Under drive adapter kit, 231 to 6 bolt/205 - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 10-15-2011, 09:27 PM   #26 (permalink)
busyfixin's Avatar
Member # 95131
When do we get to see the 271 variant?
thats not how the internet works. i'm an expert on here, not in real life.
When in doubt, throttle out!
busyfixin is offline   Reply With Quote Quick reply to this message
Old 10-17-2011, 05:04 PM   #27 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Unfortunatly don't have anything in the works for that, don't have any of those kicking around to mock up. Haven't had any demand previously and those cases aren't exactly cheap on the used market just yet. If things change down the road, we'll post it up.
Thanks,
Mike
Trail Tech Fab
Home of Infinitely Clockable T-Case Components and Adapter Kits
CNC plasma cutting up to 1 inch, PM me for more info.
mpascino is offline   Reply With Quote Quick reply to this message
Old 10-21-2011, 05:09 AM   #28 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Thanks for the order!
Trail Tech Fab
Old 11-12-2011, 09:22 PM   #29 (permalink)
Member # 147891
im glad to see that your producing these now
i see that your able to gets shafts now i had a 241 and c6 shaft put together and then welded when it lets go, would you be willing to sell me just a shaft and will it work with the adapter that made for me
to every one mike is a stand up i guy i pm'ed him with a request to make this adapter for my wife and he did and did it fast he even had to remake one of the parts due to an interferance with the front shift rail
mog-10 is offline   Reply With Quote Quick reply to this message
Old 11-13-2011, 03:47 PM   #30 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Thanks for the feedback! If the time comes that you need another shaft we'll figure something out. We're out of the country until after the holiday but ill respond the everyones messages when we are back in town. For piece of mind I'll let you know the length of our "stock" shaft as well. Thanks, be back in a couple weeks!
Trail Tech Fab
Old 12-12-2011, 05:54 AM   #31 (permalink)
Member # 83301
Do you have anything for 203/205's
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 12-15-2011, 05:17 AM   #32 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
We can manufacture the adapters for the 203/205 but we do not carry shafts for this setup. Most of our customer will run our Diablo crawl box in place of a 203/205.
Trail Tech Fab
Old 12-19-2011, 09:20 AM   #33 (permalink)
Member # 42040
I haven't been able to find information on your Diablo assembly.
How long? How many planetary gears? Gear Reduction? Cost?
Currently have TH400 2 1/2" stickout output with 8 bolt NP205 clocked flat. Would like to put a range box between them, but would like something with deeper gears than NP203.
Had a Jeep...built a buggy, now making it better!
tirespeed is offline   Reply With Quote Quick reply to this message
Old 12-22-2011, 09:13 AM   #34 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Diablo Crawler
The Diablo crawler is based upon the NP241 gear set and boasts a 2.72:1 ratio in low gear. This is the identical gear set that is found in competitor's boxes. Inputs gears are available in any configuration used in the NP T-cases (21,23,27,31,32 spline), however we only carry 23, 27,32 as these are the most popular. We can special order all the others if needed, just let us know your application and we can help you figure it out. As of now output shafts are only available in 31 and 32 spline configurations as strength becomes an issue with anything smaller. The unit mounts to factory 6 bolt round transfer case adapters.
The housing is machined from 6061 aluminum billet and utilizes a steel "rear adapter" to mate up to various tcases, figure 8 205's included. Strength is not an issue as the housing/gear set is rated for 5500 ft/lbs input torque. The steel adapter also provides a location to weld support brackets and tabs for mounts and shift linkage if needed. Both the front and rear of the Diablo are clockable in 5* increments making it completely universal for any application. You'll never have to worry about shift housing interference or clocking of the rear t-case with the Diablo, unlike other crawl boxes this is truely universal. Additionally, the Diablo is shipped with a cable shifter.
I finally got around to posting up a gallery of some photos for everyone to check out.
http://www.trailtechfab.com/gallery/...p?g2_itemId=98
Let us know if you have any other questions we can answer. I'll PM you on your specfic application.
Thanks,
Mike
Trail Tech Fab
Trail Tech Fab
Old 03-21-2012, 03:07 PM   #35 (permalink)
Member # 138878
looking for a crawl box setup for my rig. can you e mail me a pm?
i have a 93 chevy nv 4500, 32 spline output, a np 241 matching case and want to bolt a 79 ford 3/4 ton np 205 to it, 31 spline i believe?
can you give me a quote to 95407? looking to get this done pretty quick
[email protected]
swampers1226 is offline   Reply With Quote Quick reply to this message
Old 03-22-2012, 05:20 AM   #36 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Sent you an email. Thanks!
