Granddaughter Jeep build - Page 12 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-05-2019, 06:28 AM   #276 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Originally Posted by lovejeeps View Post
Yeah I went back and looked through the thread again. It looks great! I need to get mine going...this is great motivation though.
I haven't done much as I was too busy over the holidays, but I'm going to pull the dash panel today, sand blast and paint it. There's tons of little stuff like that I need to get done until my son-in-law can get here to weld up the seat frames and the new front crossmember for the radiator and weld on the plate for the steering box. Also have to do a new plate for the trans tunnel as the SM420 is larger than the stock T-90.
One of the great achievements of science has been, if not to make it impossible for intelligent people to be religious, then at least to make it possible for them not to be religious. We should not retreat from this accomplishment.
Salesmen and women. God sells to the ignorant.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 01-20-2019, 11:35 AM   #277 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
I found a solution for flaring the pipes out of the A/C compressor. Bought a block and adapter tubes from Vintage Air. The block bolts to the back of the compressor and the adapters screw onto the fittings. Very clean set up.
I also had a shop bend up some exhaust tubing to mate up with the manifolds. The left side is right on, but the right side needs more bend.
Old 01-25-2019, 06:29 PM   #278 (permalink)
Member # 212475
Iíve never seen the spring on the exhaust before? Whatís the purpose for this, or is it just temporary?
1940 something Willys MB
289 Ford,T18 Trans,D18 transfer case
lovejeeps is offline   Reply With Quote Quick reply to this message
Old 01-25-2019, 06:41 PM   #279 (permalink)
Member # 193950
Usually used with a doughnut gasket, to allow a little movement in the joint.
Aaron Z
At some point you have to accept that lots of naturally-occurring substances can kill you-Solandri
aczlan is offline   Reply With Quote Quick reply to this message
Old 01-26-2019, 10:56 AM   #280 (permalink)
Member # 212475
Aaron Z
Ok, I see. Thanks!
Old 01-26-2019, 11:17 AM   #281 (permalink)
Member # 95025
Very cool build!
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 01-26-2019, 11:32 AM   #282 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Aaron Z
Ok, I see. Thanks!
Yup. The springs, studs, and nuts came with the new manifolds I bought.
I'll update with more pics a little later today. Got the brake parts back from the machine shop and the heater came in. Mocking up stuff now.
Old 01-26-2019, 01:12 PM   #283 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Got the brake pedal offset parts from the machine shop today. I have to fab up a bracket for the heimjoint to the firewall to brace the bar. The pedal arm needs to be bent just slightly to get it exactly where I want it also. I also found out that using a left side exhaust manifold on the right side smashes the oil dipstick tube, so I bought a flexible tube from Lokar. Any hints on getting it into the block? So far it feels like an interference fit.
Old 01-29-2019, 09:59 AM   #284 (permalink)
jjeep71's Avatar
Member # 110523
Looks good, be careful with the arm hitting the body. I had a problem with that and was not getting full range. Brakes "sorta" worked until I fixed the issue.
71' CJ5, 87' 231 V-6, SM465, D-18 w/Warn OD, D44-Detroit, D30 w/ARB, Warn 9000# winch, on board air.
jjeep71 is offline   Reply With Quote Quick reply to this message
Old 01-31-2019, 01:27 PM   #285 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Got a bit more done today. Mocked up a bracket for the brake linkage to brace it to the firewall. Also test fit a new oil dipstick tube. The exhaust manifold is going to need some grinding for clearance so the tube doesn't get smashed. Got the new CV rear driveshaft, which requires a different yoke than the one with the drum e-brake. The old yoke is kicking my ass. It's taken 3-4 hours to get it half-way off. Also mocked up a place for the heater. I got the ducting and vents for heat and defrost with it. The black manifold is part of the air compressor stuff that hooks to the A/C compressor.
Old 01-31-2019, 01:39 PM   #286 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Old 02-01-2019, 06:29 AM   #287 (permalink)
whitneyj's Avatar
Member # 135947
Maybe it's just the angle of the pic, but are you going to be able to get a spark plug wire on there? Looks like the plug is up against the manifold.
Place banana in your ear.
Observe that there are no alligators around.
Conclude bananas placed in ears keep alligators away.
whitneyj is offline   Reply With Quote Quick reply to this message
Old 02-01-2019, 08:58 AM   #288 (permalink)
csutton7's Avatar
Member # 4962
looking good for sure....
--my '48 build:
'56 truck:
csutton7 is offline   Reply With Quote Quick reply to this message
Old 02-01-2019, 01:25 PM   #289 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
It's the angle of the pic. I've had that manifold on before and there's plenty of room.
Old 04-07-2019, 03:52 PM   #290 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Been slowly chipping away at it. Finally had my SIL get up here to do some welding. Got the new front crossmember in and the radiator mounted. Had to notch the radiator mount to clear the steering shaft. Been doing lots of boring clean up too.
Old 04-27-2019, 01:49 PM   #291 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
I keep chipping away at it. Lots of little stuff that takes insane amounts of time. Decided I really didn't like the AA shifter for the Warn OD. I'm starting to modify the stock shifter. The shirt lever will be even with the trans shifter instead of jammed into the T-case twin-sticks. I had to grind out between the two mounting holes for it to mate up with the front bolt on the trans. The rear flange will need to be moved back a bit to line up with the next bolt. I'll also have to cut and lengthen the rod about 8".
Old 04-27-2019, 01:52 PM   #292 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Also made a bracket to mount the fuse block to. Got it all mounted in, so now it has to come back out and get painted.
Old 06-08-2019, 07:18 AM   #293 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
I finally gave up on the idea of getting the tub prepped for paint. I realized I'd be at it until doomsday trying to clean it up good enough, so I dropped the tub off at the sandblasters yesterday. I'm supposed to get it back early next week. Now I'm trying to figure out which oxygen sensor I need for the 1992 TBI 4.3L V6. Been looking on-line and about 1/2 the wiring diagrams show a 1 wire sensor and the others show a 3 wire heated sensor. On the wiring for the motor I have I've found a 1 wire with plug. I went to the parts store and the only sensor they show is the 3 wire one and so does Rock Auto.
Edit: Well, after more research I double checked the part# for the computer and It's from a 1900 & 1991 model year, not a 1992.
In 1992 they went from a 1 wire O2 sensor to a 3 wire which is heated.
Old 06-12-2019, 06:18 AM   #294 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
I took the body tub to a sandblaster place last Friday as I started to try and clean it up myself and realized I'd be at it until doomsday. Supposed to get it back this week.
Old 06-12-2019, 06:46 AM   #295 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Going to be a damn nice Jeep!
& Blaine
:tank:
Old 06-12-2019, 07:02 AM   #296 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Thanks. I'm going for mechcanicly sound and passable on looks. It's going to get bashed on rocks, so I'm not going for a perfect body. Just want a surface the new paint will stick to.
Old 06-14-2019, 10:14 AM   #297 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Ugh !!! The sandblasting uncovered more rot than I was hoping for. Looks like new front floorboards are going to be needed.
Old 06-15-2019, 09:14 AM   #298 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Well, I ordered the floor and a pair of lower sides this morning. Patching them would be more work than replacing.
