What Axles to Upgrade a Series IIa? Toyota? - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-05-2015, 06:56 PM   #26 (permalink)
Member # 56837
e-mail sent
captcory is offline   Reply With Quote Quick reply to this message
Old 01-06-2015, 07:50 PM   #27 (permalink)
Member # 510146
I have found that the best way to brake stuff on these trucks is running too big of a tire and pushing them too hard. Running something like a 245/75-16 is about right for them stock. It wont kill what little acceleration you have, they put less stress on everything, and they are much easier to stop than bigger tires.
Make sure the braking system is 100% and you keep them adjusted (manual adjusters on the backing plate) and you should be fine. Make sure you carry spares (half shafts, points, condensor, cover plate for the trans for when the OD blows up...) and you should never brake anything. On one trip we did 15,000 miles in South America in a very heavy Ser II 109" and never broke anything, they are great trucks. Run it and enjoy it!
ArlowCT is offline   Reply With Quote Quick reply to this message
Old 01-26-2015, 03:43 AM   #28 (permalink)
Junkyddog11's Avatar
Member # 59532
Originally Posted by TMWTP View Post
Really? Cuz the stock brakes suck donkey balls.
Coming out with that statement is just like admitting that you shouldn't really pick up a wrench and if you do you should definitely not touch anything with it.
[FONT="Arial Narrow"][I][/I][/FONT]
Matt Browne
Dedicated to the resurrection of junk through engineering?
'61 88" IIA 2.5na "Soiled"
'89 RRC 300 Tdi 5spd "Swampslut"
'95 RRC LWB 300 Tdi auto
.....expansion complete. Now, the only Rover shop in Eliot Maine....is also the biggest.
Junkyddog11 is offline   Reply With Quote Quick reply to this message
Old 01-27-2015, 09:28 AM   #29 (permalink)
Member # 17378
There is almost nothing "Rover" left in drivetrain of either of my trucks, but I left the original drum brakes in both of them. Adjusted properly they're just fine. Don't understand all the hype of disc brakes, but if you want to spend $2k+ an axle for them, knock yourself out.
Lucas trucks are usually dead simple to figure out, there aren't many things to go wrong with them.
Mercedesrover is offline   Reply With Quote Quick reply to this message
Old 01-27-2015, 10:23 AM   #30 (permalink)
Member # 20109
Originally Posted by Mercedesrover View Post
...but if you want to spend $2k+ an axle for them, knock yourself out.
$1200. No need to exaggerate.
1991 D90 ex-MOD
red90rover is offline   Reply With Quote Quick reply to this message
Old 01-29-2015, 03:08 AM   #31 (permalink)
Member # 59532
After the amount of them that I have actually converted, Id have to say that you are under exaggerating, and Jim is very much closer. In a perfect world maybe, but its never that simple.
Matt Browne
Old 01-29-2015, 07:16 AM   #32 (permalink)
Member # 20109
Rocky Mountain Products, Parabolic Springs, Shackle Kits, Shock Absorber Kits
The kit sells for $1189.00 USD
Off the shelf, bolt in kit..... $1200 plus shipping + $100 if you want them to install new bearings. GM calipers, rotors and pads. No idea what you guys are doing..
1991 D90 ex-MOD
Old 01-29-2015, 01:03 PM   #33 (permalink)
Member # 13395
Sweet, custom crappy rotors for life and pads and calipers off a Lumina, what's not to like?
Edit: From TAW's writeup:
"These components were used on high performance models of the Chevy Lumina, Monte Carlo, Pontiac Grand Prix, Oldsmobile Cutlass Supreme and Buick Regal. They recommend telling your part dealer that you need parts for a 2001 Chevy Lumina."
Nice. I want that.
Edit again. I went digging for the caliper bore info for these things. The Lumina parts have two 42mm bore pistons. Regular defenders have 4X46mm bore. The OEM defender rear has a 41mm bore (2 pistons).
