Pirate4x4.Com : 4x4 and Off-Road Forum (https://www.pirate4x4.com/forum/index.php)
-   The Job Shop (https://www.pirate4x4.com/forum/forumdisplay.php?f=273)
-   -   Machine work (https://www.pirate4x4.com/forum/showthread.php?t=1645961)
Brian Ellinger 02-24-2014 05:21 PM
Machine work
295 Attachment(s)
If you need something machined, milled, turned, welded etc....
We can do one-offs and production parts, let us know what you are looking for.
We do:
4340 axle shafts and short little stub shafts for unique adapters
CNC milling
turning
MIG and TIG welding
All sorts of things you'd expect to see come from a machine shop!
I will need a drawing of the part you need made to get a starting point and a quote made up. Hand drawings can be used.
BigChevyScott 03-08-2014 02:48 PM
Whats the quickest turn around on some 4340 shafts,
I have need some custom cut shafts ASAP,
THX
Brian Ellinger 03-10-2014 09:35 AM
295 Attachment(s)
THX
PM sent
Arya Ebrahimi 03-15-2014 11:03 AM
483 Attachment(s)
Not an immediate need, but is an adapter shaft within your range of capabilities? Basically blind female splines on one end and a male splined shaft on the other?
cj8scrambld 03-22-2014 04:41 PM
Machining my D300 bearing retainer per JB Conversion specs for the HD shaft?
Last page:
http://www.jbconversions.com/pdf/15-1103.pdf
Brian Ellinger 03-24-2014 11:34 AM
295 Attachment(s)
We can do the d300 front output machining. To make things less costly, Id like to build a jig setup, and then run a few at a time, even just 3 per run. Ill look into it closely, and get you a price thru PM.
yankee19934 04-10-2014 07:30 PM
Quote for resplining two long side ford 60 shafts after taking off about 4". Both 35 spline, one alloy and one stock. They will be marked for you to cut, and then spline. I dont have anything that can cut that clean.
Cj-
cj8scrambld 04-30-2014 06:23 PM
Uhh...any update?
Brian Ellinger 05-19-2014 01:16 PM
295 Attachment(s)
Thanks to our new customers!
As for the D300 output, just not enough interest at this time.
rabbiporkchop 05-05-2015 02:57 PM
I need a couple shims made. I can send 1 as a template. both need to be machined at a different angle.
These are specifically for the 5-bolt 1979 Ford F250 Dana 44 knuckle and are currently unavailable.
http://www.expeditionportal.com/foru...1&d=1430762394
http://www.expeditionportal.com/foru...2&d=1430762423
http://www.expeditionportal.com/foru...3&d=1430762444
http://www.expeditionportal.com/foru...4&d=1430776550
Brian Ellinger 06-02-2015 12:22 PM
1 Attachment(s)
Custom bore size Full Float rings. These are for a Dana 44 6 bolt spindle. These are for a ford 9" rear axle, we can then cut double spline 31spline to Dana 44 30 spline axle shafts. We'll be releasing bolt on full float adapter flanges shortly to convert any big bearing or small bearing ford 9" rear axle to full float as well! This even allows an easy way to convert to a Chevy or Toyota 6on 5.5 bolt pattern!
We've been making this style ring for well over 12 years! Frontrangeoffroadfab.com Diamondaxle.com
Brian Ellinger 04-28-2016 09:31 AM
using this forum correctly
Brian Ellinger 08-26-2016 04:38 PM
happy to quote that new project. Need production or prototype before production, we can do it
Brian Ellinger 09-08-2016 04:18 PM
As youve noticed, we dont post up what we're doing for others! Be assured complete confidentiality!
ltrail 10-28-2016 10:12 PM
Approximate cost to shorten and respline a pair of shafts?
Diablo Blanco 10-31-2016 10:11 PM
Are you up for making a steering stem for a motorcycle?
enginetech 12-09-2016 06:33 PM
Looking for drive slugs for 05 up super duty Dana 60 to fit ouverson 47 spline axles
Brian Ellinger 12-10-2016 08:46 AM
We can make anything, with a drawing
Brian Ellinger 12-10-2016 08:47 AM
Ill see what we can do on these
0ILBURNER 12-13-2016 09:32 AM
Originally Posted by Arya Ebrahimi (Post 24667177)
...blind female splines on one end and a male splined shaft on the other?
I am in the market for one of these - can you do eeet?
Brian Ellinger 12-13-2016 09:36 AM
Can, yes
cheap, no
Blind female is a particularly long setup. Shoot us a drawing, with all specs, and we can get a quote. Need specs on splines, pressure angle etc.
enginetech 01-21-2017 02:54 PM
Did you figure out if you could make drive slugs for 05 up super duty UB's for 47 spline ouverson axles?
Brian Ellinger 01-24-2017 09:25 AM
We can, we're going to need to make a decent size batch to justify them. Likely 2 months out on 35,40,47 spline options
enginetech 03-18-2017 06:32 PM
Any progress on the 47 spline drive slugs for 05 up Super Duty UB's?
natethegreat2 04-06-2017 09:51 AM
Dana 60 pinion cover
can you quote me on the cost of QTY 2 machined pieces to make a Dana 60 pinion guard (Mild steel) or what you recommend. I just want to get the block of metal machined and I can take care of the rest. block of 1in machined to fit over the pinion then machined in the back to fit over the oil passage. I can take care of the drilling and tapping and also cutting it in half. Then I can bend up some plate and weld it to it. i can get you more specific measurements and also a drawing if we go forward with it.
http://i1308.photobucket.com/albums/...psegofirxi.jpg
