Flatty build "one piece at a time" - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-21-2009, 11:02 AM   #51 (permalink)
SVARAS's Avatar
Member # 9310
Originally Posted by 2003_ram View Post
And on other news I drew up a rough picture of what this beast should looke like when finished, all to scale, with the cage design I am planning on using for it. Cage will by 1 3/4" DOM, grill hoop will be 1 1/4" DOM. I don't have any fancy software so I do it by hand, here it is:
I see another Graham´s MB Clone
Keep on the good work !!
Graham´s
Mine
Yours
4WOR 2012 Ultimate Adventure Invited Reader
Willys MB LSX 2013
SVARAS is offline   Reply With Quote Quick reply to this message
Old 12-21-2009, 11:18 AM   #52 (permalink)
Member # 127313
But this one will be desert camo!
EDIT: Damn that's funny, the picture I drew looks a hell of a lot like the first picture you posted of Grahams!
[COLOR="Red"]Nobama[/COLOR], I don't mind working for my money, you shouldn't either.
Willys Build
[I]
“If you don't have time to do it right, when will you have time to do it over?”[/I] - John Wooden [B]RIP[/B]
[I]"Let every man have a pistol, instead of one man have a tank."[/I]
2003_ram is offline   Reply With Quote Quick reply to this message
Old 12-21-2009, 06:41 PM   #53 (permalink)
Member # 127313
Okay, got a lot done today. I boxed the center passenger side of the frame. I used the same thickness material as the frame (12 gauge) as should always be done (but I had what I had with the front end) and stitch welded it. Came out pretty nice! I have to do the driver side and the bottom side of the passenger. Let me know what you guys think.
Willys Build
[I]
Old 12-21-2009, 06:50 PM   #54 (permalink)
Member # 127313
I also threw those boggers on the front of my CJ I'm doing a disk brake swap on, looks a little funky with 2" wheel spacers!
Willys Build
[I]
Old 12-22-2009, 08:40 PM   #55 (permalink)
Member # 127313
Got a better weld on it today. Bad thing is it poured down rain when I was done, so I gotta scrape the rust off tomorrow.
Willys Build
[I]
Old 12-23-2009, 06:56 PM   #56 (permalink)
95 Why J's Avatar
Member # 141308
Nice drawing! That's going to look good when you're all done.
95 Why J is offline   Reply With Quote Quick reply to this message
Old 12-23-2009, 08:18 PM   #57 (permalink)
Member # 127313
Thanks! I can't wait to get the chassis rolling! Then onto body work, which will be a hoot. Thanks for the complement man!
Willys Build
[I]
Old 12-27-2009, 08:29 PM   #58 (permalink)
Member # 124889
Looks great. I always love the willy..
Not hardcore enough for the tall curbs at the mall.
MechAddict is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 09:00 PM   #59 (permalink)
Member # 127313
Thanks man.
Willys Build
[I]
Old 12-29-2009, 08:07 AM   #60 (permalink)
Member # 127313
Okay little update, front axle will be coming back 2 weeks from now (well maybe get it back before then, but won't be finished until 2 weeks).
I got a RBD-050 Bender, god I love Santa. I also picked up the last stick of 1 3/4".120 DOM tubing at the metal yard. I'll use 5' of it to practice bending with. This week I am also going to install the ARB in the rear axle. I am up in the air right now on whether I should truss the rear axle while I'm at it, I would use the 1 3/4".120 tubing for it? And of course ARC weld it.
Willys Build
[I]
Old 01-06-2010, 10:02 PM   #61 (permalink)
Member # 127313
Got the front axle back cut down to 58 1/2" WMS from 67". Came out GREAT. Mooge ball joints, 4:88 R/P, ARB. The rest I cam setting up. Waiting for the shafts from Alloy USA to come in (2 weeks) and then it goes under the Jeep.
