5spd options?????? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-18-2014, 10:43 AM   #1 (permalink)
Member # 154122
5spd options??????
What is a good 5 spd option for the dana 18 tcase and a chevy 350 motor, and stock axles on a 52 willys m38? I want it more capable for highway speeds as to off road capable. Thanks for ur input!
bagboynick is offline   Reply With Quote Quick reply to this message
Old 05-18-2014, 11:54 AM   #2 (permalink)
Member # 5326
With the short wheelbase your better off running an overdrive on the back of the the transfer case. There just isn't a lot of room for a true 5spd with the stock transfer case.
Old 05-18-2014, 04:23 PM   #3 (permalink)
redsandman6's Avatar
Member # 39935
I agree with mieser. All of the 5 spd that would handle the v8 power are going to be too long.
Overdrive in the d18 would be the best option check out these sites
Saturn & Warn-OD : Saturn & Warn Overdrive for Dana 18 Transfer Cases | Advance Adapters
Overdrive Types | Herm The Overdrive Guy
'93 YJ Trailer Queen
'04 Chevy Dually Tow Rig
redsandman6 is offline   Reply With Quote Quick reply to this message
Old 05-18-2014, 09:35 PM   #4 (permalink)
csutton7's Avatar
Member # 4962
I have a brand new never run tera-lo d-18 with an overdrive I need to sell so if you're interested let me know---
and the boys are right about the 5spd tranny--you will end up with an extremely short rear driveshaft…...
--my '48 build:
'56 truck:
csutton7 is offline   Reply With Quote Quick reply to this message
Old 05-19-2014, 03:39 PM   #5 (permalink)
Peow130's Avatar
Member # 123919
If you could find an NP540, that's a 5 speed truck transmission of similar size to a T18 or NP435..
You'd have to adapt it to a chev bellhousing.
Fuckin shitbox 2005 F150
53' CJV35-U, HO 5.0, 4 speed, etc.
Peow130 is offline   Reply With Quote Quick reply to this message
Old 05-20-2014, 09:36 AM   #6 (permalink)
jalbrecht42's Avatar
Member # 52989
I'd go with the warn OD personally (that's what I did) but just for discussion..
Novak has an adapter that works with several common OD transmissions.
Adapting Late Jeep Transmissions to the Dana 18 & 20 Transfer Cases
The combined length they show is:
AX15, 18-1/2"
NV3550, 18-1/2"
T5, 17-1/2"
AW4, 27-3/8" (auto, with bellhousing I assume)
If you're still running a T90 3 speed, it would be about 8-9" long in comparison.
I think Moses Ludel had a V6/NV3550/D18 w/ OD in a mostly stock early CJ-5 at one point so maybe it's possible with the motor shoved forward, but would be really tough for stock wheelbase and a V8. I can say putting a T98 in my stock CJ-2a makes for a very short driveshaft, about 13" long overall. The tube is only about 3.5" long. The T98 (with dual adapters in my case) is approx 13.5-14" overall.
'47 Willys CJ-2A -- www.pirate4x4.com/forum/showthread.php?t=690670
jalbrecht42 is offline   Reply With Quote Quick reply to this message