Trail Tech Fab
Old 03-22-2012, 05:21 AM   #37 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Originally Posted by diver14_98 View Post
do you have a plate for the 8 track 205?
PM sent.
Trail Tech Fab
Old 04-06-2012, 07:35 AM   #38 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Bump for the holiday weekend!
Trail Tech Fab
Old 04-18-2012, 10:03 AM   #39 (permalink)
Member # 121996
Dodge 241 hd to dodge 205
I have a 23 spline male dodge input on my 205, and a 241 hd driver side drop from a 97 diesel 2500. Will your doubler work with these cases? Thanks, Pat
It should take milliseconds.
tworbotalon is offline   Reply With Quote Quick reply to this message
Old 04-19-2012, 07:24 AM   #40 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Sorry we don't offer a 23 spline version at this time, mainly due to durability concerns with the coupling between the underdrive and the 205. Also the case is a little different on your HD 241 and I am not sure how everything would line up. The 241 you have is worth a few bucks, IMO you would be better off picking up a plain 241 and selling the one you have. Most of the "HD" components of the 241HD would be eliminated with the use of the kit.
Let us know if you have any other questions,
Mike
Trail Tech Fab
Trail Tech Fab
Old 04-30-2012, 07:38 PM   #41 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Thanks for the business guys!
Trail Tech Fab
Old 05-11-2012, 05:38 AM   #42 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Thanks for the business and props guys! Let us know if we can help with anything else!
Trail Tech Fab
Old 05-24-2012, 05:20 AM   #43 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Have a few kits in the pipeline, meaning quick turn around on the 241 kits. Hit us up with any questions.
Thanks,
Mike
Trail Tech Fab
Old 05-28-2012, 09:19 AM   #44 (permalink)
Dodgzilla's Avatar
Member # 43021
I've got a 96 Dodge (5.2 and a 5 speed) and would like to keep my speed sensor functional. Would it be possible to adapt the speed sensor from the output side of my original case to the spacer between the 2 cases? Has anyone looked into this? I don't have my 231 torn apart yet to see the differences in spline count or shaft diameter but I was thinking that if I could "tee" into the adapter spacer and put the sensor there it would keep the computer happy. Thanks for your help.
Dodgzilla is offline   Reply With Quote Quick reply to this message
Old 06-02-2012, 03:58 PM   #45 (permalink)
Member # 81349
I want.... but have limited space. Any one have mounting surface to output length?
support all local clubs and parks.
bingejeeping is offline   Reply With Quote Quick reply to this message
Old 06-04-2012, 05:36 AM   #46 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
PM sent
Trail Tech Fab
Old 06-04-2012, 05:45 AM   #47 (permalink)
Trail Tech Fab
mpascino's Avatar
Member # 31320
Overall length will depend on application. Which NP 205/t-case are you looking to run? I will get some number later today.
Thanks,
Mike
Trail Tech Fab
Old 06-18-2012, 12:46 PM   #48 (permalink)
Member # 154115
Not sure I've seen it yet, but can I get a 241 PSD to 32 spline input GM NP205, racetrack pattern? How much shipped to 78130? Want the shift rails out the front on the NP205
Also, when you cut the 241, the filler panel that is provided, is that welded in or what? How do you go about keeping the planeteries oiled?
badassblaze is offline   Reply With Quote Quick reply to this message
Old 07-06-2012, 07:13 AM   #49 (permalink)
Member # 217114
Hi, You keep making the kit for make a 231/300 doubler??
you could send one of your kit to Spain through USPS or UPS?
I'm looking for one like this.
Or if you can make a crawl box for a np231, to make a reduction of 7:1 or similar, I`m also interested
thanks.
kjuanmi is offline   Reply With Quote Quick reply to this message
Old 10-07-2012, 09:03 AM   #50 (permalink)
Member # 127283
I'm looking into the 231-205 doubler and was wondering what you guys are doing for shifters?
71bronco,
terrorism is "change"..keep calm and carry guns!
broncomitch is offline   Reply With Quote Quick reply to this message
