LSx Stamped Steel Oil Pan - Page 11 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 06-07-2016, 05:56 PM   #251 (permalink)
Pacific Fabrication's Avatar
Member # 127840
Oil pans are back in stock!
Follow us on
Pacific Fabrication is offline   Reply With Quote Quick reply to this message
Old 06-29-2016, 03:49 PM   #252 (permalink)
Member # 127840
Thanks for the orders!
Follow us on
Old 07-02-2016, 07:05 PM   #253 (permalink)
Newbie
Member # 174402
Hopefully I didn't miss someone asking this question. With the LS mated to a Turbo400 will the engine oil pan and trans pan bottoms have the same ground clearance?
Also, shipping to 66062
Thanks..
kchusky is offline   Reply With Quote Quick reply to this message
Old 07-05-2016, 03:42 PM   #254 (permalink)
Member # 127840
They are pretty close. The picture below is a 6.0L with the pro series pan and a TH400. Shipping to you is about $27.
Follow us on
Old 08-09-2016, 10:47 AM   #255 (permalink)
Member # 127840
Thanks for the orders! More pans are in stock and ready to ship today!
Follow us on
Old 08-28-2016, 07:53 AM   #256 (permalink)
Member # 101998
The remote oil filter adapter is for an oil cooler right? How much is that needed for "eventually" racing?
KOH...building & saving since 2010. I'll get to the start line eventually.
RubiconJeepGuy is offline   Reply With Quote Quick reply to this message
Old 08-29-2016, 11:31 AM   #257 (permalink)
Member # 127840
The remote oil filter adapter allows you to run a remote oil filter. You can actually use factory style oil cooler lines or a Lingenfelter unit pictured below.
Follow us on
Old 08-29-2016, 02:24 PM   #258 (permalink)
Member # 101998
OK, thanks. I'm dumb on this topic so forgive my ignorance, but why run a remote filter vs. the stock one? Packaging or performance?
Old 08-29-2016, 04:36 PM   #259 (permalink)
Member # 127840
On some models like a Jeep CJ, depending on how much lift it has, you may run into a clearance issue between the driveshaft and the edge of the oil filter. When you run the filter remotely you would have two lines coming out where the filter was allowing for a couple inches of extra clearance. Or in say an Ultra 4 buggy it may be more convenient to mount the filter in a more accessible location.
Follow us on
Old 09-02-2016, 12:24 PM   #260 (permalink)
Member # 127840
More oil pans are in production and should be ready to ship soon!
Follow us on
Old 09-13-2016, 02:09 PM   #261 (permalink)
gt1guy's Avatar
Member # 236179
Just read every page and I have the same question, but for running a 6l90 auto trans. I'm running a double triangulated 4-link in front and the lowers converge just under the back of the trans pan.
Kevin
gt1guy is offline   Reply With Quote Quick reply to this message
Old 09-14-2016, 02:59 PM   #262 (permalink)
Member # 127840
The 6L90 hangs a bit lower than the TH400. Measuring from the locating pins on the bellhousing to the bottom of the pan is about 11".
Follow us on
Old 09-14-2016, 04:19 PM   #263 (permalink)
gt1guy's Avatar
Member # 236179
Thank you Sir.
Price for a pro pan and remote filter adapter shipped to 70560?
Old 09-15-2016, 02:44 PM   #264 (permalink)
Member # 127840
PM sent
Follow us on
Old 09-29-2016, 09:28 AM   #265 (permalink)
Member # 127840
Follow us on
Old 10-10-2016, 05:11 PM   #266 (permalink)
Member # 127840
Follow us on
Old 11-01-2016, 05:44 PM   #267 (permalink)
Member # 127840
Oil pans are in stock and ready to ship!
Follow us on
Old 11-24-2016, 09:23 AM   #268 (permalink)
Newbie
Member # 174402
Any Black Friday or Cyber Monday deals?
Old 01-04-2017, 02:08 PM   #269 (permalink)
Member # 127840
Follow us on
Old 01-29-2017, 07:47 PM   #270 (permalink)
THE ROCK GODS
B2Krawler's Avatar
Member # 18818
shipped to 96118
Thanks
ETA?
KOH CAR 415, McCarthy Motorsports
THE ROCK GODS, Reno Nv
Hey Tech Fabrication
HTF buggy, 6.0, 40s, Spidertrax/Megas,
RZR XP1000
B2Krawler is offline   Reply With Quote Quick reply to this message
Old 02-01-2017, 05:35 PM   #271 (permalink)
Member # 127840
PM sent
Follow us on
Old 02-08-2017, 08:11 AM   #272 (permalink)
Member # 662346
What's everyone doing for the back 2 bolts?
The stock bolts are M6-1.0x135mm Bolts. I guess I'll measure the threaded length of the stock bolts and get something a little shorter than that section.
foo.c is offline   Reply With Quote Quick reply to this message
Old 02-11-2017, 06:19 PM   #273 (permalink)
fordnut's Avatar
Member # 50971
So no option to buy either the oil filter base or the remote adapter , I would need to buy the pan kit and then add the 75 $ remote adapter and shelf the oil filter base I'll never use.
I dont remember what gears I had, but they barely fit in..
fordnut is offline   Reply With Quote Quick reply to this message
Old 02-12-2017, 10:12 PM   #274 (permalink)
Member # 127840
PM sent.
Follow us on
Old 02-12-2017, 10:15 PM   #275 (permalink)
Member # 127840
The pan comes standard with the oil filter block. The remote block is sold separately. Give me a call on Monday 408-600-0122.
Follow us on
