Full CNC machine shop - Bill Baird Motorsports - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > The Job Shop
Old 08-15-2014, 01:11 PM   #1 (permalink)
Member # 490377
Bill Baird Motorsports works in partnership with Saturn Machine of Sturgis, KY. Check out our capabilities and let us know what projects your business may be interested in pursing with BBM.
Amada LC-4020F1NT
Saturn Machine & Welding offers an array of services to fulfill manufacturing needs by utilizing our state of the art facility and cutting edge equipment, including:
Amada LC-4020F1NT Laser
Faster piercing and cutting by using linear drives in all three axes
Superb cutting quality with sharp corners with the following thicknesses and materials:
Aluminum up to 0.5 inches thick
Stainless Steel up to 0.5 inches thick
Mild Steel up to 1.25 inches thick
Glass and many other materials. Call for more information.
High productivity at lower running costs through our ECO cut process
Stable cutting and increased productivity using WACS™ (Water Assisted Cutting System)
Twin-Adaptive Optics to eliminate the need for lens changing
Cut Process Monitoring improves process time and part quality by pierce detection and by monitoring cut process
Flexible design options: a fully accessible enclosure and choice of right- or left-hand layout
Amada HDS 2204NT
Amada HDS 2204NT Press Brake
Hybrid drive system incorporates AC servo motor driven bi-directional, high efficiency pumps providing high speed ram movement and super accurate ram repeatability. This advanced design offers quick setup, high-speed operation, and increased throughput.
CNC controlled hydraulic cylinders located in lower beam eliminate tool shimming due to ram deflection.
The Windows XPe embedded, touch screen control provides for transfer of tool setup data, bend sequences, and 3D simulation between control and network server.
Super accurate, high speed 5-axis backgauge reduces positioning time and easily handles staging of complex parts.
Optional Dr. ABE Bend off-line programming software further increases the high productivity offered by the HDS 2204NT press brake.
243-ton capacity
168.5″ maximum bend length
148″ distance between frames
20.47″ open height
9.84″ stroke
17.1″ throat
0.00004″ ram repeatability
Haas HS-3R
Haas HS-3R Horizontal Machining Center
Haas Automation, Inc. HS-3R Horizontal Machining Center; 150″ x 50″ x 60″ (3810 x 1270 x 1524 mm), 50-taper geared-head, 30 hp (22.4 kW) vector drive, 5000rpm, built-in 4th axis, 38-tool side-mount tool changer, color remote jog handle, 2nd home button, X-axis linear scales, 1 MBprogram memory, 15″ color LCD monitor, USB port, memory lock keyswitch, rigid tapping and 95-gallon (360 liter) flood coolant system.
Haas SL-30
Haas SL-30 CNC Lathe
Haas Automation, Inc. SL-30 CNC Lathe, with a max turning capacity of 17″ x 34″ and a 10″ chuck, has a bar capacity of up to 3.0″.
Haas SL-40
Haas SL-40 CNC Lathe
CNC Lathe; 25.5″ x 44″ (648 x 1118 mm) max capacity, 40″ (1016 mm) swing, 40 hp (30 kW) vector drive, 2400 rpm, 2-speed gearbox, A2-8 spindle, 15″ (381 mm) chuck, 10-station bolt-on turret, 15″ color LCD monitor, memory lock keyswitch, USB port and rigid tapping. Standard toolholder kit included with BOT or Hybrid turret.
Haas VF-3
Haas VF-3 Vertical Machining Center
Vertical Machining Center; 40″ x 20″ x 25″ (1016 x 508 x 635 mm), 40 taper, 20 hp (14.9 kW) vector drive, 7500 rpm, 20-station carousel tool changer, 1000 ipm (25.4 m/min) rapids, 1 MB program memory, 15″ color LCD monitor, USB port, memory lock keyswitch, rigid tapping and 55-gallon (208 liter) flood coolant system.
Haas VS-3
Haas VS-3 Vertical Machining Center
Vertical Machining Center; 150″ x 50″ x 50″ (3810 x 1270 x 1270mm), 50-taper geared-head, 30 hp (22.4 kW) vector drive, 7500 rpm, 30+1 side- mount tool changer, color remote jog handle, 2nd home button, 15″ color LCD monitor, USB port, memory lock keyswitch, rigid tapping and 95-gallon (360 liter) flood coolant system.
[COLOR="YellowGreen"]
7/31 - 8/2 Sturgis, KY
| (270) 333-2324
[/COLOR]
BBM5252 is offline   Reply With Quote Quick reply to this message
Old 08-15-2014, 05:16 PM   #2 (permalink)
MC
Nose to grindstone
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
Great capacity
MFGS of the STAR-LAB CNC machines
The finest CNC plasma tables
Made in the USA by Bulltear and can be found online at
and at local welding stores
Hypertherm and Thermal Dynamics
We also make parts for AMC
MC is offline   Reply With Quote Quick reply to this message
Old 08-21-2014, 06:11 AM   #3 (permalink)
Made in USA
Nalin400m's Avatar
Member # 111402
Originally Posted by MC View Post
Great capacity
LinkedIn:
Email:
Website:
Facebook:
Nalin400m is offline   Reply With Quote Quick reply to this message
Old 08-21-2014, 06:27 AM   #4 (permalink)
Member # 490377
Let us know what types of products your company would like to add and how our capabilities can benefit you. Call for quotes.
| (270) 333-2324
[/COLOR]
Old 08-25-2014, 08:14 AM   #5 (permalink)
Member # 490377
When only the best will do.
