
Old 01-28-2013, 04:01 PM   #5 (permalink)
Member # 231011
Size:  85.0 KBName:  ImageUploadedByTapatalk1359413850.487779.jpg
Size:  66.3 KBName:  ImageUploadedByTapatalk1359413865.997414.jpg
Size:  63.9 KBName:  ImageUploadedByTapatalk1359413892.375016.jpg
Size:  70.8 KBtrying to figure out where to cut final lengths of frame so I can put cross members in. ( I pondered on this for hours. I decided the frame width will match the set up on the front axle 29.5 inside width and ill outboard the rear leafs. I got them tacked up and the frame pulled out of square so I stopped for the night. That's where I set currently.
Old 01-28-2013, 04:06 PM   #6 (permalink)
Member # 231011
Thanks. Yeah I love these. Always wanted to do one.
Old 01-28-2013, 04:07 PM   #7 (permalink)
Member # 5326
Shoot at this rate you'll be done in like a few days.....trailer to frame in like 10 minutes!
If you could take a few measurement on your frame length after you get the bumpers on that would be a great resource for other builders down the road!
Old 01-28-2013, 04:20 PM   #8 (permalink)
Member # 231011
Will do as this was one of the hard parts. Ill post up measurements of each part and spring squat and as much as I can. Especially the stuff that was hard find.
Old 01-29-2013, 07:59 AM   #9 (permalink)
Member # 108128
Looking good. Love to see how others build the same rig.
I would just tack weld, with heavy tacks, a temporary cross member at the existing ends. Once you get the body mocked up on the frame then make the final cuts and full weld in the cross member. It's easy to remove metal, a little hard to put it back if you cut too much off.
51 Willy's
kirbybuilt is offline   Reply With Quote Quick reply to this message
Old 01-29-2013, 08:03 AM   #10 (permalink)
Member # 231011
Good call thanks.
Old 01-29-2013, 09:44 PM   #11 (permalink)
Member # 231011
Some frame measurements. 2x4 3/16 the total length is 148.75" bumper to bumper
The belly is 68" to the outsides of the 45* cuts
Rear rails are 45" then bumper added makes 47"
The front rails are 46.5" front bumper sits inside the rails. I did this incase I come up short I can add and another "bumper and gain 2" hope
I had to cut some of the tacks and take a come along and pull the frame square again. Then i added corner braces and a center piece
Size:  85.3 KBName:  ImageUploadedByTapatalk1359521061.561004.jpg
then more tacks ensure its stayed square then tacks again. Hope that all makes sense.
Old 01-29-2013, 10:14 PM   #12 (permalink)
Member # 127313
Looking good! I like the general plan of the build. Let me know if I can be of any help.
[COLOR="Red"]Nobama[/COLOR], I don't mind working for my money, you shouldn't either.
Willys Build
[I]
“If you don't have time to do it right, when will you have time to do it over?”[/I] - John Wooden [B]RIP[/B]
[I]"Let every man have a pistol, instead of one man have a tank."[/I]
2003_ram is offline   Reply With Quote Quick reply to this message
Old 01-30-2013, 08:31 AM   #13 (permalink)
Member # 231011
I appreciate that. Thanks
Old 02-05-2013, 07:00 AM   #14 (permalink)
Member # 231011
Ok so I'm trying to decide to shackle reversal or not. Seems like its almost a even split on the build threads. If I do a SR how long should the front mount be? Name:  ImageUploadedByTapatalk1360072837.631685.jpg
Size:  75.2 KBthanks.
Old 02-05-2013, 07:41 AM   #15 (permalink)
csutton7's Avatar
Member # 4962
I'm in to see how this goes...
I'd weld some plates over the frame seams to help reinforce them--there's lots of stress at those welds, so helping them would be smart...
EDITED:
ooopps--looks like you've done that--I didn't look closely at the last pic.....chris
--my '48 build:
'56 truck:
csutton7 is offline   Reply With Quote Quick reply to this message
Old 02-17-2013, 06:21 PM   #16 (permalink)
Member # 231011
Well I was making ok progress today. 1st time in I had time to work in the garage but sometimes it fights you. After smoking an angle grinder and a drill I should have red the signs.
Anyone know the best way to fix this mess up? Name:  ImageUploadedByTapatalk1361150427.500752.jpg
Size:  89.2 KBName:  ImageUploadedByTapatalk1361150438.604258.jpg
Last hole to. The other side was good. Not sure how I ended up 1/4" off.
Old 02-17-2013, 06:27 PM   #17 (permalink)
Member # 231011
Anyway. Here are some progress pics
Size:  65.9 KBName:  ImageUploadedByTapatalk1361150709.736790.jpg
Size:  75.2 KBalso need to rethink this. Name:  ImageUploadedByTapatalk1361150745.886037.jpg
Some options I was thinking cut the bumper off and move it forward and put the hanger on the backside of the bumper. So I can get the damn bolt in. Or mount it just below the frame and make the shackle shorter.
