30 Spline Rovertracks - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-11-2019, 10:40 PM   #1 (permalink)
Member # 843601
Hi guys,
last year i purchased a used set of 30 spline Rovertracks axles with ARB lockers etc fully assembled for my TD5 Defender
My CV's are starting to make some sounds now and I'm looking to replace them.
any chance anyone can help me out with what CV's I'm looking for? i heard i need to get Hilux cv's and have them machined to fit rover hubs? anyone got the measurements by any chance? I know i could just take them out and measure them but don't want the truck t just sit there until I've got the new ones.
Also does anyone have some spare Rovertracks axles/cv's for sale and is open to freight to Australia?
thanks,
F.N.S is offline   Reply With Quote Quick reply to this message
Old 04-20-2019, 04:37 AM   #2 (permalink)
Member # 43371
Are your axles fully converted (Toyota differential in place of stock one) or just axles and CVs?
Anyway it's probably the 30 splines CV you should search for.
Mine have been "clicking" and doing some embarassing noise for yeeears,
you should be okay for a while...
[I]"Trapped in time. Surrounded by evil. Low on gas."[/I]
[COLOR="Red"][B]Custom[/B] car-toons > [/COLOR]
rockbuggies welcome!
Michele is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 07:38 PM   #3 (permalink)
Member # 73826
Check with Trail Gear, I think they took over distributing Longfield, and I think they are just 30 spline Longfield CV’s(birfs)
colorover is offline   Reply With Quote Quick reply to this message
Old 05-30-2019, 07:43 PM   #4 (permalink)
Member # 20109
If they are 24 spline purées then they do not exist. If they are 30/30 then they are regular Toyota CVs.
1991 D90 ex-MOD
red90rover is offline   Reply With Quote Quick reply to this message
Old 06-25-2019, 12:56 AM   #5 (permalink)
Member # 69967
I have the rovertracks conversion on my rig and you are correct, longfield cv's that have been machined to fit the rover. They're still installed so I can't measure for you.
And they're 30 spline.
leeroy is offline   Reply With Quote Quick reply to this message
Old 12-25-2019, 08:01 PM   #6 (permalink)
Member # 562410
Just went thru rebuilding the original Rovertracks/Longfield 30 spline conversion in my 1995 D1. For future reference-
The axle shafts measured:
Long Side: 32-15/16 inches
Short Side: 17- 11/16 inches
Both shafts had the following lengths of splines-
1.350" on one end
1.630" on the other end
For the CV's-
I used RCV Ultimate 30 Spline Toyota joints as replacement
Only modification needed to the CV's- the outside hub end splines on the RCV joint are roll formed and the peaks needed to be cleaned up to fit the spindle and drive flange.
WIRover is offline   Reply With Quote Quick reply to this message
Old 12-31-2019, 09:50 AM   #7 (permalink)
Member # 43371
How are your axles?
Mine are worn at the splined ends, it would be nice if RCV offered replacement axles as well.
Originally Posted by WIRover View Post
Just went thru rebuilding the original Rovertracks/Longfield 30 spline conversion (...)
Old 01-04-2020, 10:11 PM   #8 (permalink)
Member # 562410
I broke the inner star in one of my original longfield CV's and it destroyed the splines on the axle shaft when it failed. RCV does make custom shafts, and made me a set based on the dim's I listed above. However, I will not buy custom shafts from RCV again, it took them 3 months and their customer service was very poor...
Originally Posted by Michele View Post
How are your axles?
Old 01-06-2020, 01:30 AM   #9 (permalink)
Member # 843601
Awesome thanks a lot that really helps.
Similar Threads
Double splined shaft 35 spline inner 30 spline outer strength RANGERROD General 4x4 Discussion 2 11-25-2017 11:03 PM
FJ40 TG 30 Spline 4340 Longfield Axle Super Set PJohnson Axles/Tires/Wheels For Sale 1 04-28-2017 07:10 PM
Yukon 30 spline hubs sneakysnake Misc. Stuff For Sale 0 02-05-2017 10:31 AM
Yukon Grizzly Locker CCOR Axles/Tires/Wheels 152 06-12-2013 06:22 AM
Alloy USA Front Grande 30 Spline Chromoly Axleshafts for D30 & D44 crawlz Axles/Tires/Wheels For Sale 3 05-24-2012 05:49 AM
