Roxor Crawler Build - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Brand Specific Tech > Mahindra Roxor
Old 12-04-2018, 12:32 PM   #51 (permalink)
Member # 507513
Originally Posted by Lil Uzi View Post
The Mahindras sold in USA are what.... built here ?? About $16,000 ? Wife says they are about $8,000 in India.
Well get the wife to import em then
A good US supply for Thar parts could be rather lucrative side hussle.
jrobz23 is offline   Reply With Quote Quick reply to this message
Old 12-19-2018, 05:43 PM   #52 (permalink)
Member # 90681
Just ordered a bunch of parts for this thing. Build to continue soon.
RDK_YJ88 is offline   Reply With Quote Quick reply to this message
Old 12-20-2018, 02:49 PM   #53 (permalink)
Member # 90681
These 35s look huge.
Old 12-20-2018, 08:41 PM   #54 (permalink)
Member # 177092
So, how much sheetmetal are you planning on cutting off? Or are you planning on running 12" long shackles to get enough shackle lift (plans on first page)?
'84 Bronco II is offline   Reply With Quote Quick reply to this message
Old 12-21-2018, 05:03 AM   #55 (permalink)
Member # 90681
As much as it takes. Things have changed a bit from the original plans.
9" axles front and rear.
5.43 gears and 35 spline spools front and rear
39.5 Bias Iroks
YJ leafs
Custom Cage
Armor
etc.
Old 12-21-2018, 07:15 AM   #56 (permalink)
Member # 75858
Did you bring this out to Dale's gig? I didn't see you.
LQ9, Atlas, tons, 8274 & the rest of the usual
white-rhino is offline   Reply With Quote Quick reply to this message
Old 12-21-2018, 08:52 AM   #57 (permalink)
Member # 90681
Originally Posted by RDK_YJ88 View Post
Called for rain all day so I took the truck. Of course it didn't rain the whole time I was there.
Old 12-21-2018, 08:54 AM   #58 (permalink)
Member # 75858
Pussy
Old 12-21-2018, 09:01 AM   #59 (permalink)
Member # 90681
Pussy
You also talked to me and shook my hand at the entrance. You must be getting old
Old 12-21-2018, 09:11 AM   #60 (permalink)
Member # 75858
Just because I said hi to you in your purdy white truck didn't mean that maybe your brother or some other friend was bringing it. (you do have friends don't you? )
Old 12-25-2018, 12:50 PM   #61 (permalink)
Member # 90681
Making some progress.
Waiting on some parts for the front axle.
Getting the old brackets cut off and the new ones fabbed up.
Old 12-27-2018, 04:12 PM   #62 (permalink)
Josh40601's Avatar
Member # 171332
so... what about the 4600 build? No more go on that one?
The never-ending project
An old Explorer with a lot of dents
Josh40601 is offline   Reply With Quote Quick reply to this message
Old 12-27-2018, 04:49 PM   #63 (permalink)
Damn kids
plym49's Avatar
Member # 162771
If you are going to cut and replace that much, what was the point of spending that much for the core vehicle? An old CJ would have cost pennies by comparison. And would have been eligible for tags.
It is cool what you're doing, but still.
Always tip.
plym49 is offline   Reply With Quote Quick reply to this message
Old 12-28-2018, 05:59 AM   #64 (permalink)
Member # 90681
It's still happening, just not for KOH this year. We are planning to run the east coast series this year and KOH 2020. Gives us some more time to figure out some design changes we are making. Planning to have the roxor done for KOH this year so we can check it out though.
So far, all I've cut is the leaf spring mounts. It's not like I've cut it up and made a buggy out of it.
Jeeps in Michigan are rusty. Whether it's a CJ, YJ, TJ and even some JK's. This thing is brand new, you can pick any color you want, all steel body, already has an electronic Turbo Diesel, cast iron 5 speed trans, cast iron T-case, interior is bed lined, etc. Seemed like a good base for a crawler.
Original build plans didn't consist of 40s, but I got an awesome deal on these Iroks from a buddy so I skewed the plans a little. Trying to keep it leaf springs to save some cost and also keep it similar to how it was built originally.
Old 12-28-2018, 07:53 AM   #65 (permalink)
Member # 75858
I like it Tom.
Old 12-28-2018, 07:54 AM   #66 (permalink)
Josh40601's Avatar
Member # 171332
well i hope to see the Roxor next year and the Colorado in 2020 then!
Old 12-31-2018, 06:16 AM   #67 (permalink)
Member # 90681
Holding it's own weight in the front. Switched out the 2.5" YJ leafs for 4" YJ leafs.
Front axle will be coming back out for steering and adding .25" diff guard to the bottom half.
Lot's of work to do still.
Old 12-31-2018, 05:20 PM   #68 (permalink)
Josh40601's Avatar
Member # 171332
what made you want to stay spring under? Axle wrap? That axle is freaking awesome. jealous as hell
Old 12-31-2018, 06:59 PM   #69 (permalink)
Member # 90681
Haha thanks.
Mainly to keep it low while maintaining a spring that isn't flat.
Old 12-31-2018, 07:04 PM   #70 (permalink)
Josh40601's Avatar
Member # 171332
Haha thanks.
What's the up travel going to be like on the passenger side?
Sent from my Pixel 2 XL using Tapatalk
Old 12-31-2018, 07:30 PM   #71 (permalink)
Member # 90681
3-4" without modifying the frame.
Old 12-31-2018, 07:34 PM   #72 (permalink)
Josh40601's Avatar
Member # 171332
Very cool.
Old 01-01-2019, 09:06 AM   #73 (permalink)
Tuff Jeeper's Avatar
Member # 207270
Subscribed!
00 TJ
3 hrs from Moab
Tuff Jeeper is offline   Reply With Quote Quick reply to this message
Old 01-01-2019, 08:49 PM   #74 (permalink)
Member # 90681
Getting shocks mounted up. Also modified the bumper to fit back on.
After shock mounts are complete I'll move onto bump stops, then pull the front axle for final welding on brackets and adding some beef to the diff.
Old 01-03-2019, 11:22 AM   #75 (permalink)
Josh40601's Avatar
Member # 171332
are you guys going to start developing products for these too, or is this just a personal fun build?
