Machine shop and Broaching - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > The Job Shop
Old 03-17-2016, 12:06 PM   #151 (permalink)
onetoncv's Avatar
Member # 2160
These are our 10 bolt and 12 bolt to Toyota conversion flanges. Prices starting at 159.00. Using factory Toyota bolts.
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 03-24-2016, 05:29 AM   #152 (permalink)
onetoncv's Avatar
Member # 2160
Bump
Old 03-28-2016, 04:44 PM   #153 (permalink)
onetoncv's Avatar
Member # 2160
1480 ultimate flanges
530-877-2875
Old 03-29-2016, 05:47 AM   #154 (permalink)
Member # 53677
I have a strange one...
I need two steel sleeves turned on a lathe. Needs to be 7/8" OD and 3/4" ID about 4" long (or two of them about 2" long each)...I can verify exact length this evening; but is this something you can make?
Its thin...I know; but I just need it to sleeve a bolt inside another piece of tube.
thanks!
2017 JK Buggy / LQ9 / Solid Mfg HP60 / 14bolt / 42" Maxxis / Method Wheels / Radflo
IG: @partiallycommittedracing
slravene is offline   Reply With Quote Quick reply to this message
Old 03-29-2016, 07:07 AM   #155 (permalink)
Member # 156511
Originally Posted by onetoncv View Post
Were going to run a couple quick sales , The first is our Dana 60 to Toyota flange on sale for 85.00.
The 2nd will be our Dana 44 to Toyota flange there on sale for 80.00.
The 3rd our 32 spline to Toyota flange in c/v and non cv patterns for 89.00.
We will run this for 5 of each then its back to normal pricing first come first serve.
I need toyota flanges for a Dana 60 and Sterling long pinion.
mavereq is offline   Reply With Quote Quick reply to this message
Old 03-29-2016, 11:25 AM   #156 (permalink)
onetoncv's Avatar
Member # 2160
thanks!
We should be able to do that . Jess
530-877-2875
Old 03-29-2016, 11:25 AM   #157 (permalink)
onetoncv's Avatar
Member # 2160
we make both , call for pricing . Jess
530-877-2875
Old 03-29-2016, 11:44 AM   #158 (permalink)
Member # 53677
PM sent
Old 03-31-2016, 09:09 AM   #159 (permalink)
onetoncv's Avatar
Member # 2160
pm sent .Jess
530-877-2875
Old 04-01-2016, 01:43 PM   #160 (permalink)
onetoncv's Avatar
Member # 2160
New for spring 2016 we now offer a full line of 14 bolt full float yokes from 1350 - 1410 -and now 1480 series in our forged yokes series. The 1480 yoke part # is 148014b prices start at 245.00
530-877-2875
Old 04-21-2016, 08:50 AM   #161 (permalink)
Member # 400633
Can you respline a D44 TrueTrac diff spider gear from 30 spline to 35 spline to accept D60 35 spline shafts?
CobraMarty is offline   Reply With Quote Quick reply to this message
Old 04-21-2016, 09:57 AM   #162 (permalink)
onetoncv's Avatar
Member # 2160
don't have that broach
530-877-2875
Old 04-21-2016, 10:08 AM   #163 (permalink)
Member # 400633
thanks.
Old 04-30-2016, 09:01 AM   #164 (permalink)
onetoncv's Avatar
Member # 2160
Our new 32 spline 1480 forged yokes now available
530-877-2875
Old 06-08-2016, 10:44 AM   #165 (permalink)
onetoncv's Avatar
Member # 2160
Making 241 brackets today
530-877-2875
Old 06-27-2016, 06:31 PM   #166 (permalink)
Curly's Avatar
Member # 20205
Did you ever get into broaching the Spicer 30 spline hubs out to 35 spline?
KI6PPU
It's very black and white. It becomes Gray when you give quarter....
Curly is offline   Reply With Quote Quick reply to this message
Old 06-28-2016, 09:34 AM   #167 (permalink)
onetoncv's Avatar
Member # 2160
no were not doing those right now
530-877-2875
Old 07-01-2016, 12:10 PM   #168 (permalink)
onetoncv's Avatar
Member # 2160
Our newer lathe coming in to keep up with production
530-877-2875
Old 08-09-2016, 10:16 PM   #169 (permalink)
Member # 695897
How long is this shaft and is it chevy 32 spline output?
Eller46 is offline   Reply With Quote Quick reply to this message
Old 08-10-2016, 08:47 PM   #170 (permalink)
Member # 695897
I'm interested in the shaft that you use in your 241c SYE how long is it? And what are the output splines? Also have you ever built a 241c/205 doubler? Or parts for one?
Old 08-15-2016, 11:40 AM   #171 (permalink)
onetoncv's Avatar
Member # 2160
It uses the stock output speedo housing shortens the case up around 4" Its a 32 spline output , have not done anything on the 241 doubler yet. Jess
530-877-2875
Old 09-01-2016, 08:57 AM   #172 (permalink)
onetoncv's Avatar
Member # 2160
Made this flange for a tractor, it fits a Dana 44 that was not available. We were able to replicate it and get this tractor back to work.
530-877-2875
Old 09-15-2016, 10:59 AM   #173 (permalink)
onetoncv's Avatar
Member # 2160
bump
530-877-2875
Old 09-15-2016, 07:08 PM   #174 (permalink)
onetoncv's Avatar
Member # 2160
1480 ultimate flanges for hero cases and dana 80's going out along with our machined 1480 billit midship
530-877-2875
Old 10-10-2016, 03:45 PM   #175 (permalink)
Newbie
Member # 688362
Not sure how smart it even is or if it's possible but can you open up and respline a set of Dana 44 Yukon Grizzly Locker side gears to 35 spline..? Trying to build a 44/60 hybrid front axle with JK Dana 44 rear ring and pinion, 35 spline shafts, and Kingpin 60 outers. Any help appreciated.
Tried to PM but you were full up.
M390 is offline   Reply With Quote Quick reply to this message
