Anti-Rock sway bar to Defender! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-18-2012, 08:28 AM   #1 (permalink)
Member # 103918
Question is, does anyone ever fitted a currie anti -rock sway bar to a defender???
Is there a thread or pictures somewhere?
Thanks in advance
josecamorim is offline   Reply With Quote Quick reply to this message
Old 12-18-2012, 09:43 AM   #2 (permalink)
Member # 13683
Yes! No!
K.C.
Puffdragon is offline   Reply With Quote Quick reply to this message
Old 12-24-2012, 10:59 PM   #3 (permalink)
Member # 11256
there's gotta be a pic somewhere of frankenrover's. Didn't doc what's his nuts in Dallas also have one on his 90 at one point? Think it was documented on d90.com. So search here for frankenrover build up and then check d-90.com for it.
-ben
m016324 is offline   Reply With Quote Quick reply to this message
Old 03-05-2013, 08:13 AM   #4 (permalink)
Member # 265042
The standard Defender sway-bars are about the same torsional stiffness as a Currie anti-rock bar - so you may as well just fit one of those!
The front suspension, by virtue of it's geometry has a lot of anti-sway built in - so doesn't really need any extra unless you want to change the on-road handling.
We've gone down the route of making unlockable rear bars (disconnects) which give you much better handling on the road but maintain as much articulation as possible off road. However, I appreciate Currie's point of view that you are sometimes better with a balanced vehicle even if the resistance to articulation is increased a little. If nothing else, it makes it less frightening to drive!
Si
X-Eng is offline   Reply With Quote Quick reply to this message
Old 03-05-2013, 09:31 AM   #5 (permalink)
Member # 13683
Stock rover away bar performs nothing like the antirock.
Proper use of sway bars is very important and should be used on most any rig. The sway bars from the factory will not perform the same as an aftermarket. You must tune your aftermarket sway bar to your suspension.
K.C.
Old 03-05-2013, 11:36 AM   #6 (permalink)
Member # 43371
Originally Posted by Puffdragon View Post
Yes! No!
No! Yes!
Can't remember if it was custom made or Currie's...
"Trapped in time. Surrounded by evil. Low on gas."
Custom car-toons >
rockbuggies welcome!
Michele is offline   Reply With Quote Quick reply to this message
Old 03-05-2013, 06:00 PM   #7 (permalink)
Member # 69597
I have one on mine but its a maengineering.net one. Search here for defender rollover rebuild you will see the install on there. It works money!!
97 D-90, 102 " [QUOTE=Buckon37s;10043598]Stop being a giant vagina. This is pirate..[/QUOTE]
- gone fishin!!
- D-90 build
- Disco truggy-rip
mightymg1 is offline   Reply With Quote Quick reply to this message
Old 03-25-2013, 08:58 AM   #8 (permalink)
Member # 103918
Thanks everyone for helping, specially Puffdragon
Old 03-25-2013, 06:16 PM   #9 (permalink)
Member # 150724
Yep, but he doesn't have any more & that URL is now dead, btw
Landy_Andy is offline   Reply With Quote Quick reply to this message
Old 03-25-2013, 07:56 PM   #10 (permalink)
Buckon37s's Avatar
Member # 20394
Actually I have about 5 and I'm dumping them cheap.
[I]BUCK[/I] Wild Racing
Team 911
Thank you all for your support
Widia Cutting Tools
Sterling Autosport
PSC
Ruffstuff
Tom Woods Drive Shafts
Buckon37s is offline   Reply With Quote Quick reply to this message
Old 03-25-2013, 10:38 PM   #11 (permalink)
Member # 150724
Drop us a PM with price & what u have, thanks.
Old 03-26-2013, 12:25 AM   #12 (permalink)
Member # 57981
As above if you wouldn't mind
Letzroll Offroad Racing UK #4817
www.letzrolloffroad.com
RedlineMike is offline   Reply With Quote Quick reply to this message
Old 03-26-2013, 07:42 AM   #13 (permalink)
Member # 9461
You can sort of see it in this pict. We ran it through the crossmember.
The Frankenrover Saga
___________________________________________
- 110 wheelstand pritchet
FrankenRover is offline   Reply With Quote Quick reply to this message
Old 03-26-2013, 08:04 AM   #14 (permalink)
Buckon37s's Avatar
Member # 20394
I have three sets left. A set is the two arms. The rest of the kit you would have to source (Isuzu rodeo torsion bar, hiems, bolts). $150 a set. At that price you can have the entire set built like mine for $225.
Team 911
Widia Cutting Tools
Sterling Autosport
PSC
Ruffstuff
Old 03-27-2013, 06:13 AM   #15 (permalink)
Member # 69597
This is bucks bar.
- gone fishin!!
- D-90 build
- Disco truggy-rip
Old 03-27-2013, 08:52 AM   #16 (permalink)
Member # 150724
Buck, you have a PM
Old 03-27-2013, 02:30 PM   #17 (permalink)
Member # 150724
What's the total width ? Outside face of arm to outside face of arm, from the pic's looks like it'll clear my shocks ok, just need to double check tonight b4 I get a set of Buck.
Thx.....
Old 03-27-2013, 04:00 PM   #18 (permalink)
Buckon37s's Avatar
Member # 20394
Thx.....
Trust me, you can't handle a set of Buck. It will kill you.
39.125in wide to outside.
Team 911
Widia Cutting Tools
Sterling Autosport
PSC
Ruffstuff
Old 03-27-2013, 08:54 PM   #19 (permalink)
Buckon37s's Avatar
Member # 20394
Just as an FYI, this system has now ran 6 KOH races on 3 cars. No Failures.
Team 911
Widia Cutting Tools
Sterling Autosport
PSC
Ruffstuff
Old 03-28-2013, 05:44 AM   #20 (permalink)
Member # 69597
here is the mount i built to fit it on my 90
- gone fishin!!
- D-90 build
- Disco truggy-rip
Old 03-28-2013, 07:00 AM   #21 (permalink)
Member # 91403
Id like to rock this on my RRC...
SHAWNBASSETT26 is offline   Reply With Quote Quick reply to this message
Old 03-28-2013, 07:28 AM   #22 (permalink)
Member # 150724
Gonna have to pass on them.... will foul my rear shocks on full stuff
Old 03-28-2013, 09:08 AM   #23 (permalink)
Member # 13683
You can mount them anyway you want. You can even mount the tube/torsion bar on the axle.
K.C.
Old 03-28-2013, 10:55 AM   #24 (permalink)
Buckon37s's Avatar
Member # 20394
That's the best way to do it if you are primarily a crawler/ DD.
Team 911
Widia Cutting Tools
Sterling Autosport
PSC
Ruffstuff
Old 04-06-2013, 11:14 AM   #25 (permalink)
Member # 151399
Buck - just sent you a PM to see if you have any more - thanks -Don
donb is offline   Reply With Quote Quick reply to this message
