63 Willy’s wagon build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-22-2018, 07:44 AM   #1 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Got this wagon 5 years ago and got started on the build but then found out I was going to be a father and decided to rebuild the flat fender since it was going to be the easier rebuild. Fast forward 5 years, flat fender is done and now it’s time to get going on the wagon.
4x4Yak is offline   Reply With Quote Quick reply to this message
Old 11-22-2018, 07:49 AM   #2 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Here’s what I started with...1963 Willy’s wagon Maverick model. It had already been hacked up a bit and front axle added.
Old 11-22-2018, 07:59 AM   #3 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Sold the original drivetrain and picked up a Chevy 305, NV4500, atlas 2, high pinion Dana 60 front, 14bolt rear, and 42” pit bulls. Inspired by the “another chopped channeled Willy’s wagon” thread a few years back. Trying to keep as low as possible.
Old 11-22-2018, 08:02 AM   #4 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Had a shop in Sacramento media blast the body and apply a ppg epoxy primer to protect. Got some rust spots to deal with but not too bad.
Old 11-22-2018, 08:07 AM   #5 (permalink)
Member # 181868
Sub'd
Project : Amphibious HEMTT
Old 11-22-2018, 08:09 AM   #6 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Boxed the frame and started mocking up the suspension. Got parts from ruffstuff specialties, Dan is awesome to work with and his products are top notch. Had a buddy help with the 3 link front and 4 link rear.
Old 11-22-2018, 08:13 AM   #7 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Did a little fender trimming, low as possible. Thinking 4 or 5” up travel on rear axle.
Old 11-22-2018, 08:18 AM   #8 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Notched the frame to try and squeeze in the shock towers. Needs more gussets and gotta figure out some wheel wells. The stock ones won’t fit anymore.
Old 11-22-2018, 07:40 PM   #9 (permalink)
Member # 84406
Subd! I've always wanted one of these...
WTF! Zombies! *blam* *blam* *blam* *blam* *blam* *blam* *blam* ........................ *blam
Pallister is offline   Reply With Quote Quick reply to this message
Old 11-23-2018, 08:43 AM   #10 (permalink)
Member # 278
sub'd
Who in Sac did your work? And if you don't mind, how much?
-1971 FJ55(aka Trail55): 6.0L-NV4500-LC split case, SOA, D60s, ARB'd... and cupholders
-1972 FJ55(aka Trail50): Turbo 5.3L-4L80-Blackbox-split case, D60s, ARB'd *stalled*
-1968 Mustang Fastback: not a restore but a refresh
Lil'John is offline   Reply With Quote Quick reply to this message
Old 11-23-2018, 08:51 AM   #11 (permalink)
Member # 181868
Looks like you need a taller garage.
Old 11-23-2018, 09:02 AM   #12 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Lil’John, I think it was BME or American Stripping Co. in Sacramento that did the blasting and primer. I think I paid $500-$700. TNT Powder coating in shingle spring has done some more recient work for me. Lance is easy to work with and quick turnaround time.
Old 11-23-2018, 09:05 AM   #13 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Waterhorse, definitely outgrew that garage. We’ve since moved and now I have a 30’x40’ shop with 12’ ceiling.
Old 11-23-2018, 09:24 AM   #14 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Removed toolbox and starting to remove Swiss cheese floors.
Old 11-23-2018, 05:13 PM   #15 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Got a newer piece of sheet metal back in the passenger side, a little surface rust.
Old 11-23-2018, 09:07 PM   #16 (permalink)
Member # 709969
axles
Looking good! Did you shorten the axles? Or do you know what WMS you're at?
Thanks
the1mavin is offline   Reply With Quote Quick reply to this message
Old 11-23-2018, 09:35 PM   #17 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
I think they are (14 bolt) is 67.5” and (front 60) is 69.25” both uncut.
Old 11-27-2018, 05:17 AM   #18 (permalink)
Member # 1056
I will be following this. I have redone a couple of them and frame swapped two. Looks great and I really like the size of the wagon. Just big enough to fit good size running gear etc. but small enough to fit through the trails.
Nice work. Looks great!
ToyotaJeep is offline   Reply With Quote Quick reply to this message
Old 11-27-2018, 07:07 AM   #19 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Thanks, any tips or tricks you have from working on wagons would be greatly appreciated.
Old 11-27-2018, 06:35 PM   #20 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Originally trying to set shocks like this....but that wasn’t going to work.
Some cut off wheels and plasma torch work to undo the frame French/notch.
Now maybe the shocks will fit better like this.
Old 11-28-2018, 07:56 PM   #21 (permalink)
Member # 202363
Subscribed I always wanted to build on of these. Keep up the great work.
zuzu is offline   Reply With Quote Quick reply to this message
Old 11-28-2018, 08:50 PM   #22 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
I’m in. First real wheeling I did was in one of these.
Old 11-28-2018, 08:55 PM   #23 (permalink)
49willys_mogon's Avatar
Member # 78325
As 73FJ says circle the wagons! Always great to see another one coming back from the clutches of the crusher. Really dig the maverick model.
49willys_mogon is offline   Reply With Quote Quick reply to this message
Old 12-06-2018, 02:00 AM   #24 (permalink)
Member # 55090
So glad you are building it with a low COG as they look comical up high!
The new shock tower position will be much stronger than the large cutout in the frame you had too.
1948 Willys PU using a 2008 Grand Cherokee Hemi donor
Gojeep is offline   Reply With Quote Quick reply to this message
Old 12-28-2018, 03:36 PM   #25 (permalink)
Newbie
4x4Yak's Avatar
Member # 212794
Found some more shop time today. Packaging issues. Recessed the frame and mocked up tower. Full extension just barely clears. Can’t get full compression, tire hits shock. Might try a 1.5” spacer then get wheels with correct backspacing.
