Vision X | 2 Inch Light POD | Narrow Beam - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Lighting and Electronics
Old 09-25-2018, 10:00 AM   #1 (permalink)
Reno Off-Road's Avatar
Member # 186031
Send a message via Skype™ to Reno Off-Road
2" Light POD by Vision X is a built to last product. These lights will give you the vision you need under all night time situations, off-road excursion or racing.
  • Part Number: V/X4007314
  • Clear lens
  • 10 degree beam
  • Universal
  • Black aluminum housing
  • Unbreakable polycarbonate lens
  • 50,000 hour lifespan
  • 2" x 2"
  • 10 watts
  • 900 lumens
  • Sold individually
Shop Now: Reno Off-Road Vision X
The Solo s1100 in the Solstice Series of LED off road lamps is equipped with Vision’s brand new 10 watt LED technology, with each 10 watt Solo producing 900 lumens in only a 2” x 2” square housing. Not only are they the brightest, they are the most efficient with the s1100 drawing only 0.83 amps due to their advanced electronic drivers which are also responsible for their 50,000 hour life span and variable 9 - 50 Volt DC input.
The Solstice Solo’s main feature is the 4 sided channel design that allows you to interlink it on all four sides with another Solstice Solo pod or other various available mounting hardware for flat, tube or even helmet mount making it the only modular light with the ability to make any shape or length. Key features are as follows; rugged die-cast aluminum housing provides optimum durability and heat dissipation.
The Solstice Solo series features an IP68 ingress protection rated housing making them impenetrable to dust and submersible under water up to 3 meters. The unbreakable polycarbonate lenses are housed by a 6061 aluminum face plate which doubles as a radiant heat sink to melt away snow and ice in frigid conditions.
The Solstice Solo series has been subjected to a 15.6Grms vibration test to ensure their performance in high impact conditions. Built to last, this Vision X series features a lifetime warranty.
Reno Off-Road
Jeep * 4x4 * Buggy * Race
Parts & Accessories
775.553.8333
Reno Off-Road is offline   Reply With Quote Quick reply to this message
