DieselDoris 1947 CJ2a from Sweden - Page 12 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-04-2020, 02:56 PM   #276 (permalink)
Member # 221907
20191218_163657
On the 18/12 I got the chassi back in the workshop after I sprayed the tub earlier that day.
20191219_000829
Mounted the internals in the rear axle and the radius arms.
20191219_163856
And connected with the frame.
20191219_163904
Front axle and links bolted togheter.
20191220_162747
On the 19/12 I got help from Ernie to mount the engine in the chassie.
20191220_162802
20191220_162808
I got the rear brakes all togheter
20191220_174529
We disassembled my coil overs and mounted the foam bump and filled the CO with Fox shock oil and nitrogen.
20191220_223940
Reservoirs mounted with jubilee clips covered with shrink tubing.
Willys CJ2A 1947 with Toyota axles with ARB and 35"PBR
pigge is offline   Reply With Quote Quick reply to this message
Old 01-05-2020, 09:15 AM   #277 (permalink)
Member # 181868
I see you have radius arms in the rear. Maybe you want them.
The reason I comment is, When I first started my project, that's what I did. I liked the simplicity. But I didn't completely understand radius arms. Unless you have allot of rubber at the attachments, they won't flex. I'm not really building a rock crawler and don't believe in massive flex. BUT, my first attempt had almost no flex. In fact, it flexed mostly from the frame. The radius arms act as a giant anti-roll bar.
I was afraid of cracking the frame and ended up making one side a radius arm and the other side just a single link. This flexes lots. The only issue I can imagine is the whole truck would twist under major excelleration. I don't have big power, so not an issue for me. In tests, it has no negative problems.
In front of my project I did radius arms. These were basically stock superduty. I found these were good for "on road" manners. I end up making a "pin-able" radius arm on one side. This gave good on road manners and lots of flex off road. (With the pin removed) I couldn't run without the pin on road because hard braking would make one side dive.
I have some pics of testing with both radius arms. I will try to find them.
Edit, I found description and testing of my front set up. Post 49 and 50. (Link below) It appears I don't have the rear testing in this thread. I'll see if I can dig up the pics. (They show better what I mean)
Project : Amphibious HEMTT
Old 01-09-2020, 12:00 AM   #278 (permalink)
Willys Fan
CJ3BL's Avatar
Member # 429498
Superb progress! Looking great! Really enjoying your build. Very creative ideas!
CJ3BL is offline   Reply With Quote Quick reply to this message
Old 01-09-2020, 02:03 PM   #279 (permalink)
Member # 221907
Thanks for the very kind word.
Old 01-09-2020, 02:18 PM   #280 (permalink)
Member # 221907
It's because of the radius arms acting as sway bars I have chosen them.
I had an extremly stable car on leaf springs and I want to keep the car that way.
Old 01-09-2020, 02:42 PM   #281 (permalink)
Member # 221907
In the afternoon on Friday the 20/12 I picked up my Rims from powder coating.
The same night I sprayed the red paint on the lip.
20191220_235411
20191221_205452
Exhaust system painted and mounted.
20191221_205502
Steering is mounted and adjusted I also measured the thickness for my spacers needed in the ram.
20191222_194513
20191221_211145
How about a Willys gasser?
20191221_211153
Front axle have got some goodies, Longfield shafts, Birfields and fixed drive flanges.
20191222_012155
I also assembled and mounted the new fuel tank.
20191222_020911
20191222_212512
Mounted all 4 tires with beadlocks.
Old 01-14-2020, 03:37 PM   #282 (permalink)
Member # 221907
On the 22/12 we mounted the cage
20191222_221725
20191222_221738
20191222_223232
These wheels are a little to small
20191223_020430
On the 23/12 I got my tank cover and rear coil overs mounted
20191223_094543
I also got the last hoses pressed before the hydraulic shop closed for christmas.
20191223_132409
This looks so much better
Old 01-15-2020, 09:27 AM   #283 (permalink)
Member # 181868
That's OK if it's what you want. Here's a pic of what I mean. You might not see it here, but the right tire is off the ground. The frame is square to the ground in the front. Obviously there's a lot of stress on the frame. If the frame were braced more, there would be less flex. There is tremendous stress on the links also. (If you have heavy tires)
Here's the same truck with a single link on one side. Frame is not twisted from front to back.
Old 01-19-2020, 11:32 AM   #284 (permalink)
Member # 221907
Here are the last pictures from the assemble of the car.
It was a totally mad race all Christmas to finish the car.
I wanted to get the car finished for our local 4x4 meet on the 26/12-19 because last time I drove it was 26/12-17 so if I manage to make it the build had been under 2 years.
20191225_025721
The hoses for brakes, axle vent and ARB goes behind the big hoses for the steering ram.
20191225_182734
On the 25/12 I got help from Ernie to mount the last parts I couldn't do by my self, then of to Christmas dinner with my family at my sisters plays.
20191225_214043
20191225_214059
20191226_024530
I spoke too Ernie when he drove in to the 4x4 meet I drove home to have a shower, breakfast and pick up my youngest son after an all nighter in the workshop. Now I had been awake for 22 hours and spent 17 of them in the workshop.
When I was back in the shop after 1,5 hour me and my son mounted the headlights and tightened the bolts to the seats and then of to the 4x4 meet with the Willys.
I'm very happy that it all worked out.
A Giant thanks to my wife that supported me and let me spend so many hours in the workshop before and under Christmas.
Old 01-20-2020, 11:47 PM   #285 (permalink)
Willys Fan
CJ3BL's Avatar
Member # 429498
Congratulations on getting it all together to make the 4x4 meet! That's pretty amazing! Really cool build! Great work!
Old Yesterday, 07:48 AM   #286 (permalink)
Member # 181868
Need some pics at the meet.
Old Yesterday, 01:47 PM   #287 (permalink)
Member # 221907
Of course you will get some pics
20191226_115830
20191226_115837
20191226_115849
20191226_115919
20191226_115928
20191226_133617
20191226_145113
It sits a little low in the rear, the coil-overs had not been adjusted at all, it's fixed now.
I'm really happy with how it all looks because it's really close to my vision.
I will show more pictures over the next days
Old Yesterday, 01:48 PM   #288 (permalink)
Member # 221907
Thanks for the kind words
Old Yesterday, 04:45 PM   #289 (permalink)
Member # 181868
Looks great! Looks wide for the height, so should be very stable on a side hill. Color looks great to! Any bugs besides the spring height? How much did you get to run it?