Old 03-02-2013, 04:00 PM   #18 (permalink)
Member # 231011
SuperTramp Willys
Thanks for adding me to the build threads. Name:  ImageUploadedByTapatalk1362264983.520020.jpg
Size:  37.7 KBre-did the rear brackets. Name:  ImageUploadedByTapatalk1362265016.652070.jpg
Size:  53.0 KBhere is what I did to solve this. Tacked on a 2" .120 wall 1/2 long used a roto bit then on my sleve I added on the missing piece. Name:  ImageUploadedByTapatalk1362265116.407757.jpg
Size:  40.7 KBName:  ImageUploadedByTapatalk1362265132.541653.jpg
Size:  53.1 KBstayed up late and got it on its own weight. Name:  ImageUploadedByTapatalk1362265176.015635.jpg
Size:  47.8 KBstripping all the crap off the tub before stretching
Old 03-02-2013, 04:00 PM   #19 (permalink)
Member # 231011
SuperTramp Willys
Size:  43.3 KB ended up at 103.5" wb.
Old 03-02-2013, 06:42 PM   #20 (permalink)
Member # 231011
SuperTramp Willys
Freaking bondo was 1/2" thick. Stripped it all down and cut it in half. After I stripped it the pass side had a few bullet holes. Name:  ImageUploadedByTapatalk1362274903.478832.jpg
Size:  31.7 KBName:  ImageUploadedByTapatalk1362274923.568457.jpg
Old 03-02-2013, 06:43 PM   #21 (permalink)
Member # 231011
SuperTramp Willys
Size:  43.3 KBName:  ImageUploadedByTapatalk1362274979.710787.jpg
Old 03-24-2013, 09:16 PM   #22 (permalink)
Member # 231011
SuperTramp Willys
Finally had a chance to spend time I bathe garage this weekend. Name:  ImageUploadedByTapatalk1364181179.740569.jpg
Size:  61.8 KBtrying to figure where to put the engine
Size:  58.6 KBName:  ImageUploadedByTapatalk1364181254.252175.jpg
Size:  42.1 KBmade some motor mounts
Size:  35.6 KBcopying svaras design
Old 03-24-2013, 09:24 PM   #23 (permalink)
Member # 231011
SuperTramp Willys
Size:  58.3 KBset the carb mount at 0* which the engine ended up about 4* tranny end down Name:  ImageUploadedByTapatalk1364181529.937196.jpg
Size:  43.1 KB used the stock crossmember. I'm a far cry from flat. Ill make a skid plate that makes every this flat. Name:  ImageUploadedByTapatalk1364181625.073421.jpg
Size:  55.3 KBcut out te floor so I could sit the body on and see how I want to stretch it. Te rear driveshaft will be close to 30". Name:  ImageUploadedByTapatalk1364181727.115320.jpg
Size:  51.9 KB finished the day with a crossmember for the engine. I have a plan to make the center removable. Time to read up on body work. Any tips on how to take the old body apart at the seams?
Old 06-06-2013, 10:16 PM   #24 (permalink)
Member # 231011
Well not much of an update. Been hard finding time to be in the garage with kids moving back in from college. In laws in town. 1 kid getting his license some training for work the wife getting a new job and schedule and on top of it ( I'm a pool guy) work has been crazy busy and 16 hour days in the heat and its hard to go into the hot garage. So it will be slow thru the summer then plan on hitting it hard on the winter. So for now its been research, stocking cash, and rereading others builds. So here is where I'm at Name:  ImageUploadedByTapatalk1370578189.817029.jpg
Started to build floor and stretch.
Size:  44.9 KB I had to remake the seam part as mine where trashed. Name:  ImageUploadedByTapatalk1370578310.746210.jpg
Size:  39.7 KBName:  ImageUploadedByTapatalk1370578341.723245.jpg
Size:  38.4 KBName:  ImageUploadedByTapatalk1370578387.581481.jpg
Size:  60.1 KBso I don't want to comp cut it and was hung up on getting the rear axle in the center without it stretching to much in the door. I moved the tub back but then the motor is to far forward. So I'm adding a few inches in the ass and if this still doesn't work I'm moving the axle forward.
Old 06-06-2013, 10:19 PM   #25 (permalink)
Member # 231011
Size:  50.9 KBName:  ImageUploadedByTapatalk1370578621.460043.jpg
Size:  49.3 KBcut the radius out to move back to retain the factory wheel opening. That's where I'm at. Just thinking about steering, gas tank, pedals, radiator/fan. Need ill that kinda to get everything in the right spot.
