Roxor Crawler Build - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Brand Specific Tech > Mahindra Roxor
Old 01-03-2019, 01:37 PM   #76 (permalink)
today
fredycruger's Avatar
Member # 225557
awesome build
please more pics of the leaf spring perches
fredycruger is offline   Reply With Quote Quick reply to this message
Old 01-04-2019, 09:43 AM   #77 (permalink)
Member # 90681
Originally Posted by Josh40601 View Post
are you guys going to start developing products for these too, or is this just a personal fun build?
We offer the bumpers through our sister company www.589motorsports.com Slowly working on more products for them.
Originally Posted by fredycruger View Post
awesome build
I'll have to take some more this weekend.
RDK_YJ88 is offline   Reply With Quote Quick reply to this message
Old 01-05-2019, 01:33 PM   #78 (permalink)
Member # 685938
Love the build so far!
Christopher.h is offline   Reply With Quote Quick reply to this message
Old 01-10-2019, 04:14 AM   #79 (permalink)
Member # 90681
Front diff guard going on. Made from 1/4" to bring the total thickness to 3/8's in the high impact areas. I don't know why that pad looks angled in the picture, it doesn't in person.
Parts for brakes, steering and rear axle are starting to show up. Front suspension is mostly complete.
Old 01-16-2019, 11:37 AM   #80 (permalink)
Member # 90681
A lot to do before we hit the road for KOH. A lot of parts in the mail.
Old 01-22-2019, 05:12 AM   #81 (permalink)
Member # 90681
Rear axle is scheduled to show up today. Just waiting on the orbital valve to show up to be able to finish up the front.
Working on our new DIY front flat fender kit.
Old 01-22-2019, 06:48 AM   #82 (permalink)
Member # 75858
You gonna paint it red?
LQ9, Atlas, tons, 8274 & the rest of the usual
white-rhino is offline   Reply With Quote Quick reply to this message
Old 01-22-2019, 07:29 AM   #83 (permalink)
Member # 90681
It's not red already?
Old 01-23-2019, 08:27 AM   #84 (permalink)
Member # 90681
Rear axle showed up. I'm pretty impressed with it. About $1200 for the axle, shafts, bearing pockets and seals shipped. Trail-gear had it welded and shipped within 3 days.
Hopefully have it mounted in the Roxor tonight or tomorrow night. Will need to get the wheel bearings bored out for the 35 spline shafts.
Old 01-23-2019, 08:56 AM   #85 (permalink)
whitneyj's Avatar
Member # 135947
What calipers are those bearing pocket brackets for?
Place banana in your ear.
Observe that there are no alligators around.
Conclude bananas placed in ears keep alligators away.
whitneyj is offline   Reply With Quote Quick reply to this message
Old 01-23-2019, 09:02 AM   #86 (permalink)
Member # 90681
I have no idea. I'll be making brackets for K10 calipers.
Old 01-23-2019, 09:13 AM   #87 (permalink)
whitneyj's Avatar
Member # 135947
Ah, gotcha. I assumed the bearing pockets had the caliper brackets on there specific to what you ordered.
Old 01-23-2019, 09:30 AM   #88 (permalink)
Member # 90681
I beleive Trail-gear has brackets, calipers and rotors that bolt on.
Old 01-25-2019, 11:02 AM   #89 (permalink)
Josh40601's Avatar
Member # 171332
does it run the toyota drop out or ford?
The never-ending project
An old Explorer with a lot of dents
Josh40601 is offline   Reply With Quote Quick reply to this message
Old 01-25-2019, 11:40 AM   #90 (permalink)
Member # 90681
Ford.
Old 01-29-2019, 06:10 AM   #91 (permalink)
Member # 90681
Things to do before Friday in no particular order:
1. Lengthen driveshafts
2. Button up steering hoses and cooler / Fill with fluid
3. Trim Rear fenders
4. Plumb brake lines (fittings should be here today)
5. Assemble rear axle (waiting on breather and drive flanges, should be here tmr)
6. Make engine skid plate
7. Mount rock sliders
8. Mount and wire fog lights
9. Mount and wire rock lights
10. Fill all fluids (Steering, brakes and axles)
Tires are back on to figure out trimming.
Rear calipers mounted. K10 Caliper and pads, rear superduty rotor and superduty wheel bearing are used on all 4 corners.
Old 01-30-2019, 05:36 PM   #92 (permalink)
Member # 429
It's looking great.
Jack
2007 2500hd max/ali with stuff.
2008 FWC Hawk
1985 4Runner 4.3, R151 on tons
locrwln is offline   Reply With Quote Quick reply to this message
Old 02-10-2019, 04:00 PM   #93 (permalink)
Member # 90681
We had an awesome time at KOH. Got the Roxor "finished" enough to drag it across the country with zero testing.
Other than a few issues, it did great and moved our butts around the desert all week.
Issues:
- Front axle is leaking diff fluid from the passenger. Must have damaged the cheap summit seal when installing the shafts.
- All four tires rub really bad. It was expected though, since I ran out of time for bump stops. Ended up trimming the rear fenders a little more on the lake bed.
- Steering is super slow at low rpm. Going to look into swapping the pulley or the whole pump.
- Mile marker hub on the pass. side kept unlocking for some reason. Will upgrade to chromo outters and flanges.
- Brakes are super soft. Have to look into a booster upgrade.
Still need to finish up the rock sliders and rear corner armor.
Looking into a 1" body lift to allow me to raise the trans and tcase to help with building a flatish belly skid. Also need to get beadlocks as we burped all the air out of one tire on the trail.
Old 02-14-2019, 06:27 PM   #94 (permalink)
TexasCrawler's Avatar
Member # 773489
Subscribed!
I love what people are doing with these things! Great platform to build off of
TexasCrawler is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 11:07 AM   #95 (permalink)
Member # 85483
Just out of curiosity, why didn't you do a shackle reverse on the front?
Today, truth has been forced to take a back seat to political correctness
thumping is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 11:41 AM   #96 (permalink)
Member # 90681
Never really had an issue with my other front shackle rigs, so i didn't see the need for it.
Plan is to run it for the season and tear it down for links in the winter sometime.
Waiting on new seals for the front axle and chromo stubs/flanges to show up.
Old 04-08-2019, 11:53 AM   #97 (permalink)
YotaAtieToo's Avatar
Member # 25632
Properly set up front shackle works way better imo. Plus no need for stupid long drive shaft slip.
Old 05-31-2019, 10:53 AM   #98 (permalink)
Member # 1176
subscribed
June 28th 2003
Berg is offline   Reply With Quote Quick reply to this message
Old 06-04-2019, 06:52 AM   #99 (permalink)
Slab King
BronsonJeep's Avatar
Member # 775225
This thing is cool. Sub'd.
What gear ratio are you running?
What's available to up the power from the little diesel?
89YJ; 3-link/SOA; D44/Super 88; 5.7 V8/3550/241OR; 5.13's; 37s, cage, 97" wheelbase
BronsonJeep is offline   Reply With Quote Quick reply to this message
Old 06-17-2019, 06:30 AM   #100 (permalink)
Member # 90681
5.43s with 35 spline spools front and rear. There are a bunch of tunes out there now that pretty much double the power.