Call for very competitive pricing.
| (270) 333-2324
[/COLOR]
Old 09-03-2014, 08:46 AM   #6 (permalink)
Member # 490377
Give us a call to see what all we can do for you.
| (270) 333-2324
[/COLOR]
Old 09-30-2014, 08:42 AM   #7 (permalink)
Member # 490377
Brand new CNC lathe ready to make parts for you. Give us a call.
| (270) 333-2324
[/COLOR]
Old 10-08-2014, 09:00 AM   #8 (permalink)
Member # 490377
Don't forget to check out our Facebook to keep up with what's happening in the shop:
https://www.facebook.com/BillBairdMotorsports
| (270) 333-2324
[/COLOR]
Old 10-17-2014, 01:09 PM   #9 (permalink)
Member # 490377
What are you outsourcing? Give us a shot to beat your current manufacturer. You'll be impressed with the quality and price.
| (270) 333-2324
[/COLOR]
Old 10-18-2014, 07:30 AM   #10 (permalink)
onetoncv's Avatar
Member # 2160
Looks like your going for it . Got any pic's of the machines doing there job ?
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 10-20-2014, 12:54 PM   #11 (permalink)
Member # 490377
Saturn Machine | Steel Fabrication & Machining | Laser Processing | Sandblasting
| (270) 333-2324
[/COLOR]
Old 10-30-2014, 05:31 PM   #12 (permalink)
rugburn's Avatar
Member # 45
We are swamped here with work and have a few LARGE plates to machine.
I will email an IGES file for quote.
John
John Runberg
Swedish American :usa:
rugburn is offline   Reply With Quote Quick reply to this message
Old 10-30-2014, 06:08 PM   #13 (permalink)
Member # 377394
I had the opportunity to tour their shop. Nothing but top quality and precision. They do multimillion dollar contracts worldwide. If you need something done, they have the capability to do it, and with a fast turn around time!
SVT
RangerSVT is offline   Reply With Quote Quick reply to this message
Old 10-31-2014, 06:39 AM   #14 (permalink)
Made in USA
Nalin400m's Avatar
Member # 111402
SVT
x2
LinkedIn:
Email:
Website:
Facebook:
Old 11-03-2014, 06:33 AM   #15 (permalink)
Member # 490377
Appreciate all the job requests from the Pirate community.
| (270) 333-2324
[/COLOR]
Old 11-05-2014, 08:01 AM   #16 (permalink)
Made in USA
Nalin400m's Avatar
Member # 111402
Give them a call. Great service every time.
LinkedIn:
Email:
Website:
Facebook:
Old 11-05-2014, 12:46 PM   #17 (permalink)
rugburn's Avatar
Member # 45
I'll see you guys on Friday morning !!!!
John Runberg
Old 11-06-2014, 08:04 AM   #18 (permalink)
Member # 490377
Looking forward to meeting you and very appreciative for the opportunity.
| (270) 333-2324
[/COLOR]
Old 11-09-2014, 10:45 AM   #19 (permalink)
rugburn's Avatar
Member # 45
First class shop and crew !
Looking forward to sending more work to you
John Runberg
Old 11-10-2014, 05:42 AM   #20 (permalink)
Member # 490377
Thanks looking forward to working with you;
we appreciate the opportunity.
| (270) 333-2324
[/COLOR]
Old 11-18-2014, 01:59 PM   #21 (permalink)
rugburn's Avatar
Member # 45
Bling Blang.....My project is coming together
John Runberg
Old 05-05-2015, 02:59 PM   #22 (permalink)
rabbiporkchop's Avatar
Member # 181404
I need a quote on 2 of these machined at different angles
These are specifically for the 5-bolt 1979 Ford F250 Dana 44 knuckle and are currently unavailable.
95 solid axle Tahoe with LM7 swap
rabbiporkchop is offline   Reply With Quote Quick reply to this message
Old 04-06-2017, 09:55 AM   #23 (permalink)
Member # 232237
Dana 60 pinion cover
can you quote me on the cost of QTY 2 machined pieces to make a Dana 60 pinion guard (Mild steel) or what you recommend. I just want to get the block of metal machined and I can take care of the rest. block of 1in machined to fit over the pinion then machined in the back to fit over the oil passage. I can take care of the drilling and tapping and also cutting it in half. Then I can bend up some plate and weld it to it. i can get you more specific measurements and also a drawing if we go forward with it.
natethegreat2 is offline   Reply With Quote Quick reply to this message