Willys Build
[I]
Old 01-07-2010, 09:03 PM   #62 (permalink)
Member # 127313
Got my transfercase coming, it's a 1980 D300. I got the 1980 model because it has the shorter rear shaft making it so I gained 1 1/8" rear driveshaft length, which in a rig THIS SHORT I need everything I can get. When we get the case, we'll go with JB conversions 4:1 kit. Also should be getting my transmission tomorrow. Almost have everything I need for the jeep, now it's finding the time to throw this shit together.
Willys Build
[I]
Old 01-07-2010, 10:58 PM   #63 (permalink)
WildWilly4x4's Avatar
Member # 17680
If you end up needing a stouter output( I did, running the same short shaft as you), get the Novak ultra short 32 spline output for the rear......You will gain about another inch and a half...but its about the $450 range.....I went through two of the stock outputs before they were able to get the production ultra short kit to me.
'50 m38, 60, 14bolt, 4.3, 420, dana 300, 35" krawlers on trailready's/ '80 Blazer 60,14 bolt, tpi 350, th400, 205, 35" swampers
Link to my M38 build:
WildWilly4x4 is offline   Reply With Quote Quick reply to this message
Old 01-07-2010, 11:40 PM   #64 (permalink)
CRO
Member # 7588
willys look
this
or this
1948 Willys
1952 M37CDN Powag
CRO is offline   Reply With Quote Quick reply to this message
Old 01-08-2010, 06:26 AM   #65 (permalink)
Member # 127313
Should I have gotten the longer rear shaft version if I cam going to replace that part anyways? I paid $100 more for the short shaft.
CRO, that willys is the same look I am going for, military looking but heavy duty. I decided to paint the frame and all those pices the army color, trying to talk my dad into going flat military paint all around. If you look at my profil picture it's the same willys!
Willys Build
[I]
Old 01-08-2010, 09:30 AM   #66 (permalink)
Member # 17680
No, Thats the cool thing about Novak's kit, it fits any 300 case, factory long or short.....it has both patterns on it.
Old 01-25-2010, 07:03 PM   #67 (permalink)
Member # 127313
If I break the short shaft than I'll get novaks, I'll give it a go there as is.
Oil was nasty. Shafts are pitted, so I am going to 35 splien shafts, axles weak point will be the 8.5" Ring Gear, but with 35's this little jeep will be bomb proof. Pulled the R/P earlier tonight. Tomorrow I hope to finish the frame and rear bumper.
Willys Build
[I]
Old 01-26-2010, 04:48 PM   #68 (permalink)
Member # 17967
Keep going
Your build reminded me of mine. But you need more lug nuts...
I recommend a Rear HP 60 Detroit and 33's. 5.0 EFI, NP435. Yeah, it fits.
jamesroney is offline   Reply With Quote Quick reply to this message
Old 01-30-2010, 05:35 PM   #69 (permalink)
Member # 127313
Nice rig! Anymore pics? I like the 5 5.5 because it swaps with my other Jeeps.
Willys Build
[I]
Old 02-01-2010, 07:05 PM   #70 (permalink)
Member # 17967
Sure.
More Pics??? Sure...I have TONS. (excuse the pun!)
PM me and I can e-mail them to you.
Old 02-01-2010, 09:49 PM   #71 (permalink)
Member # 127313
Pm'd.
Willys Build
[I]
Old 02-03-2010, 07:02 AM   #72 (permalink)
Member # 130014
Originally Posted by CRO View Post
this
Honegger's old coil-sprung flatty right?
:D
SKULLYOTA is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 03:20 PM   #73 (permalink)
Member # 103510
I like this look, what type of set-up, i.e. example: axles, lift, model (5 or 7), year and etc. is this CJ? Thanks!
TennFire-1521 is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 03:21 PM   #74 (permalink)
Member # 103510
Old 02-06-2010, 12:22 PM   #75 (permalink)
Member # 127313
It's a '76 cj7, D30 front in that picture and M20 rear with 2" spacers. Lift is a worn out SOA. It's been a great Jeep, never had one issue with it running hard trails (though driving experience goes a long ways).
Willys Build
[I]