1994 FZJ80 with Mitsubishi 4D3 power
1980 Land-Rover crew cab with 6BT power
HandBuilt is offline   Reply With Quote Quick reply to this message
Old 01-29-2015, 02:02 PM   #34 (permalink)
Member # 42753
Drum brakes are like gremlins. They're great if you never get them wet.
And don't feed them after midnight.
Dougal is offline   Reply With Quote Quick reply to this message
Old 02-02-2015, 09:12 AM   #35 (permalink)
Member # 20109
Nice. I want that.
The only custom bit is turning out the center bore, which is pretty simple.
It is 2 pistons, but because it is a floating caliper, the force on the rotor is the same as a fixed four piston caliper. Rover pistons come in 41 and 46 mm, so these would brake similar to the smaller piston units.
The 42 mm pistons have around 84% the clamping pressure of the 46 mm.
1991 D90 ex-MOD
Old 02-02-2015, 12:50 PM   #36 (permalink)
Member # 13395
Aw yeah!
Old 02-02-2015, 02:27 PM   #37 (permalink)
Member # 13395
Just to clarify:
So you have to bore out the center and re-index a new pattern. The pic is from TAW's writeup.
Old 02-08-2015, 01:41 AM   #38 (permalink)
Member # 212466
The Wild Industries kit has plenty going for it.
Utilises defender discs, pads and callipers.
Wild Industries
Proudly supporting Black Jewish Gays since 2005.
DasLandRoverMan is offline   Reply With Quote Quick reply to this message
Old 02-09-2015, 08:05 AM   #39 (permalink)
Member # 175908
Just to clarify:
There were some guys on D90 Source talking about this. All I can say is WTF Seriously!!!! That seems like a giant pain in the ass. Rotors are wear items and need to be replaced. Who the hell wants to have rotors specially machined every time you need to change them???
fishEH is offline   Reply With Quote Quick reply to this message
Old 03-16-2019, 08:24 AM   #40 (permalink)
Member # 827538
I have a '68 109 that I relocated from Ireland to Arizona, I upgraded my power train from the 2.25 diesel to an LS1 5.3 out of an '05 Tahoe coupled to a 4L60 transmission and a customForbyn Brothers transfer case. I kept my semi-original axles (original 10 spline front axle & Salisbury from a '73 MOD 109). I put almost 10K miles on the upgrade before I had the rear hub bolts shear, and at that time I found out that I also snapped my front axle. I have no idea when I would have snapped the front axle as I hadn't used the 4WD in a while.
All I did was replace the front axle shaft, drilled out the snapped bolts in the rear, and upsized the bolt and changed them from grade 5 to grade 8. I am just rolling over 15K miles on the upgrade and am loving it. My Landy is my daily driver.
Here are my upgrades since relocating from Ireland:
1. '05 5.3L engine out of a Chevy Tahoe with a 4L60 automatic transmission with a Forbyn Bros. transfer case.
2. Hydroboost (power brakes ) for the brakes.
3. Power steering from a P38 Range Rover.
(Handles like a sports car and stops on a dime, okay a really big dime.)
4. Dual air conditioning (front and back). It's an Arizona Landy now, so AC is not an option.
5. Three fuel tanks. (Original MOD fuel tanks under the driver's and passenger's seat along with the 18 gallon rear tank. The two front tanks are tied together and the rear tank is separate with a GM fuel tank switch to switch from back to front.
6. Dakota Digital Gauge console, so all of the engine monitoring can be used from the computer.
7. LED headlights and running lights. I still have to upgrade to LED my reverse lights.
From the outside, she looks pretty stock aside from the 2" shackle lift I took from the '73 MOD 109 that I stripped for parts. And the LED lights.
magician2000 is offline   Reply With Quote Quick reply to this message
Old 04-20-2019, 04:32 AM   #41 (permalink)
Member # 43371
Is it grey-ish by any chance?
Originally Posted by magician2000 View Post
I have a '68 109
"Trapped in time. Surrounded by evil. Low on gas."
Custom car-toons >
rockbuggies welcome!
Michele is offline   Reply With Quote Quick reply to this message
