2004 Ford Super Duty F-250 axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-15-2019, 08:45 AM   #1 (permalink)
Member # 841969
I have been offered a set of super duty axles for my J20. They axles are setup correctly for my build.
Any warning that I should be aware of with these axles?
Anyone have any experience with them?
Any limitation on a j20?
Craig
craigibc is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 08:51 AM   #2 (permalink)
Member # 85771
The 50 stopped being used in 2003 right?
Make Forums Great Again!
Old 04-15-2019, 08:56 AM   #3 (permalink)
Member # 120478
When you say "set up correctly for my J20".... ?
Make sure the front is a 60, to the extent you think it is anyway. A lot of those era of superdutys have 50's. To the untrained eye, the 50 and the 60 can be hard to tell apart as they have the same 8 lug outers: hubs, brakes, etc.
Wheeler ->
90 Bronco with stuff
Dan90FSB is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 06:52 PM   #4 (permalink)
Member # 841969
From my research, the D50 stopped in 2003 and it should be a Dana 60 in 2004. I am still going to check for some ID to be sure.
As far as the setup I need a drivers side drop for my transfer case and the gearing is already 4.10 which is good for my rig as well.
It came stock with leaf springs like I am using on my truck.
I have looked into it alot this evening and it appears you can go manual locking hubs as well. Outside of the axle width which i might need to measure to see how that compares to the chevy axles I have now.
Craig
Old 05-18-2019, 06:04 PM   #5 (permalink)
JayMcJay's Avatar
Member # 111999
There are two quick and easy ways to tell if it's a 60 vs. a 50.
The first is the pinion nut will be 1 5/16" on a 60
The second is to look at the sticker on the rear surface of the passenger side axle tube. It should say 248 on it. 9.75"x25.4=248mm ring gear.
There was a blend of D50 and 60 used up thru 03. In 04 they should all be 60.
They're great axles with decent after market support. Run'em!
JayMcJay is offline   Reply With Quote Quick reply to this message
Old 05-18-2019, 06:18 PM   #6 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
The 50's are literally cast with a 50 on the top.
Action Fab is online now   Reply With Quote Quick reply to this message
Old 05-18-2019, 06:33 PM   #7 (permalink)
nkldrgr's Avatar
Member # 44053
Pre 2005 Dana 60s can be hard to install crossover steering arms.
It only take two things to fly: airspeed and money.
nkldrgr is offline   Reply With Quote Quick reply to this message
Old 05-18-2019, 06:37 PM   #8 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
JHF has that covered with a weld on kit now.
Similar Threads
FORD SUPER DUTY DANA 60 LOWER LINK MOUNTS MotoBilt Suspension 2 06-19-2018 06:44 AM
05+ Ford Super Duty Dana 60 Full Width Truss Kit TMR Customs Axles/Tires/Wheels 11 11-14-2017 08:42 AM
Brand new Reese Titan Class V Hitch Super duty trucks Narked Misc. Stuff For Sale 4 08-08-2014 11:44 PM
High steer for Super Duty Ford axles 2005-06 YjRyan Axles/Tires/Wheels For Sale 14 03-11-2013 09:36 AM
1999-2004 Ford Super Duty stub axles 1sicbronconut Axles/Tires/Wheels For Sale 0 11-12-2012 04:43 PM
