How to put locking hubs on a 74 wagoneer 44 frontend? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-30-2014, 12:05 AM   #1 (permalink)
Member # 410745
Question How to put locking hubs on a 74 wagoneer 44 frontend?
A little info on the project '46 2-A / waggoneer 44s front & rear S.o.a.--5:38s -231 V-6--Sm420 4Spd-dana 18 all sitting on 35" monster mudders--Your basic little trail Jeep.As the title says what do i need to put locking hubs on 74 wagoneer dana 44 front ? (And Yes i`m new here & yes i tried a search first. Sorry if i missed it if this has been answered before)
caseywheels is offline   Reply With Quote Quick reply to this message
Old 01-30-2014, 06:23 AM   #2 (permalink)
Member # 5326
It should be as easy as pulling the out the drive slugs and installing locking hubs. It should be an internal hub style front axle?
For a cheap junkyard swap some Dana/Spicer locking hubs off a 70s Ford F150 should work.
The only special tools you kinda need is a good set of internal and external snap ring pliers. It can be done with some flat head screwdrivers but that might lead to flying metal rings and swearing.
Old 01-30-2014, 11:26 AM   #3 (permalink)
Member # 229476
On a similar note, what would be involved to put locking hubs on a D41 rear axle?
danielbuck is offline   Reply With Quote Quick reply to this message
Old 01-30-2014, 12:04 PM   #4 (permalink)
Member # 5326
19 Spline Full Floating Axle Kits | Herm The Overdrive Guy
I think you would have to convert to 19 spline side gears to use the herm stuff.
If I remember right you can install 19-spline D44 side gears in the D41 carrier.
Old 02-01-2014, 06:35 AM   #5 (permalink)
Member # 213940
I did mine years ago, also a 74. It was quick and easy an took maybe an hour.
The important thing to remember it to save the old parts. Keeping one drive slug and cap makes a quick and easy trail spare if you blow up a locking hub.
Yeager1 is offline   Reply With Quote Quick reply to this message
