Machine shop and Broaching - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > The Job Shop
Old 10-21-2015, 08:26 PM   #126 (permalink)
onetoncv's Avatar
Member # 2160
These flanges and companion flanges we made for a quick change differential to custom dimensions. This flange system allows my customer to achieve 38 degrees and have one ton rated parts off the rear axle. In his race car this allows the diff to slide, and makes it faster around the corners. They're on there way to Australia right now
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 10-22-2015, 06:47 AM   #127 (permalink)
Member # 41097
Random question for you as I ponder the wonders of the universe and how to keep my truck as light as possible. Can/could you build parts for a chain driven drop box? That is, 4 flanged yokes for 1.75" 10 spline shaft, 2 1.75" dia 10 spline shafts, and splined double or triple 80 sprockets (or just the collars for a weld on sprocket)?
81' International S1724 DT466 toyhauler w/fun parts
96' Ranger: kings, EMF parts, 800hp SBF
mustange70 is offline   Reply With Quote Quick reply to this message
Old 10-22-2015, 07:27 AM   #128 (permalink)
onetoncv's Avatar
Member # 2160
I think that would be possible but the time involved is not reality. I would venture to 2" 10 splines instead of 1 3/4 .
530-877-2875
Old 10-22-2015, 01:35 PM   #129 (permalink)
Member # 41097
Cool, I'll be in touch when I'm ready to do this.
Thanks.
Old 11-06-2015, 10:18 AM   #130 (permalink)
onetoncv's Avatar
Member # 2160
Working with some new parts when 1480 is not enough for you. These parts are aprox 5 ton rated , We are working on a new rockbouncer quote for this new hardware. The U joints alone weigh 3 lbs ,versus 1480 at 1.7 lbs
530-877-2875
Old 11-18-2015, 06:23 PM   #131 (permalink)
Member # 216998
Dana Spicer pinion brake
I am in need of a e-brake for the truck I am building, I can locate it on the Dana / Spicer 19060S axle or on the Allison 3060 transmission. The axle is easier since there are already bolt holes to mount to. Have you already done something like this? I sent you a PM with my number so we can discuss in more detail.
1939dodge is offline   Reply With Quote Quick reply to this message
Old 11-18-2015, 07:36 PM   #132 (permalink)
onetoncv's Avatar
Member # 2160
pm sent
530-877-2875
Old 12-10-2015, 07:33 AM   #133 (permalink)
onetoncv's Avatar
Member # 2160
another lathe coming on line after a 25 year sleep. #4 swazey.
https://youtu.be/Yjf026WGyRg
530-877-2875
Old 12-27-2015, 09:02 PM   #134 (permalink)
Member # 99982
Any update on Spicer lockouts broaching?
Have a set I'm wanting to get done and looking for direction on someone who does this anymore
90 YJ 4.0top-end 103wb 79Ford60/shaved14 np435/d300 h1's-SXs
BUILTnotBOT is offline   Reply With Quote Quick reply to this message
Old 12-28-2015, 11:06 AM   #135 (permalink)
onetoncv's Avatar
Member # 2160
It would take a minimum order of around 50 sets to make it worth it. Jess
530-877-2875
Old 12-29-2015, 02:28 PM   #136 (permalink)
onetoncv's Avatar
Member # 2160
making dana 80 billet flanges
530-877-2875
Old 01-14-2016, 08:32 AM   #137 (permalink)
onetoncv's Avatar
Member # 2160
Dana 80 stuff out to heat treat
530-877-2875
Old 01-20-2016, 09:41 AM   #138 (permalink)
onetoncv's Avatar
Member # 2160
dana 80 heat treated flange
530-877-2875
Old 01-28-2016, 10:14 AM   #139 (permalink)
onetoncv's Avatar
Member # 2160
bump
530-877-2875
Old 02-02-2016, 11:29 AM   #140 (permalink)
onetoncv's Avatar
Member # 2160
doing more 31 spline yokes
530-877-2875
Old 02-10-2016, 12:05 PM   #141 (permalink)
Member # 235007
I really need to call... about drive shafts, but flanges too.
Ever do any Unimog pinion flanges. 1.7-ish maj dia 21 spline. Splines look like gear teeth vs squares like 10 spline stuff vs triangles like stuff with a higher spline count. If that makes sense.
Bluemoose1 is offline   Reply With Quote Quick reply to this message
Old 02-11-2016, 09:48 AM   #142 (permalink)
onetoncv's Avatar
Member # 2160
we have not done unimog flanges yet
530-877-2875
Old 02-17-2016, 10:13 AM   #143 (permalink)
onetoncv's Avatar
Member # 2160
made lots of parts on this shaft
530-877-2875
Old 02-22-2016, 02:59 PM   #144 (permalink)
onetoncv's Avatar
Member # 2160
We now offer a full line of 1480 forged U bolt yokes , applications include the 32 spline Atlas , and 205 , along with 14 bolt differentials , and the popular 34 spline titan NWF upgraded outputs. Prices start at 225.00.
530-877-2875
Old 03-08-2016, 08:42 AM   #145 (permalink)
onetoncv's Avatar
Member # 2160
Our new flyer
Old 03-08-2016, 10:02 AM   #146 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
Do you have the ability to anneal/reharden before and after broaching?
Would it possible for you to broach this input gear to standard GM 32-spline from the original Rover 10-spline?
Hoarder of Land Cruisers, wheeler of none.
Arya Ebrahimi is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 02:37 PM   #147 (permalink)
onetoncv's Avatar
Member # 2160
we don't have the gm th-400 32 spline. Jess
530-877-2875
Old 03-08-2016, 04:27 PM   #148 (permalink)
Member # 7876
What about Dodge 29 spline?
Old 03-08-2016, 08:45 PM   #149 (permalink)
onetoncv's Avatar
Member # 2160
not that one either , the cutters are made for higher production use , They can vary from 1500 to 5 grand . I have the 34 spline for the allison . Jess
530-877-2875
Old 03-09-2016, 07:46 PM   #150 (permalink)
onetoncv's Avatar
Member # 2160
just added our new 1480 fixed midship .
530-877-2875
